FTPD-1
FTPD-1
    BRIDGETEK
    FT51A PROGRAM AND DEBUGGER MODUL
FTPD-1 数据手册
FTPD-1 FTDI Programmer Debugger 1 Module Datasheet Version 1.0 Document Ref erence No.: FT_001263 Clearance No.: FTDI# 480 Future Technology Devices International Ltd FTPD-1 FTDI Programmer Debugger 1 Module Datasheet FTPD-1 is a module used for programming and debugging. 1. Introduction 1.1 Features The FTPD-1 is a module with a FT230X USB to UART converter and a dual buffer. The FTPD-1 utilises these components to generate a single line half-duplex UART signal with no handshake w hich can be used to program several of FTDI’s MCU devices, predominantly FT51A. The FTPD-1 has the following features: This module also provides a switched 5V power supply to the target device and is configured such that it does not infringe USB compliance regulations for supplying bus power.  FTPD-1’s board dimensions are the same as a credit card; however the fitted components give it additional height. The module is supplied with a berg connector ribbon cable; however it is compatible for operation with pogo pin cables. All components used, including the FT230X are Pb-free (RoHS compliant).  Full-Speed USB to UART converter  Single half-duplex UART data pin input/output Two dedicated GPIOs to control Reset# and Prog# outputs  TXDEN line to control the direction of the halfduplex UART data  PWREN# line to control the power supply  2X3 way 2.54mm pitch shrouded male header  150mm ribbon cable with Female to Female 2.54mm pitch 2x3 way connectors  Protected by resettable fuse with 0.5A hold current and schottky diode on the output power line.  Pogo pin compatible  Power output available, indication LED N either the whole nor any part of the information c ontained in, or the produc t des c ribed in this manual, may be adapted or reproduc ed in any material or elec tronic form without the prior written c ons ent of the c opyright holder. T his produc t and its doc umentation are s upplied on an as - is basis and no warranty as to their s uitability for any partic ular purpose is either made or implied. Future T echnology D evices I nternational L td will not ac c ept any c laim for damages hows oever aris ing as a res ult of us e or failure of this produc t. Y our s tatutory rights are not affec ted. T his product or any variant of it is not intended for use in any medic al applianc e, devic e or s ys tem in whic h the failure of the produc t might reas onably be expec ted to res ult in pers onal injury. T his doc ument provides preliminary information that may be s ubject to c hange without notice. N o freedom to us e patents or other intellectual property rights is implied by the public ation of this doc ument. Future T ec hnology D evic es I nternational L td, U nit 1 , 2 Seaward P lace, C enturion Business P ark, G lasgow G 4 1 1 HH U nited Kingdom. Sc otland Regis tered C ompany N umber: SC 1 3 6 6 4 0 Copyright © 2015 Future Technology Devices International Limited 1 FTPD-1 FTDI Programmer Debugger 1 Module Datasheet Version 1.0 Document Ref erence No.: FT_001263 Clearance No.: FTDI# 480 Table of Contents 1. Introduction ................................................................. 1 1.1 Features ................................................................................ 1 2 Driver Support ................................................................ 3 3 Ordering Information ...................................................... 4 4 FTDP-1 Signals ............................................................... 5 4.1 FTPD-1 Pin Out ...................................................................... 5 4.2 Signal Descriptions ................................................................... 6 5 Module Dimensions......................................................... 7 6 FTPD-1 Module Circuit Schematic .................................... 8 7 Hardware Setup Guide .................................................... 9 7.1 Connecting to MCU board ....................................................... 9 7.2 Connecting to PC ...................................................................10 8 Contact Information ..................................................... 11 Appendix A – List of Figures and Tables............................ 12 List of Figures ...............................................................................12 List of Tables ................................................................................12 Appendix B – Revision History.......................................... 