AA47F
AA47F
    TOWARD(拓纬)
    SMD6
    固态 SPST-NO(1 Form A) 6-SMD(0.300",7.62mm)
AA47F 数据手册
74 Hi-A Grade ≥ 1A 47 Series 80V/1.5A.1a/2a AEC-Q101 / Hi-Temp (105℃) Available Features RoHS Compliance Application ● Contact Form 1a / 2a ● Modem ● Load Voltage 80V ● Telephone Equipment ● Operation LED Current 3.0mA ● Security Equipment ● Load Current 1.5A ● Sensing Equipment ● On-Resistance 0.13Ω ● Automatic Test Equipment ● Output Capacitance 220pF ● I/O Modules ● Low Off-State Leakage Current 1.0µA ● Electric Vehicle PART NO 8.8±0.3 9.8±0.3 4.3±0.3 TO WA R D 2.0±0.2 47 6.4±0.3 TO SMD6 3.4±0.2 S MD 8 4.4±0.3 9.4±0.3 2.0±0.2 AC 47 AB 47 ARD TOW S 4.4±0.3 9.8±0.3 D SMD4 3.4±0.2 D IP 8 AC WA 47 RD F 6.4±0.3 TO 3.4±0.2 8.8±0.3 AA WA 47 RD F AB 47 F 6.4±0.3 ARD TOW 3.4±0.2 DIP6 TO WA R DIP4 4.7±0.3 6.4±0.3 AC 3.4±0.2 47 TO WA R 3.4±0.2 AA 47 AB 6.4±0.3 D 6.4±0.3 ARD TOW S 4.7±0.3 SOP4 S OP 8 PACKAGE PACKING AB47 DIP-4 Tube 90pcs AA47 DIP-6 Tube 50pcs AC47 DIP-8 Tube 45pcs AB47F SMD-4 Tube 90pcs AA47F SMD-6 Tube 50pcs AC47F SMD-8 Tube 45pcs AB47S SOP-4 Tube 100pcs AC47S SOP-8 Tube 50pcs AB47F-R1 SMD-4 AA47F-R1 SMD-6 AC47F-R1 SMD-8 AB47S-R1 SOP-4 AC47S-R1 SOP-8 Reel 1000pcs * Package & PCB Layout Design, See Page 134 Terminal Identification AB47(F)(S) 1:Anode (LED) 2:Cathode (LED) 3,4:Drain (MOS FET) AA47(F) 1:Anode 2:Cathode 3:NC 4,6:Drain 5:Source (LED) (LED) (MOS FET) (MOS FET) 為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。 In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range. 47 Series. REV.10/2016 AC47(F)(S) 1,3:Anode (LED) 2,4:Cathode (LED) 5,6,7,8:Drain (MOS FET) 75 Hi-A Grade ≥ 1A Absolute Maximum Ratings 絕對最大定格 (Ambient Temperature 周圍溫度:25℃ ) Item Symbol Value AB47S AC47S AB47(F) AC47(F) AA47(F) 1CH Input 輸入 2CH 1CH 2CH Continuous LED Current 連續 LED 電流 IF 50mA Peak LED Current LED 峰值電流 (f-100 Hz,Duty=1%) IFP 500mA LED Reverse Voltage 逆向 LED 電壓 VR 5V Input Power Dissipation 輸入損耗 PIN 75mW Load Voltage 負荷電壓 VL 80V (AC peak or DC) 1CH Load Current 負荷電流 (A) IL 1.25 1.0 1.25 1.0 1.5 Peak Load Current 峰值負荷電流 (1ms,1 shot) (A) IPEAK 3.0 3.0 3.0 3.0 3.0 (mW) POUT 350 450 350 450 500 (mW) PT 400 500 400 500 550 I/O Breakdown Voltage 入 / 出力間絕緣電壓 (Vrms) VI/O 1500 1500 3750 3750 3750 I/O Breakdown Voltage 入 / 出力間絕緣電壓 (Suffix-H) (Vrms) VI/O 3750 3750 5000 5000 5000 Output 輸出 Output Power Dissipation 輸出損耗 Total Power Dissipation 全損耗 Operating Temperature 使用時溫度 TOPR -40℃ ~ +85℃ Storage Temperature 保存溫度 TSTG -40℃ ~ +100℃ Electrical Specifications 電性規格 (Ambient Temperature 周圍溫度:25℃ ) Item Input 輸入 LED Forward Voltage LED 順向電壓 Operation LED Current LED 動作電流 Recovery LED Voltage LED 復位電壓 On-Resistance 導通電阻 Drain to Drain Output 輸出 Off-State Leakage Current 開路狀態漏電流 Output Capacitance 輸出端容量 Turn-On Time 動作時間 Turn-Off Time 復位時間 Coupled 結合 I/O Insulation Resistance 輸入 / 出間絕緣阻抗 I/O