ME817EV
ME817EV
    BRIDGETEK
    BT817 LCD 控制器 显示 评估板
ME817EV 数据手册
ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 Bridgetek Pte Ltd ME817EV BT817 Evaluation Board Datasheet 1 Introduction The ME817EV is a customer evaluation board for Bridgetek’s 4th generation EVE chip, BT817. The ME817EV is used to develop and demonstrate BT817’s graphics, touch and audio functionalities. The board is capable of supporting LCD panels with 40-pin LVDS interface, or 50-pin RGB interface. Backlight LED current can be adjusted using dip switches. Capacitive touch screens can be connected to the board through a 10-pin or 6pin FPC connector. An Audio filter and amplifier are included on-board, allowing a 1/8W speaker to be driven. Audio source can be supplied from the BT817, or through a line-in connector. The ME817EV board supports 2 types of host controller: MCU with SPI/QSPI master, or USB host, selectable through dip switches. The SPI option of the board behaves as a SPI slave, and requires a SPI Master for proper micro-controller interfacing and system integration. The USB option of the board behaves as a USB High-speed device using the FTDI FT4222H, and requires control from a USB host through the Type-C connector. For a full list of the BT817’s features, refer to the BT817_8 Datasheet. 1.1 Features The ME817EV has the following features:  Supports 40-pin LVDS display up to 1280x800  Supports 50-pin RGB display up to 1024x600  Trimmable on board LCD biasing voltages  On board LCD backlight LED Driver  On board audio power amplifier and audio connector for external speaker support  On board 16Mbyte NOR Flash Memory  10-pin or 6-pin FPC connector for capacitive touch screen  Supports SPI host interface through 2x8 pin header or 20pin FPC connector  Supports FT4222H  5V power supply via SPI host connector, or via USB Type-C port USB High-speed connection with Neither the whole nor any part of the information contained in, or the product described in this manual, may be adapted or reproduced in any material or electronic form without the prior written consent of the copyright holder. This product and its documentation are supplied on an as-is basis and no warranty as to their suitability for any particular purpose is either made or implied. Bridgetek Pte Ltd will not accept any claim for damages howsoever arising as a result of use or failure of this product. Your statutory rights are not affected. This product or any variant of it is not intended for use in any medical appliance, device or system in which the failure of the product might reasonably be expected to result in personal injury. This document provides preliminary information that may be subject to change without notice. No freedom to use patents or other intellectual property rights is implied by the publication of this document. Bridgetek Pte Ltd, 178 Paya Lebar Road, #07-03, Singapore 409030. Singapore Registered Company Number: 201542387H Copyright © Bridgetek Pte Ltd ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 2 Ordering Information Part No. ME817EV Part No. MM900EV, MM930Lite, MM932LC CleO-SPK1 Copyright © Bridgetek Pte Ltd Description BT817 customer evaluation board Table 2-1 – Ordering information Description FT9xx Development module Accessory - CleO speaker enclosure with connecting wires Table 2-2 – Accessories 2 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 Table of Contents 1 Introduction .................................................................... 1 1.1 Features .................................................................................... 1 2 Ordering Information ...................................................... 2 3 Hardware Description ..................................................... 4 3.1 ME817EV board ......................................................................... 4 3.2 Physical Descriptions ................................................................ 5 3.2.1 PCB layout ................................................................................................ 5 3.2.2 ME817EV Connectors ................................................................................. 