UMFT51AA
UMFT51AA
    BRIDGETEK
    FT51A EVAL BRD
UMFT51AA 数据手册
UMFT51AA-01 Datasheet Version 1.0 Document Ref erence No.: FT_001141 Clearance No.: FTDI# 479 Future Technology Devices International Datasheet UMFT51AA 8051 Compatible Module UMFT51AA is an FT51A DIP module that is compatible with an 8051 microcontroller. 1 Introduction The UMFT51AA is a development module for FTDI’s FT51AQ, one of the devices from FTDI’s range of microcontrollers with USB interface bridging features integrated. FT51A is a MCU series which includes the following features: USB client and USB hub interfaces, 8051 core, 8-bit ADC, UART, SPI, I2C, 245 FIFO and PWM. The UMFT51AA is a module which is designed to plug into a standard 0.6” wide 40 pin DIP socket. 1.1 Features The UMFT51AA is built with a FT51AQ; many of the features of the FT51AQ can be utilized with this module. For a full list of the FT51A’s series features refer to the FT51A datasheet which can be found by clicking here. In addition to the features listed in the FT51A datasheet, the UMFT51AA has the following features:  PCB assembly module is designed to fit a standard 15.24mm (0.6”) wide 40 pin DIP socket. Pins are on a 2.54mm (0.1”) pitch. This module is a drop in replacement for an 8051 microcontroller.  An on board USB type A socket and plug allow modules to be connected to a PC via a standard A extension cable or directly. This module is also capable of cascading several modules by utilizing the USB hub feature.  Debugger interface header used for debugging and programming the FT51AQ. Designed for operation with the FTPD-1 programmer / debugger module. See the FTPD-1 datasheet for details about this module.  Onboard jumper for configuring the FT51AA to be in self powered or USB powered modes. All components used, including the FT51AQ are Pbfree (RoHS compliant). N either the whole nor any part of the information c ontained in, or the produc t des c ribed in this manual, may be adapted or reproduc ed in any material or elec tronic form without the prior written c ons ent of the c opyright holder. T his produc t and its doc umentation are s upplied on an as - is basis and no warranty as to their s uitability for any partic ular purpos e is either made or implied. Future T ec hnology D evices I nternational L td will not ac c ept any c laim for damages hows oever arising as a res ult of us e or failure of this produc t. Y our s tatutory rights are not affec ted. T his produc t or any variant of it is not intended for us e in any medic al appliance, device or s ystem in whic h the fail ure of the produc t might reas onably be expected to res ult in pers onal injury. T his doc ument provides preliminary information that may be s ubject to c hange without notice. N o freedom to us e patents or oth er intellectual property rights is implied by the pub lication of this doc ument. Future T echnology D evic es I nternational L td, U nit 1 , 2 Seaward P lac e, C enturion Business P ark, G lasgow G 4 1 1HH U nited Kingdom. Sc otland Registered C ompany N umber: SC 1 3 6 6 4 0 Copyright © 2015 Future Technology Devices International Limited 1 UMFT51AA-01 Datasheet Version 1.0 Document Ref erence No.: FT_001141 Clearance No.: FTDI# 479 Table of Contents 1 Introduction ................................................................. 1 1.1 Features ................................................................................ 1 2 Driver Support .............................................................. 3 3 Ordering Information .................................................... 4 4 UMFT51AA Signals and Configurations ........................... 5 4.1 UMFT51AA Pin Out ................................................................. 5 4.2 Signal Descriptions ................................................................ 6 4.3 I/O Pin Feature Options ......................................................... 8 5 Module Configurations .................................................. 9 5.1 Jumper Configuration Options ................................................ 9 5.2 Programming Firmware to the Flash ROM ............................... 9 6 Module Dimensions ..................................................... 10 7 UMFT51AA Module Circuit Schematic ........................... 11 8 Contact Information .................................................... 13 Appendix A – References ................................................. 14 Document References ...................................................................14 Acronyms and Abbreviations .........................................................14 Appendix B – List of Figures and Tables............................ 