13 2 C opyright © 2015 Future T echnology D evices I nternational L imited FTPD-1 FTDI Programmer Debugger 1 Module Datasheet Version 1.0 Document Ref erence No.: FT_001263 Clearance No.: FTDI# 480 2 Driver Support Royalty-Free Drivers (USB Drivers + DLL S/W Interface):  Windows 10 32,64-bit  Windows 8.1 32,64-bit  Windows 8 32,64-bit  Windows 7 32,64-bit The drivers listed above are all available to download for free from www.ftdichip.com. 3 C opyright © 2015 Future T echnology D evices I nternational L imited FTPD-1 FTDI Programmer Debugger 1 Module Datasheet Version 1.0 Document Ref erence No.: FT_001263 Clearance No.: FTDI# 480 3 Ordering Information Module Code Description FTPD-1 FTDI Programmer / Debugger Module 4 C opyright © 2015 Future T echnology D evices I nternational L imited FTPD-1 FTDI Programmer Debugger 1 Module Datasheet Version 1.0 Document Ref erence No.: FT_001263 Clearance No.: FTDI# 480 4 FTDP-1 Signals 4.1 FTPD-1 Pin Out 1 : NC 2 : VSW 3 : RESET# 4 : PROG# 5 : DBG 6 : GND Figure 1 – Module Pin Out Figure 1 illustrates the signals available on the 6 pin header of the FTPD-1. 5 C opyright © 2015 Future T echnology D evices I nternational L imited FTPD-1 FTDI Programmer Debugger 1 Module Datasheet Version 1.0 Document Ref erence No.: FT_001263 Clearance No.: FTDI# 480 4.2 Signal Descriptions Pin No. Name Type Description C N2-1 NC Not C onnected Floating pin. C N2-2 VSW Power Out C N2-3 RESET# Signal Output Active low reset output. C N2-4 PROG# Signal Output Active low PROG# output.. C N2-5 DBG Signal Input/output Half-duplex UART data pin. C N2-6 GND Ground 0V Ground. 5 volt power output. Outputs power sources from the USB bus when the FT230X has enumerated. Table 1 - Module Pin Out Description Pin No. Name Type Description C N1-1 VBUS Power 5 volt power input. C N1-2 DM Signal Input/Output USB Data - from upstream device C N1-3 DP Signal Input/Output USB Data + from upstream device C N1-4 GND Ground 0 volt ground. Table 2 - Upstream USB Port Pin Out Description 6 C opyright © 2015 Future T echnology D evices I nternational L imited FTPD-1 FTDI Programmer Debugger 1 Module Datasheet Version 1.0 Document Ref erence No.: FT_001263 Clearance No.: FTDI# 480 5 Module Dimensions Figure 2 – FTPD-1 Module Dimensions All dimensions are given in millimetres. The FTPD-1 module exclusively uses lead free components, and is fully compliant with European Union directive 2002/95/EC. 7 C opyright © 2015 Future T echnology D evices I nternational L imited FTPD-1 FTDI Programmer Debugger 1 Module Datasheet Version 1.0 Document Ref erence No.: FT_001263 Clearance No.: FTDI# 480 6 FTPD-1 Module Circuit Schematic Figure 3 – Module Circuit Schematic 8 C opyright © 2015 Future T echnology D evices I nternational L imited FTPD-1 FTDI Programmer Debugger 1 Module Datasheet Version 1.0 Document Ref erence No.: FT_001263 Clearance No.: FTDI# 480 7 Hardware Setup Guide The FTPD-1 is designed to be used with FTDI’s microcontroller chips for firmware programming and debugging purposes. It allows direct connection with FT51A module s such as UMFT51A-EVM and UMFT51AA, with the 6-way ribbon cable assembly provide d in the package. 7.1 Connecting to MCU board Figure 4 - FTPD-1 connection to UMFT51A-EVM 9 C opyright © 2015 Future T echnology D evices I nternational L imited FTPD-1 FTDI Programmer Debugger 1 Module Datasheet Version 1.0 Document Ref erence No.: FT_001263 Clearance No.: FTDI# 480 Figure 5 - FTPD-1 connection to UMFT51AA-1 7.2 Connecting to PC The FTPD-1 has a mini-USB connector for the host connection. The first time the FTPD-1 module is connected to a Windows PC, the USB device drivers need to install. This should happen automatically if the PC is connected to the internet. Alternatively users can download the D2XX driver from the FTDI website and install the driver manually. Successful installation will result in a new device appearing in the Device manager under universal Serial Bus Controllers Figure 6 - FTPD-1 successful driver installation It is labelled “USB Serial Converter” – the text coming from the driver file. 10 C opyright © 2015 Future T echnology D evices I nternational L imited FTPD-1 FTDI Programmer Debugger 1 Module Datasheet Version 1.0 Document Ref erence No.: FT_001263 Clearance No.: FTDI# 480 8 Contact Information Head Office – Glasgow, UK Branch Office – Tigard, Oregon, USA Unit 1, 2 Seaward Place, Centurion Business Park Glasgow G41 1HH United Kingdom Tel: +44 (0) 141 429 2777 Fax: +44 (0) 141 429 2758 7130 SW Fir Loop Tigard, OR 97223 USA Tel: +1 (503) 547 0988 Fax: +1 (503) 547 0987 E-mail (Sales) E-mail (Support) E-mail (General Enquiries) E-Mail (Sales) E-Mail (Support) E-Mail (General Enquiries) sales1@ftdichip.com support1@ftdichip.com admin1@ftdichip.com Branch Office – Taipei, Taiwan 2F, No. 516, Sec. 1, NeiHu Road Taipei 114 Taiwan , R.O.C. Tel: +886 (0) 2 8797 1330 Fax: +886 (0) 2 8751 9737 E-mail (Sales) E-mail (Support) E-mail (General Enquiries) tw.sales1@ftdichip.com tw.support1@ftdichip.com tw.admin1@ftdichip.com us.sales@ftdichip.com us.support@ftdichip.com us.admin@ftdichip.com Branch Office – Shanghai, China Room 1103, No. 666 West Huaihai Road, Shanghai, 200052 C hina Tel: +86 (0)21 6235 1596 Fax: +86 (0)21 6235 1595 E-mail (Sales) E-mail (Support) E-mail (General Enquiries) cn.sales@ftdichip.com cn.support@ftdichip.com cn.admin@ftdichip.com Web Site http://ftdichip.com Distributor and Sales Representatives Please visit the Sales Network page of the FTDI Web site for the contact details of our distributor(s) and sales representative(s) in your country. Sys tem and equipment manufacturers and des igners are responsible to ens ure that their s ystems, and any Future T echnology D evi c es I nternational L td (FTDI) devices incorporated in their s ys tems , meet all applic able s afety, regulatory and s ys tem- level performanc e requirements. A ll application-related information in this doc ument (inc luding application descriptions, s uggested FTD I devices and other materials ) is provided for referenc e only. While FT DI has taken c are to as s ure it is ac c urate, this information is s ubjec t to c us tomer c onfirmation, and FT DI disclaims all liability for s ys tem des igns and for any applic ations as s is tanc e provided by FT D I . U s e o f FT D I devic es in life s upport and/or s afety applic ations is entirely at the us er’s ris k, a nd the us er agrees to defend, indemnify and hold harmles s FTDI from any and all damages , c laims, s uits or expense resulting from s uc h us e. T his document is s ubject to c hange without notic e. N o freedom to us e patents or other intellectual property rights is implied by the public ation of this doc ument. N either the whole nor any part of the information c ontained in, or the produc t des cribed in this document, may be adapted or reproduc ed in any material or elec tronic form without the prior written c ons ent of th e c opyright holder. Future T ec hnology D evic es I nternational L td, U nit 1 , 2 Seaward P lac e, C enturion Busines s P ark, G las gow G 4 1 1 H H , U nited Kingdom. Sc otland Regis tered C ompany N umber: SC 1 3 6 6 4 0 11 C opyright © 2015 Future T echnology D evices I nternational L imited FTPD-1 FTDI Programmer Debugger 1 Module Datasheet Version 1.0 Document Ref erence No.: FT_001263 Clearance No.: FTDI# 480 Appendix A – List of Figures and Tables List of Figures Figure 1 – Module Pin Out ...................................................................................................................... 5 Figure 2 – FTPD-1 Module Dimensions .................................................................................................... 7 Figure 3 – Module Circuit Schematic ....................................................................................................... 8 Figure 4 - FTPD-1 connection to UMFT51A-EVM ...................................................................................... 9 Figure 5 - FTPD-1 connection to UMFT51AA-1 ....................................................................................... 10 Figure 6 - FTPD-1 successful driver installation ..................................................................................... 10 List of Tables Table 1 - Module Pin Out Description ...................................................................................................... 6 Table 2 - Upstream USB Port Pin Out Description .................................................................................... 6 Copyright © 2015 Future Technology Devices International Limited 12 FTPD-1 FTDI Programmer Debugger 1 Module Datasheet Version 1.0 Document Ref erence No.: FT_001263 Clearance No.: FTDI# 480 Appendix B – Revision History Document Title: FTPD-1 FTDI Programmer Debugger 1 Module Datasheet Document Reference No.: FT_001263 Clearance No.: FTDI# 480 Product Page: http://www.ftdichip.com Document Feedback: Send Feedback Revision Version 1.0 Changes Date Initial Release Copyright © 2015 Future Technology Devices International Limited 2015-12-07 13
FTPD-1 价格&库存
很抱歉,暂时无法提供与“FTPD-1”相匹配的价格&库存,您可以联系我们找货
