BU-1C05J
BU-1C05J
    TOWARD(拓纬)
    6GHZ, 200V/0.2A HIGH FREQUENCE R
BU-1C05J 数据手册
Reed Relay / BU Series (1c) BU Series (1c) RoHS Compliance Surface Mount Reed Relays Features ● Available in Axial, Gull wing and J Lead configurations. ● Tape and Reel packaging available. ● High reliability, hermetically sealed contacts for long life. ● High Insulation Resistance - 109Ωminimum. ● Coaxial shield for 50Ωimpedance. Excellent for RF and Fast. ● Rise Time Pulse switching (up to 6 GHz). ● External Magnetic Shield. Order Code BU-1C XX X a b c a : Contact Form : 1C=1FormC b : Nominal Coil Voltagel : 03=3.3VDC, 05=5VDC c : Nil=Standard Type, J=SMD J Model Coil Date-Standard Type (at 20℃ ) Part Number Nominal Voltage DC ± 10% [V] Coil Resistance ± 10% [ohm] Max. Coil Voltage (VDC) Must Release Voltage MIN. [V] at 20℃ Must Operate Voltage MAX. [V] at 20℃ BU-1C03 3.3 70 4 0.4 2.5 BU-1C05 5 110 6 0.4 3.8 Contact Rating Contact Form Contact Rating MAX DC / Peak AC resistance 3W Switching Voltage MAX DC / Peak AC resistance 30VDC Max.Switching Current MAX DC / Peak AC resistance 0.1A Max.Carry Current MAX DC / Peak AC resistance 0.2A BRIGHT TOWARD INDUSTRIAL CO.,LTD. REV.22-11-01 1 Form C Reed Relay / BU Series (1c) Specification 1 Form C Contact From 200mΩ Static Contact Resistance (Max.init) Breakdown Voltage Between contacts 200VDC / peak AC Contacts to shield 1000VDC / peak AC Contacts / shield to coil 1000VDC / peak AC Insulation Resistance 1x109Ω Capacitance-Typical Open Contact 1.0pF Operate Time-including bounce-Typical 0.3mS Release Time 0.3mS Vibration1#PIN 20G's to 2000HZ shock 50G's 3–1.02 2 4 6 8 -20℃ ~+85℃ 1 4.95 8–.38 Operating Temp 3 -35℃ ~+100℃ 5 Signal Level 1.0V, 10mA, 1x108Ops. 7 Storage Temp Life Expectancy Top View Dimensions (Unit : mm) 1#PIN 1 3 5 7 4.95 8–.38 3–1.02 10.06 10.16 Top View 4.83 R.25 5.33 7.00 1.27 .26 0.25 0.50 R.38 .25±0.05 9.52 11.68 12.95 7.880 9.65 11.18 SMD(Standard) 2 4 6 8 1 3 5 7 Top View J Model 10.06 Note:Tolerance ±0.2mm 4.83 R.25 R.38 7.00 8–.38 4.95 Wiring Diagrams (Top View) 1.27 1 3 5 7 .25±0.05 9.52 11.68 12.95 Top View .26 2 4 6 8 為了持續的改進,敝司有權在不引響規格範圍的情況下修改設計。 In the interest of continuous development, our companies reserve the right to alter designs within specifiaction range. © TOWARD CORPORATION REV.22-11-01
BU-1C05J 价格&库存
很抱歉,暂时无法提供与“BU-1C05J”相匹配的价格&库存,您可以联系我们找货