15 List of Figures ...............................................................................15 List of Tables ................................................................................15 Appendix C – Revision History.......................................... 16 Copyright © 2015 Future Technology Devices International Limited 2 UMFT51AA-01 Datasheet Version 1.0 Document Ref erence No.: FT_001141 Clearance No.: FTDI# 479 2 Driver Support Driver support for the FT51A USB Device Firmware Updater (DFU) is available as part of the FT51A SDK and is available for the following OS:  Windows 10 32,64-bit  Windows 8.1 32,64-bit  Windows 8 32,64-bit  Windows 7 32,64-bit  Linux 3.0 and greater Copyright © 2015 Future Technology Devices International Limited 3 UMFT51AA-01 Datasheet Version 1.0 Document Ref erence No.: FT_001141 Clearance No.: FTDI# 479 3 Ordering Information Module Code Utilised IC Code Description UMFT51AA-01 FT51AQ 8051 compatibility module. Other modules in the FT51A range: Module Code Utilised IC Code Description UMFT51-EVM FT51AQ FT51A demonstration platform. Copyright © 2015 Future Technology Devices International Limited 4 UMFT51AA-01 Datasheet Version 1.0 Document Ref erence No.: FT_001141 Clearance No.: FTDI# 479 4 UMFT51AA Signals and Configurations 4.1 UMFT51AA Pin Out (DIO0) P1.0 VCC P0.0 (AIO0) P0.1 (AIO1) (DIO1) P1.1 (DIO2) P1.2 (DIO3) P1.3 P0.2 (AIO2) (DIO4) P1.4 P0.3 (AIO3) (DIO5) P1.5 P0.4 (AIO4) (DIO6) P1.6 P0.5 (AIO5) (DIO7) P1.7 RST P0.6 (AIO6) P0.7 (AIO7) (DIO8) P3.0 (DIO9) P3.1 (DIO10) P3.2 (DIO11) P3.3 P2.7 (AIO15) (DIO12) P3.4 P2.6 (AIO14) (DIO13) P3.5 P2.5 (AIO13) (DIO14) P3.6 P2.4 (AIO12) (DIO15) P3.7 P2.3 (AIO11) P2.2 (AIO10) P2.1 (AIO9) Ground ` P2.0 (AIO8) Figure 4.1 – Module Pin Out Figure 4.1 illustrates the signals available on the DIL pins. The top image shows the pinout when the module is viewed from the top. The bottom image shows what signals are available when viewed from the bottom. Copyright © 2015 Future Technology Devices International Limited 5 UMFT51AA-01 Datasheet Version 1.0 Document Ref erence No.: FT_001141 4.2 Clearance No.: FTDI# 479 Signal Descriptions Pin No. Name Type Description Port 1 pins, P1.0 to P1.7 (DIO0 to DIO7). All FT51A C N1-1 to C N1-8 Port 1 I/O Signals digital functions can be mixed to these pins; however ADC features are not available for these pins. These pins are 5 volt tolerant. Port 3 pins, P3.0 to P3.7 (DIO8 to DIO15). All FT51A C N1-10 to C N1-17 Port 3 I/O Signals digital functions can be mixed to these pins; however ADC features are not available for these pins. These pins are 5 volt tolerant. Port 2 pins, P2.0 to P2.7 (AIO8 to AIO15). ADC features C N2-21 to C N2-13 Port 2 I/O Signals are available for these pins however these pins are not suitable for high frequency data transfers such as SPI. These pins are not 5 volt tolerant. Port 0 pins, P2.0 to P0.7 (AIO8 to AIO15). ADC features C N2-2 to C N2-9 Port 0 I/O Signals are available for these pins however these pins are not suitable for high frequency data transfers such as SPI. These pins are not 5 volt tolerant. C N1-9 RST Reset Pin Active high reset. C N1-20 GND Ground Ground 0 volts. C N2-1 VC C5V Power 5 volt power input when JP1 is open, 5 volt power output when JP1 is closed and connected to upstream USB port. C N1-18 to C N1-19 NC C N2-10 to C N2-12 NC Not C onnected Not C onnected Floating pin. Floating pin. Table 4.1 – Module Pin Out Description Pin No. Name Type Description C N4-1 VBUS Power 5 volt power input. To enable bus power mode close JP1 C N4-2 DM Signal USB Data - from upstream device C N4-3 DP Signal USB Data + from upstream device C N4-4 GND Ground 0 volt ground. Table 4.2 – Upstream USB Port Pin Out Description Copyright © 2015 Future Technology Devices International Limited 6 UMFT51AA-01 Datasheet Version 1.0 Document Ref erence No.: FT_001141 Pin No. Name Type Description C N5-1 VBUS Power 5 volt power output. C N5-2 DM Signal USB Data - to downstream device C N5-3 DP Signal USB Data + to downstream device C N5-4 GND Ground 0 volt ground. Clearance No.: FTDI# 479 Table 4.3 – Downstream USB Port Pin Out Description Pin No. Name Type Description C N3-1 and C N3-4 NC Not C onnected Floating pin. C N3-2 VC C5V Power 5 volt power input. (Protected by zenor diode.) C N3-3 RESET# Signal C N3-5 DBG Signal Debugger data line, single line half-duplex UART. C N3-6 GND Ground 0 volt ground. Active low reset input from the FTPD-1 debugger/programmer Table 4.4 – Debugger Port Pin Out Description Copyright © 2015 Future