1.14.002.003/0000
1.14.002.003/0000
    RAFI
    轻触开关 立贴
1.14.002.003/0000 数据手册
MICON 5 »Just click it… …just feel it« as e l P s res p e Switching individually With the new MICON 5, switching is redefined. The click varies from a gentle to a distinctly sportive sound, depending on the type used. This makes it possible to tailor the look and feel of the input keyboard to the style of the overall system. RAFI's new MICON 5 short-travel keyswitch sets the benchmark in miniaturisation while safeguarding switching reliability and excellent tactile and acoustic properties. In membrane keyboards, in operating panels or under keycaps: The RAFI MICON 5 leaves great freedom to your designers and offers to your customers the switching reliability that lasts for a product's life. This is the leading edge: Technology, look & feel, service life. Machines and devices should above all be easy and safe to operate: With keyswitches giving a distinct feedback. And which offer reliable switching for the full life cycle of a product. RAFI's new MICON 5 opens up entirely new perspectives for the development of data entry systems and control panels with its footprint of only 5.1 x 6.4 mm. First class acoustic and tactile properties, excellent look and feel combined with absolute switching reliability for keyboards and data entry units. MICON 5 The small keyswitch finds a place anywhere The MICON 5 excels by its minimum dimensions, superior tactile properties and a sealed contact system with gold contacts. This makes it ideally suited for the most sophisticated applications just as for the most severe conditions of use. MICON 5:The reliable switching unit for use under keycaps. Push, pull, rocker, double push functions, etc. Whatever you want to switch, you can realise all your ideas with the MICON 5. MICON 5: Unbeatable also under membrane overlays. Experience pays. The MICON 5 offers you utmost flexibility in designing many different control panels in combination with the RAFI plungers of variable heights and actuation areas, ranging from extremely small keypads to exclusive control panels. Part numbers Order no. Terminals Height [mm] Operating force F¹ [N] (+- 20%) Switching travel S² [mm] (+- 0,5 mm) Operating life [operations] (testing force) 1.14.002.101/0000 SMD standard 3,85 3,0 0,7 1.14.002.001/0000 SMD standard 3,85 4,5 0,8 250.000 (6 N) 1.14.002.111/0000 SMD standard 3,8 5,5 0,9 1.000.000 (8 N) 1.14.002.011/0000 SMD standard 3,85 8,5 1,1 250.000 (12 N) 1.14.002.103/0000 SMD low 3,45 3,0 0,6 1.000.000 (4 N) 1.14.002.003/0000 SMD low 3,45 4,5 0,7 250.000 (6 N) 1.14.002.113/0000 SMD low 3,45 5,5 0,7 1.000.000 (8 N) 1.14.002.106/0000 THT standard 3,85 3,0 0,7 1.000.000 (4 N) 1.14.002.006/0000 THT standard 3,85 4,5 0,8 250.000 (6 N) 1.14.002.116/0000 THT standard 3,85 5,5 0,9 1.000.000 (8 N) 1.14.002.016/0000 THT standard 3,85 8,5 1,1 250.000 (12 N) 1.000.000 (4 N) Mechanical characteristics (preliminary data) Operating force range: Tactile feedback: See table part numbers, others available on request Uniform over the service life and temperature range Mechanical Design (preliminary data) Contact system: Contact arrangement: Keyswitch mounting: Fixing: Terminals: Terminal shape: Flammability of materials: Dimensions: Snap-action contact, gold-plated on both sides 1 NO contact On printed circuit board Reflow or wave soldering; gluing not required High-grade tin (lead-free to WEEE standards) Recessed J-shape terminals for SMD, PCB solder terminals for THT UL 94 HB (non-halogenous acc. to WEEE) 6,4 x 5,1 x 3,85/3,45 mm RAFI MICON 5 Basic element SMD-J on back Without cover Overall height 3.85 mm Metal cover Sectional view of keyswitch Silicone seal and actuator Standard keyswitch with extension plunger Housing with snap disc MICON 5 under customer-specific keycaps Electrical characteristics (preliminary data) Rated voltage: Rated current: Rated power, max.: Contact resistance: Bouncing time: Switching travel: 0.02 to 42 V AC / DC 0.01 to 100 mA 1W
1.14.002.003/0000 价格&库存
很抱歉,暂时无法提供与“1.14.002.003/0000”相匹配的价格&库存,您可以联系我们找货
1.14.002.003/0000
    • 2100+11.99428
    库存:3180
    1.14.002.003/0000
    • 1+23.843911+3.08367
    • 10+20.0265410+2.58998
    • 25+18.5719925+2.40187
    • 100+16.54264100+2.13942
    • 250+15.35335250+1.98561
    • 500+14.54396500+1.88093
    • 1000+13.813871000+1.78651
    库存:2031
    1.14.002.003/0000
    • 2100+12.812022100+1.65695
    • 4200+12.252414200+1.58457
    • 6300+11.957196300+1.54639
    库存:2031