6 4 Board Schematics .......................................................... 11 5 Hardware Setup ............................................................ 14 5.1 Power Configuration ............................................................... 14 5.2 Backlight LED current Configuration ....................................... 14 5.3 Compatible LCD panel ............................................................. 14 5.4 Hardware Setup Example 1: MM900EV with 7” LCD ................ 15 5.5 Hardware Setup Example 2: FT4222 with 10.1” LCD ............... 17 6 Mechanical Dimensions ................................................. 19 7 Specifications ................................................................ 20 7.1 8 Electrical Specification ............................................................ 20 Contact Information ...................................................... 21 Appendix A – References ................................................... 19 Document References ..................................................................... 19 Acronyms and Abbreviations ........................................................... 19 Appendix B - List of Figures and Tables ............................. 20 List of Figures ................................................................................. 20 List of Tables ................................................................................... 20 Appendix C – Revision History ........................................... 21 Copyright © Bridgetek Pte Ltd 3 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 3 Hardware Description Please refer to section 3.2.2 for connector settings. Some ME817EV jumpers must be set to work properly with your system. 3.1 ME817EV board Figure 3-1 – ME817EV board top view Figure 3-2 – ME817EV board bottom view The main functions of the ME817EV are as follows:            USB Type-C or SPI connector for power supply 3.3V regulator. Takes 5V input and outputs 3.3V for on-board circuits AVDD/VGH/VGL/VCOM biasing voltages for LCD power LCD backlight driver. Drive current 120mA – 280mA with over voltage protection (OVP) of 35V 3 stage audio filter and power amplifier Audio connector for external speaker and audio line in 10-pin and 6-pin FPC connector for capacitive touch screen On board 16M byte SPI NOR flash memory FT4222H USB to QSPI master bridge 2x8 pin header for MM900 series microcontroller modules or generic MCU 20-pin 1.0mm FPC connector for generic MCU Copyright © Bridgetek Pte Ltd 4 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 3.2 Physical Descriptions 3.2.1 PCB layout The ME817EV is a 160mm x 100mm, four-layer printed circuit board. Board thickness is approximately 1.6mm. Figure 3-3 – ME817EV board top layer Figure 3-4 – ME817EV board bottom layer Copyright © Bridgetek Pte Ltd 5 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 3.2.2 ME817EV Connectors Connectors and jumpers are described in the following sections.  JP1 – Power source select for the board JP1 is the jumper option for users to select the 5V power supply source for the board. Pin Option Description OPEN 1-2 SHORT 2-3 SHORT  5V Power from CN6 USBC1 VBUS 5V Power from CN11 USBC2 VBUS (CN6 must not connect) 5V Power from CN7 or CN8 5V_HOST (CN6 must not connect) Table 3-1 – JP1 Pin options JP2 – Power source select for the 40-pin LVDS panel JP2 is the jumper option for users to select the 2.5V/3.3V power supply for the 40-pin LVDS panel (CN9). Pin Option 1-2 SHORT 2-3 SHORT  Description Select 2.5V power supply Select 3.3V power supply Table 3-2 – JP2 Pin options CN1 – 50-pin RGB LCD Flex Cable connector, 0.5mm, bottom contact This connector is the interface between the BT817 IC and the LCD Module. Compatible with many LCD panels with 50-pin RGB interface such as the Riverdi RiTFT-70H. Pin No. 1-2 3-4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 Name LEDA LEDK GND VCOM DVDD MODE DE VS HS B7 B6 B5 B4 B3 B2 B1 B0 G7 G6 G5 G4 G3 G2 G1 G0 R7 R6 Copyright © Bridgetek Pte Ltd Type P P P P P O O O O O O O O O O O O O O O O O O O O O O Description Power for LED backlight (Anode) Power for LED backlight (Cathode) Ground Common voltage Power for digital circuit, 3.3V DE/SYNC mode select Data enable Vertical Sync Horizontal Sync RGB Blue data RGB Blue data RGB Blue data RGB Blue data RGB Blue data RGB Blue data RGB Blue data RGB Blue data RGB Green data RGB Green data RGB Green data RGB Green data RGB Green data RGB Green data RGB Green data RGB Green data RGB Red data RGB Red data 6 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 Pin No. 