Technology Devices International Limited 7 UMFT51AA-01 Datasheet Version 1.0 Document Ref erence No.: FT_001141 Clearance No.: FTDI# 479 4.3 I/O Pin Feature Options The following features can be configured using the FT51A’s multiplexer to bring signal to the available pins. FT51A IO Signal Option Available On Pin Description GPIO DIO0-15 and AIO015 ADC AIO0-15 8-bit analog to digital converter UART DIO0-15 UART interface. Data rates up to 6 Mbaud. SPI Master DIO0-15 SPI master interface. Clock frequency up to 24MHz SPI Slave DIO0-15 SPI slave interface DIO0-15 8 bit parallel data interface with handshake. Data rates up to 7MB/s. I2C Master DIO0-15 I2C interface. Data rates up to 3.4Mb/s I2C Slave DIO0-15 I2C interface PWM DIO0-15 and AIO015 245 FIFO BCD Detect General purpose IO Pulse Width Modulation output. DIO0-15 and AIO0- Indicates a dedicated charger port has be detect on the 15 upstream USB port. Table 4.5 – I/O Signal Options Copyright © 2015 Future Technology Devices International Limited 8 UMFT51AA-01 Datasheet Version 1.0 Document Ref erence No.: FT_001141 Clearance No.: FTDI# 479 5 Module Configurations 5.1 Jumper Configuration Options Solder Setting Status Description JP1 Opened NonDefaul t Self-Powered mode. This setting removes the connection between VBUS and VCC5V. For self-powered operation 5V power is received from CN2-1. JP1 Closed Defaul t Link No. Bus-Powered mode. This setting creates a connection between VBUS and VCC5V. For bus-powered operations 5V power will be output on CN2-1 when the module is connected to an upstream USB port. Table 5.1 – Jumper JP1 Modes Warning: There should never be more than one power output supplying power to the same net at any one time. Closing JP1 will cause a direct short between two different power supplies, when a self-powered set-up is applied and the USB bus is connected resulting in the potential for damage to the module and other connected circuitry. 5.2 Programming Firmware to the Flash ROM The FT51A can be programmed using the FTPD-1. CN3 is a dedicated port that can interface with the FTPD-1. A list of available examples (at time of writing) is shown below and source code can be found in ‘C:\Users\Username\Documents\FTDI\FT51A_SDK\version\examples’ after installing the FT51A SDK:  AN_344_FT51A_DFU_Sample  AN_345 FT51A Keyboard Sample  AN_346 FT51A Mouse Sample  AN_347 FT51A Test and Measurement Sample  AN_348 FT51A FT800 Sensors Sample  AN_349 FT51A FT800 Spaced Invaders Sample  AN_351 FT51A Compatibility Module  AN_354 FT51A Standalone Demo Application Users can develop their own custom applications using the SDK. Copyright © 2015 Future Technology Devices International Limited 9 UMFT51AA-01 Datasheet Version 1.0 Document Ref erence No.: FT_001141 Clearance No.: FTDI# 479 6 Module Dimensions 18.45 83.13 68.38 57.53 2.54 9.28 7.88 15.24 Figure 6.1 – UMFT51AA Module Dimensions All dimensions are given in millimetres. The UMFT51AA module exclusively uses lead free components, and is fully compliant with European Union directive 2002/95/EC. Copyright © 2015 Future Technology Devices International Limited 10 UMFT51AA-01 Datasheet Version 1.0 Document Ref erence No.: FT_001141 Clearance No.: FTDI# 479 7 UMFT51AA Module Circuit Schematic Copyright © 2015 Future Technology Devices International Limited 11 UMFT51AA-01 Datasheet Version 1.0 Document Ref erence No.: FT_001141 Clearance No.: FTDI# 479 Figure 7.1 – Module Circuit Schematic Copyright © 2015 Future Technology Devices International Limited 12 UMFT51AA-01 Datasheet Version 1.0 Document Ref erence No.: FT_001141 Clearance No.: FTDI# 479 8 Contact Information Head Office – Glasgow, UK Branch Office – Tigard, Oregon, USA Unit 1, 2 Seaward Place, Centurion Business Park Glasgow G41 1HH United Kingdom Tel: +44 (0) 141 429 2777 Fax: +44 (0) 141 429 2758 7130 SW Fir Loop Tigard, OR 97223 USA Tel: +1 (503) 547 0988 Fax: +1 (503) 547 0987 E-mail (Sales) E-mail (Support) E-mail (General Enquiries) E-Mail (Sales) E-Mail (Support) E-Mail (General Enquiries) sales1@ftdichip.com support1@ftdichip.com admin1@ftdichip.com Branch Office – Taipei, Taiwan 2F, No. 516, Sec. 1, NeiHu Road Taipei 114 Taiwan , R.O.C. Tel: +886 (0) 2 8797 1330 Fax: +886 (0) 2 8751 9737 E-mail (Sales) E-mail (Support) E-mail (General Enquiries) tw.sales1@ftdichip.com tw.support1@ftdichip.com tw.admin1@ftdichip.com us.sales@ftdichip.com us.support@ftdichip.com us.admin@ftdichip.com Branch Office – Shanghai, China Room 1103, No. 666 West Huaihai Road, Shanghai, 200052 C hina Tel: +86 (0)21 6235 1596 Fax: +86 (0)21 6235 1595 E-mail (Sales) E-mail (Support) E-mail (General