164
S.S.R.
TL Series
DC Intput & AC Output 8A/16A
Features
Applications
● High isolation voltage 4000 VAC between input
and output
● 600VDC peak blocking Voltage
● Be suitable for 110/220VAC power voltage
● Random-on & Zero-on types are available
● UL Recognized
● Household appliance
● Programmable controller
Order Code:
a : Model : TL = SIP 4 Pin Package
b : Output Voltage : 2 = 240VAC
c : Output Current : 08 = 8Amp ; 16 = 16Amp
d : Turn - on Type : Nil = Zero on ; R = Random - on
e : Option : Nil = Standard, 1-9 = Special code
TL 2 16 R - X
a b c d
e
Absolate Maximum Rating:
Symbol
Rating
TL208(R ) TL216(R )
Unit
IF
50
mA
Peak Forward Current
IFP
1
A
Reverse Voltage
VR
6
VAC
Maximun Load Voltage
Vomax
280
VAC
Off-state Output Voltage
VDRM
600
VDC
On-state Output Current
IT(RMS)
8
ITSM
80
Items
Forward Current
Input
Output
Non-repeatitive Sutge Current
16
160
A
A
I/O Isolation Voltage
Viso
4000
VAC
Operating Temperature
Topr
-25~+100
Storage Temperature
Tstg
-35~+125
Electrical Characteristics:
Items
Input
Symbol
MIN.
TYP.
MAX.
Unit
Conditions
Forward Voltage
VF
1.18
1.4
V
IF=10mA
Reverse Current
IR
10
µA
VR=5V
Leakage Voltage Range
VO
35
280
VAC
Peak Leakage Current
IDRM
100
µA
VDRM=600V
VTM
1.5
V
IT=Rated IT
50
mA
VDRM=600V/ √ 2
30
V/µS
VDRM=600V/ √ 2
10
mA
VD=6V
Output On-state Voltage
Hold Current
Rise rate of off-state
Minimum trigger current
IH
dv/dt
I
FT
Recovery Input Voltage
VFOFF
0.5
V
I/O Isolation Resistance
Riso
1010
Ω
DC=500V
Turn-on Time (Random-on)
TON
1
mS
IF=20mA
Turn-on Time (Zero-on)
TON
10
mS
Turn-off Time
TOFF
10
mS
Note:Recommended trigger current is between 10mA and 20mA.
TL Series. REV.10/2016
165
S.S.R.
Dimensions : (Unit : mm)
REFERENCE DATA :
TL2 08
TL216
Mximun Load Current Vs.
Ambient temperature
Ambient temperature
Solid State Relays
BRIGHT TOWARD INDUSTRIAL CO.,LTD.
PhotoMOS-FET Relays PhotoMOS-FET Relays PhotoMOS-FET Relays PhotoMOS-FET Relays PhotoMOS-FET Relays PhotoMOS-FET Relays PhotoMOS-FET Relays
General-Purpose
Hi-A Grade ≥ 1A Hi-V Grade ≥ 600V Low Leakage Current
RF
Photo Coupler
Mos Driver
TL216
166
S.S.R.
Forward Current Vs.
Ambient temperature
Forward Current Vs.
Forward Voltage
On State Power Dissipation Vs.
On State Load Current
Case Temperature
Peak Surge Current V.S Duration
(Non Repective)
167
S.S.R.
Minimun Trigger Current Vs.
Ambient temperature
Relative Peak Repetitive Voltage Vs.
Ambient Temperature
Ambient Temperature
Peak Repetitive Current Vs.
Ambient Temperature
Peak Repetitive Current V.S
Ambient Temperature
General-Purpose
RF
Photo Coupler
Mos Driver
Ambient temperature
Solid State Relays
很抱歉,暂时无法提供与“TL216”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+184.44240
- 200+73.60200
- 500+71.13960
- 1000+69.91920