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50  Name R5 R4 R3 R2 R1 R0 GND DCLK GND L/R U/D VGH VGL AVDD DISP NC VCOM NC GND NC NC Type Description O RGB Red data O RGB Red data O RGB Red data O RGB Red data O RGB Red data O RGB Red data P Ground O Pixel clock P Ground O Left/Right selection O Up/Down selection P Gate ON Voltage P Gate OFF Voltage P Power for analog circuits O LCD Enable No connection P Common voltage No connection P Ground No connection No connection Table 3-3 – CN1 Pinout CN2 – FPC-10 0.5mm connector, top contact This connector is for the capacitive touch panel connection. Compatible with 7” Riverdi touch panels. Pin No. 1 2 3 4 5 6 7 8 9 10  Name VSS VDD SCL NC SDA NC RST# WAKE# INT# VSS Type Description P Ground P 3.3V power supply I/O I2C SCL line NA No connection I/O I2C SDA line NA No connection I/O Touch reset I/O Pull-up to 3.3V with 3.3K resistor I/O Touch interrupt P Ground Table 3-4 – CN2 Pinout CN4 – Audio connector ME817EV supports mono audio output through CN4. A ready-made speaker module (CleO-SPK1) is available from Bridgetek. Visit Bridgetek’s on-line shop for more information. Pin No. 1 2 3 4 Name SPSP+ AGND LINE_IN Copyright © Bridgetek Pte Ltd Type Description O Audio speaker out negative O Audio speaker out positive P Audio Ground I External audio line in Table 3-5 – CN4 Pinout 7 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157  CN6 – USB Type-C receptacle USB 5V power input. Type-C 5V/1.5A sink. Pin No. A4,B4,A9,B9 A1, B1, A12, B12 A5 B5  Name VBUS GND CC1 CC2 Type P P I/O I/O Table 3-6 – CN6 Description 5V power input Ground USB CC1 line, 5.1K pull down resistor. USB CC2 line, 5.1K pull down resistor. Pinout CN7 and CN8 - SPI host interface This is the interface where the SPI control and data signals are routed. There are also power and ground pins on this interface. CN8 is a 2x8 pin header, compatible with the Bridgetek MM900 series modules. CN7 is a 20-pin FPC connector which can be used to connect to the MCU board through an FPC cable.  Pin No (CN8) Pin No (CN7) Name Type 1 2 3 4 5 6 7-8 9 10 11 12 18 15 17 16 9 10 11-12 5,20 3,4 1,2 6,19 MA_SCK MA_CS# MA_MISO MA_MOSI MA_IO3 MA_IO2 NC NC 5V_HOST GND GND 13 13 I I I/O I/O I/O I/O P P P I 14 14 15 16 - 8 7 Description SPI clock input SPI chip select, active low SPI master input, slave output or Quad SPI IO1 SPI master output, slave input or Quad SPI IO0 GPIO1 or Quad SPI IO3 GPIO0 or Quad SPI IO2 No connection No connection 5V power supply Ground Ground Powers down and reset input, active low. Connect MA_PD# to 3.3V if not used. O Interrupts output, active low. On board 4.7kΩ pullMA_INT# up to 3.3V. AUDIO_L O AUDIO_L output from BT817 NC No connection GPIO3 I/O GPIO3 pin of BT817 Table 3-7 – CN7 & CN8 Pinout CN9 – 40-pin LVDS LCD Flex Cable connector, 0.5mm, top contact This connector is the interface between the RGB-LVDS converter IC and the LCD Module. Compatible with many LCD panels with 40-pin LVDS interface such as the A-TOPS AT-T101QIH. Pin No. 1 2-3 4 5 6 7 8 9 10 11 Name VCOM VDD GND DISP STDBY GND TX0_N TX0_P GND TX1_N Copyright © Bridgetek Pte Ltd Type P P P O O P O O P O Description Common voltage Power supply, 2.5V or 3.3V Ground Display enable Standby mode, pulled-high Ground LVDS data output LVDS data output Ground LVDS data output 8 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 Pin No. 12 13 14 15 16 17 18 19 20 21 22 23-24 25 26-27 28 29 30 31-32 33 34 35 36-37 38 39-40  Name TX1_P GND TX2_N TX2_P GND TXCLK_N TXCLK_P GND TX3_N TX3_P GND NC GND NC SELB AVDD GND LEDK L/R U/D VGL NC VGH LEDA Type O P O O P O O P O O P P O P P P O O P P P Description LVDS data output Ground LVDS data output LVDS data output