Capacitance 輸入 / 力端靜電容量 VF 1.0 IF ON VF OFF 0.5 MAX. Units 1.37 1.5 V 1.0 3.0 mA 1.0 0.13 RON ILEAK Ω 1.0 µA VL=80V pF VL=0V,f=1MHz IF=5mA IL=Rating (for SOP type) TON 0.4 3.0 ms TOFF 0.12 0.5 ms TON 0.3 3.0 ms TOFF 0.12 0.5 ms C I/O IF=5mA,IL=Rating Time to flow is within 1sec. 0.16 220 109 IF=10mA V COUT R I/O Conditions IF=10mA IL=Rating (for DIP/SMD type) Ω 1.3 pF f=1MHz 為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。 In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range. BRIGHT TOWARD INDUSTRIAL CO.,LTD. 47 Series. REV.10/2016 Solid State Relays Turn-Off Time Transmission 復位時間 傳達 Turn-On Time 動作時間 Symbol MIN. TYP. PhotoMOS-FET Relays PhotoMOS-FET Relays PhotoMOS-FET Relays PhotoMOS-FET Relays PhotoMOS-FET Relays PhotoMOS-FET Relays PhotoMOS-FET Relays General-Purpose Hi-A Grade ≥ 1A Hi-V Grade ≥ 600V Low Leakage Current RF Photo Coupler Mos Driver Outline Package 76 Hi-A Grade ≥ 1A 為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。 In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range. 47 Series. REV.10/2016 134 Package & PC Board Pattern Package 包裝 Dimensions 外型尺寸圖 PC Board pattern PC 板加工圖 0.3 7.87 9.54 max. ARD TOW DIP4 (Bottom View) 15 max. 0.3 SMD4 1.3 +0.2 0.1 -0.05 0.3 8.7 1.3 ARD TOW (Top View) 7.87 9.54 max. TO WA RD 0.3 DIP6 (Bottom View) 15 max. SMD6 1.3 0.1 +0.2 -0.05 0.3 8.7 TO WA R D 1.3 0.3 (Top View) 7.87 9.54 max. TO WA R D 0.3 DIP8 (Bottom View) 15 max. 1.3 +0.2 0.1 -0.05 0.3 TO WA R D 1.3 0.3 (Top View) TO WA RD 6.3 SMD8 (Top View) 0.06 6.3 TO WA R D SOP4 1.27 SOP8 0.06 為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。 In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range. Package & PC Board Pattern. REV.06/2017 0.76 (Top View) 135 Packing Specifications Package Type 包裝類型 Reel shape & dimensions 圈帶形狀和尺寸 Quantity 數量 100 330 12 4.6 Tape shape & dimensions 形狀和尺寸 4 Pin SOP 2.0 100 330 16 10.4 13 1000 pcs 8 Pin SOP 2.0 80 380 1000 pcs 80 380 4 Pin SMD 1000 pcs 80 380 5.3 17 1000 pcs 1000 pcs 9.15 17 6 Pin SMD 9.9 17 8 Pin SMD 17 為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。 In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range. BRIGHT TOWARD INDUSTRIAL CO.,LTD. Packing Speci ications. REV.06/2017 136 Load Connecting Method Type 類型 Load 負荷 4 pin AC or DC Feature 特長 Control bi-directional signal 可控制雙向信號 AC or DC Control bi-directional signal 可控制雙向信號 B DC On-Resistance is 1/2 of A-connection 導通電阻值是 A 接法的 1/2 2-Make-contacts (Source Common) C DC On-Resistance is 1/2 of B-connection 導通電阻值是 B 接法的 1/2 A 6 pin Connection 接續方法 2 input and 2 output 2 入力和 2 出力回路 8 pin AC or DC 1 input and 2 output 1 入力和 2 出力回路 為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。 In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range. Load Connecting Method. REV.06/2017
AA47F 价格&库存
很抱歉,暂时无法提供与“AA47F”相匹配的价格&库存,您可以联系我们找货