Enquiries) cn.sales@ftdichip.com cn.support@ftdichip.com cn.admin@ftdichip.com Web Site http://ftdichip.com Distributor and Sales Representatives Please visit the Sales Network page of the FTDI Web site for the contact details of our distributor(s) and sales representative(s) in your country. Sys tem and equipment manufacturers and des igners are responsible to ens ure that their s ystems, a nd any Future T echnology D evic es I nternational L td (FTDI) devices incorporated in their s ys tems , meet all applic able s afety, regulatory and s ys tem - level performanc e requirements. A ll application-related information in this doc ument (inc luding application d escriptions, s uggested FTD I devices and other materials ) is provided for referenc e only. While FT DI has taken c are to as s ure it is ac c urate, this information is s ubjec t to c us tomer c onfirmation, and FT DI disclaims all liability for s ys tem des igns and for a ny applic ations as s is tanc e provided by FT D I . U s e of FT D I devic es in life s upport and/or s afety applic ations is entirely at the us er’s ris k, and the us er agrees to defend, indemnify a nd hold harmles s FTDI from any and all damages , c laims, s uits or expense r esulting from s uc h us e. T his document is s ubject to c hange without notic e. N o freedom to us e patents or other intellectual property rights is implied by the public ation of this doc ument. N eith er the whole nor any part of the information c ontained in, or th e produc t des cribed in this document, may be adapted or reproduc ed in any material or elec tronic form without the prior written c ons ent of the c opyright holder. Future T ec hnology D evic es I nternational L td, U n it 1 , 2 Seaward P lac e, C enturion Busines s P ark, G las gow G 4 1 1 H H , U nited Kingdom. Sc otland Regis tered C ompany N umber: SC 1 3 6 6 4 0 Copyright © 2015 Future Technology Devices International Limited 13 UMFT51AA-01 Datasheet Version 1.0 Document Ref erence No.: FT_001141 Clearance No.: FTDI# 479 Appendix A – References Document References FT51A Datasheet AN_289 FT51A programmers Guide FTPD-1 Datasheet AN_344_FT51A_DFU_Sample AN_345_FT51A_Keyboard_Sample AN_346_FT51A_Mouse_Sample AN_347_FT51A_Test_and_Measurement_Sample AN_348_FT51A_FT800_Sensors_Sample AN_349_FT51A_FT800_Spaced_Invaders_Sample AN_352_FT51A_Installation_Guide Acronyms and Abbreviations Terms ADC Description Analog to digital conversion I2C Inter integrated Circuit LCD Liquid Crystal Display LED Light Emitting Diode MCU Micro Controller Unit SPI Serial Peripheral Interface USB Universal Serial Bus Copyright © 2015 Future Technology Devices International Limited 14 UMFT51AA-01 Datasheet Version 1.0 Document Ref erence No.: FT_001141 Clearance No.: FTDI# 479 Appendix B – List of Figures and Tables List of Figures Figure 4.1 – Module Pin Out ................................................................................................................... 5 Figure 6.1 – UMFT51AA Module Dimensions .......................................................................................... 10 Figure 7.1 – Module Circuit Schematic .................................................................................................. 12 List of Tables Table 4.1 – Module Pin Out Description................................................................................................... 6 Table 4.2 – Upstream USB Port Pin Out Description ................................................................................ 6 Table 4.3 – Downstream USB Port Pin Out Description ............................................................................ 7 Table 4.4 – Debugger Port Pin Out Description........................................................................................ 7 Table 4.5 – I/O Signal Options................................................................................................................ 8 Table 5.1 – Jumper JP1 Modes................................................................................................................ 9 Copyright © 2015 Future Technology Devices International Limited 15 UMFT51AA-01 Datasheet Version 1.0 Document Ref erence No.: FT_001141 Clearance No.: FTDI# 479 Appendix C – Revision History Document Title: UMFT51AA-01 Datasheet Document Reference No.: FT_001141 Clearance No.: FTDI# 479 Product Page: http://www.ftdichip.com Document Feedback: Send Feedback Revision Version 1.0 Changes Date Initial Release Copyright © 2015 Future Technology Devices International Limited 2015-11-18 16
UMFT51AA 价格&库存
很抱歉,暂时无法提供与“UMFT51AA”相匹配的价格&库存,您可以联系我们找货