Ground LVDS clock output LVDS clock output Ground LVDS data output LVDS data output Ground No connection Ground No connection Select 6/8 bit mode. Pulled-low Power for analog circuits Ground Power for LED backlight (Cathode) Left/Right selection, pulled-high Up/Down selection, pulled-low Gate OFF Voltage No connection Gate ON Voltage Power for LED backlight (Anode) Table 3-8 – CN9 Pinout CN10 – FPC-10 0.5mm connector, bottom contact This connector is for capacitive touch panel connection. Compatible with 10.1” Microtech touch panels. Pin No. Name Type 1-4 5 6 7 8 9 10 NC RST# INT# SCL SDA GND VCC NA I/O I/O I/O I/O P P Description No connection Touch reset Touch interrupt I2C SCL line I2C SDA line Ground 3.3V power supply Table 3-9 – CN10 Pinout  CN11 – USB Type-C receptacle USB data and 5V power input. Type-C 5V/1.5A sink. Pin No. Name Type A4,B4,A9,B9 A1, B1, A12, B12 A6, B6 A7, B7 A5 B5 VBUS GND D+ DCC1 CC2 P P I/O I/O I/O I/O Description 5V power input Ground USB D+ data line USB D- data line USB CC1 line, 5.1K pull down resistor. USB CC2 line, 5.1K pull down resistor. Table 3-10 – CN11 Pinout Copyright © Bridgetek Pte Ltd 9 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157  CN12 – FPC-10 0.5mm connector, bottom contact This connector is for the capacitive touch panel connection. Compatible with 10.1” A-TOPS touch panels. Pin No. 1-2 3-4 5 6 7 8 9-10  Name GND VCC SCL SDA RST# INT# GND Type Description P Ground P 3.3V power supply I/O I2C SCL line I/O I2C SDA line I/O Touch reset I/O Touch interrupt P Ground Table 3-11 – CN12 Pinout CN13 – Backlight LED connector This connector is for the Backlight LED connection. Pin No. Name Type 1 2 LEDA LEDK P P Description Power for LED backlight (Anode) Power for LED backlight (Cathode) Table 3-12 – CN13 Pinout  CN14 – FPC-6 0.5mm connector, bottom contact This connector is for the capacitive touch panel connection. Compatible with 10.1” TSD touch panels. Pin No. 1 2 3 4 5 6 Name SDA SCL RST# INT# GND VDD Copyright © Bridgetek Pte Ltd Type Description I/O I2C SDA line I/O I2C SCL line I/O Touch reset output I/O Touch interrupt input P Ground P 3.3V power supply Table 3-13 – CN14 Pinout 10 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 4 Board Schematics Figure 4-1 - BT817 IC and RGB Connector Figure 4-2 - FT4222 USB Bridge Circuit Copyright © Bridgetek Pte Ltd 11 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 Figure 4-3 - Host Interface Connectors Figure 4-4 - RGB to LVDS converter Copyright © Bridgetek Pte Ltd 12 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 Figure 4-5 - LCD Biasing Voltages Figure 4-6 - Power and Audio Circuits Copyright © Bridgetek Pte Ltd 13 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 5 Hardware Setup 5.1 Power Configuration There are 3 methods of powering the ME817EV board. 1) PC USB port Power(5V) - Connect to PC via Type-C cable to CN11 2) USBC charger Power(5V) - Connect USB charger with Type-C cable to CN6 3) Power from MCU host board(5V) - Connect 5V to CN8 pin 10 or CN7 pin 3&4 The following table summarises how to power the ME817EV board using the various methods. Power Method CN11 CN6 Must not connect PC USB port power (5V) 5V USBC charger power (5V) Don’t care CN8 Pin 10 (or CN7 pin3&4) JP1 Don’t care Short pin 1-2 5V Don’t care Must not MCU host board power (5V) Don’t care connect 5V Table 5-1 – Board power configuration open Short pin 2-3 5.2 Backlight LED current Configuration The ME817EV module has a backlight LED driver circuit on-board. The driver takes 5V as an input power source, and the regulator produces the output voltage so that the desired total output current can be drawn by the backlight LED. Users can select backlight current up to a maximum of 280mA via dip switch SW1. By default, with all the 4 switches in SW1 turned OFF, resistor R44 (2.4 Ohm) is setting the minimum backlight current at 120mA. The switches in S12 are connected to array resistor RP9 (4 x 7.5 Ohm). Turning ON each switch will provide an additional backlight current of 40mA per switch. Backlight LED array Vled voltage Vled current SW1 Number of ON position 6x6 19.2V 120mA 0 8x3 9.6V 160mA 1 10 x 3 9.6V 200mA 2 12 x 3 9.6V 240mA 3 14 x 3 Comment 9.6V 280mA 4 Table 5-2 – Backlight LED configuration 5.3 Compatible LCD panel The ME817EV supports 2 types of LCD interface: 1. LVDS panel with 40-pin 0.5mm FPC cable or connector 2. RGB panel with 50-pin 0.5mm FPC cable or connector Table 5-3 lists a few LCD panels which have been tested as working with the ME817EV board. Vendor Part No Size Resolution Riverdi RiTFT-70H-CAP 7” 1024x600 EastRising ER-TFT101-1 10.1” 1024x600 A-TOPS AT-T101QIH-48CP 10.1” 1280x800 Copyright © Bridgetek Pte Ltd Display Interface Cap Touch IC /Connector RGB-50 RGB-50 FT5426/CN2 LVDS-40 GT928/CN12 - 14 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 Vendor Microtech Part No Size Resolution MTF101IA-01D(TFT) MTP101GGY-01(CTP) 10.1” 1280x800 Table 5-3 – Compatible LCD list Display Interface Cap Touch IC /Connector LVDS-40 GT928/CN10 5.4 Hardware Setup Example 1: MM900EV with 7” LCD This example uses a Riverdi 7” TFT with CTP (RiTFT-70H-CAP) for display and touch functions. The host controller will utilize Bridgetek’s MM900EV module built with FT900 32-bit MCU controller. The RiTFT-70H-CAP outline size is the same as the ME817EV PCB. It is possible to put the LCD and PCB together back-to-back to form a display module assembly. Hardware Setup          Plug the USB Type-C cable into the CN6-USBC1 connector, with the other end plugged to a USB power source (at least 1.5A current rating) Trim variable resistors VR1-VR4 to get required LCD biasing voltages as: AVDD=9.6V, VGL=-6V, VGH=18V, VCOM=3.8V. Un-plug the USB Type-C cable to remove the power Connect the LCD display 50-pin FPC cable to CN1 Connect the LCD touch 10-pin FPC cable to CN2 On SW2, set all 8 positions to OFF. On SW1, set SW1-1 to ON, SW1-2/3/4 to OFF Set JP1 to short pin2-3 Connect the MM900EV module to CN8. A UMFTPD2A programming/debug module is also recommended for programming the FT900. Plug the USB Type-C cable to turn on the power Software Setup    Download EVE Toolchains at https://brtchip.com/eve-toolchains/ . Download EVE sample applications at https://brtchip.com/SoftwareExamples-eve/ . Launch the Sample Application based on FT900 platform. The BT81X Programming Guide describes the programming code and formats used by the BT81X. The Sample Application is a well-formatted and documented program that illustrates the Programming Guide, and provides numerous design examples and reference code demonstrations. Copyright © Bridgetek Pte Ltd 15 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 Figure 5-1 – MM900 setup with 7” 1024x600 panel Figure 5-2 – 7” Module assembly Copyright © Bridgetek Pte Ltd 16 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 5.5 Hardware Setup Example 2: FT4222 with 10.1” LCD This example uses an A-TOPS 10.1” 1280x800 TFT with CTP (AT-T101QIH-48CP) for display and touch functions. The host will be PC, connected by utilizing the on-board FTDI FT4222H USB to QSPI bridge. Hardware Setup         On SW2, set all 8 positions to ON. On SW1, set all 4 positions to OFF Set JP1 to short pin1-2 Plug the USB Type-C cable to CN11-USBC2 connector, with the other end plugged to PC USB port (at least 1.5A current rating). Trim variable resistors VR1-VR4 to get required LCD biasing voltages as: AVDD=8.2V, VGL=-7V, VGH=22V, VCOM=3.3V. Un-plug the USB Type-C cable to remove the power Connect the LCD display 40-pin FPC connector to CN9 through 40-pin FPC cable Connect the LCD touch 10-pin FPC cable to CN12 Plug the USB Type-C cable to turn on the power Software Setup   Follow section 5.4 to download EVE toolchain and sample application. When re-compiling the sample application, select EVE_GRAPHICS_ME817EV in the Processor Definitions of SampleApp MSVC Property Pages, as shown in the screenshot below. For more details, please refer to the user manual of EveApps. Figure 5-3 – EveApps configuration for ME817EV Copyright © Bridgetek Pte Ltd 17 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 Figure 5-4 - PC setup with 10.1” 1280x800 panel Copyright © Bridgetek Pte Ltd 18 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 6 Mechanical Dimensions Figure 6-1 – PCB Mechanical Dimensions Copyright © Bridgetek Pte Ltd 19 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 7 Specifications 7.1 Electrical Specification Parameter VCC_5V Icc1_5V Icc2_5V Icc3_5V Voh Vol Vih Vil Description Minimum Typical Maximum Units 5V supply voltage 4. 5 5.0 5. 5 V VCC=5V operating 200 mA current VCC=5V operating 950 mA current VCC=5V operating 1200 mA current Output Voltage 2.4 V High Output Voltage 0.4 V Low Input High Voltage 2.0 5.25 V Input Low Voltage 0.8 V Table 7-1 - Operating Voltage and Current Copyright © Bridgetek Pte Ltd Notes Without LCD/speaker With 7” LCD and 1/8W speaker With 10.1” LCD and 1/8W speaker 20 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 8 Contact Information Head Quarters – Singapore Branch Office – Taipei, Taiwan Bridgetek Pte Ltd 178 Paya Lebar Road, #07-03 Singapore 409030 Tel: +65 6547 4827 Fax: +65 6841 6071 Bridgetek Pte Ltd, Taiwan Branch 2 Floor, No. 516, Sec. 1, Nei Hu Road, Nei Hu District Taipei 114 Taiwan, R.O.C. Tel: +886 (2) 8797 5691 Fax: +886 (2) 8751 9737 E-mail (Sales) E-mail (Support) E-mail (Sales) E-mail (Support) sales.apac@brtchip.com support.apac@brtchip.com sales.apac@brtchip.com support.apac@brtchip.com Branch Office - Glasgow, United Kingdom Branch Office – Vietnam Bridgetek Pte. Ltd. Unit 1, 2 Seaward Place, Centurion Business Park Glasgow G41 1HH United Kingdom Tel: +44 (0) 141 429 2777 Fax: +44 (0) 141 429 2758 Bridgetek VietNam Company Limited Lutaco Tower Building, 5th Floor, 173A Nguyen Van Troi, Ward 11, Phu Nhuan District, Ho Chi Minh City, Vietnam Tel : 08 38453222 Fax : 08 38455222 E-mail (Sales) E-mail (Support) E-mail (Sales) E-mail (Support) sales.emea@brtichip.com support.emea@brtchip.com sales.apac@brtchip.com support.apac@brtchip.com Web Site http://brtchip.com/ Distributor and Sales Representatives Please visit the Sales Network page of the Bridgetek Web site for the contact details of our distributor(s) and sales representative(s) in your country. System and equipment manufacturers and designers are responsible to ensure that their systems, and any Bridgetek Pte Ltd (BRT Chip) devices incorporated in their systems, meet all applicable safety, regulatory and system-level performance requirements. All application-related information in this document (including application descriptions, suggested Bridgetek devices and other materials) is provided for reference only. While Bridgetek has taken care to assure it is accurate, this information is subject to customer confirmation, and Bridgetek disclaims all liability for system designs and for any applications assistance provided by Bridgetek. Use of Bridgetek devices in life support and/or safety applications is entirely at the user’s risk, and the user agrees to def end, indemnify and hold harmless Bridgetek from any and all damages, claims, suits or expense resulting from such use. This document is subject to change without notice. No freedom to use patents or other intellectual property rights is implied by the publ ication of this document. Neither the whole nor any part of the information contained in, or the product described in this document, may be adapted or reproduced in any material or electronic form without the prior written consent of the copyright holder. Bridgetek Pte Ltd, 178 Paya Lebar Road, #07-03, Singapore 409030. Singapore Registered Company Number: 201542387H. Copyright © Bridgetek Pte Ltd 21 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 Appendix A – References Document References http://brtchip.com/m-eve4/ BT817_8 Datasheet BT81X Programming Guide FT9xx Modules Acronyms and Abbreviations Terms Description EVE Embedded Video Engine LCD Liquid Crystal Display PC Personal Computer SPI Serial Peripheral Interface TFT Thin Film Transistor USB Universal Serial Bus Copyright © Bridgetek Pte Ltd 19 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 Appendix B - List of Figures and Tables List of Figures Figure 4-1 - BT817 IC and RGB Connector .................................................................................. 11 Figure 4-2 - FT4222 USB Bridge Circuit ...................................................................................... 11 Figure 4-3 - Host Interface Connectors ...................................................................................... 12 Figure 4-4 - RGB to LVDS converter .......................................................................................... 12 Figure 4-5 - LCD Biasing Voltages ............................................................................................. 13 Figure 4-6 - Power and Audio Circuits ........................................................................................ 13 Figure 5-1 – MM900 setup with 7” 1024x600 panel ...................................................................... 16 Figure 5-2 – 7” Module assembly .............................................................................................. 16 Figure 5-3 – EveApps configuration for ME817EV ......................................................................... 17 Figure 5-4 - PC setup with 10.1” 1280x800 panel ........................................................................ 18 Figure 6-1 – PCB Mechanical Dimensions .................................................................................... 19 List of Tables Table 2-1 – Ordering information ................................................................................................ 2 Table 3-1 – JP1 Pin options ........................................................................................................ 6 Table 3-2 – JP2 Pin options ........................................................................................................ 6 Table 3-3 – CN1 Pinout ............................................................................................................. 7 Table 3-4 – CN2 Pinout ............................................................................................................. 7 Table 3-5 – CN4 Pinout ............................................................................................................. 7 Table 3-6 – CN6 Pinout ............................................................................................................. 8 Table 3-7 – CN7 & CN8 Pinout .................................................................................................... 8 Table 3-8 – CN9 Pinout ............................................................................................................. 9 Table 3-9 – CN10 Pinout............................................................................................................ 9 Table 3-10 – CN11 Pinout .......................................................................................................... 9 Table 3-11 – CN12 Pinout ........................................................................................................ 10 Table 3-12 – CN13 Pinout ........................................................................................................ 10 Table 3-13 – CN14 Pinout ........................................................................................................ 10 Table 5-1 – Board power configuration ....................................................................................... 14 Table 5-2 – Backlight LED configuration ..................................................................................... 14 Table 5-3 – Compatible LCD list ................................................................................................ 15 Table 7-1 - Operating Voltage and Current ................................................................................. 20 Copyright © Bridgetek Pte Ltd 20 ME817EV BT817 Evaluation Board Datasheet Version 1.0 Document No.: BRT_000325 Clearance No.: BRT#157 Appendix C – Revision History Document Title: ME817EV BT817 Evaluation Board Datasheet Document Reference No.: BRT_000325 Clearance No.: BRT#157 Product Page: http://brtchip.com/m-eve4/ Document Feedback: Send Feedback Revision Changes Date 1.0 Initial Release 11-11-2020 Copyright © Bridgetek Pte Ltd 21
ME817EV 价格&库存
很抱歉,暂时无法提供与“ME817EV”相匹配的价格&库存,您可以联系我们找货
ME817EV
  • 1+1006.68480
  • 5+986.55486
库存:1
ME817EV
  • 1+1187.947461+153.98061
