5.58.007.001/0000
5.58.007.001/0000
    RAFI
    更换键
5.58.007.001/0000 数据手册
RAFIX 16 2 RAFIX 16 General data RAFIX 16 control component range • For a mounting hole diameter of 16.2 mm to IEC 60947 • 250V/6A max. • Water-jet proof IP65 • Contact blocks: Gold and silver contacts with quick-connect terminals 2.8 x 0.8 mm; Option: PCB plug-in socket • 3 collar shapes, low-profile design • The lamps of the pushbuttons can be replaced from the front or rear. • The contact blocks snap directly onto the actuators without a coupling element and can be easily removed by turning = cost reducing assembly. The specified data apply only if actuators/signal indicators are combined with contact blocks and lamp sockets within the same product range. Content RAFIX 16 pushbutton RAFIX 16 pushbutton, flush lens, square collar RAFIX 16 pushbutton, protruding lens, square collar RAFIX 16 pushbutton, protruding collar, square collar RAFIX 16 pushbutton, flush lens, round collar RAFIX 16 pushbutton IP66 with protective cap RAFIX 16 pushbutton, protruding lens, round collar RAFIX 16 pushbutton, protruding collar, round collar RAFIX 16 pushbutton, flush lens, square collar, alignable without gaps 2- 8 2- 9 2 - 10 2 - 11 2 - 12 2 - 13 2 - 14 2 - 15 2 - 16 RAFIX 16 selector switch RAFIX 16 selector switch, square collar RAFIX 16 selector switch, round collar RAFIX 16 selector switch, square collar, alignable without gaps 2 - 18 2 - 19 2 - 20 2 - 21 RAFIX 16 keylock switch MICROMEC RAFIX 16 keylock switch MICROMEC, square collar RAFIX 16 keylock switch MICROMEC, round collar RAFIX 16 keylock switch MICROMEC, square collar, alignable without gaps 2 - 22 2 - 23 2 - 24 2 - 25 RAFIX 16 keylock switch, RONIS RAFIX 16 keylock switch, RONIS, square collar RAFIX 16 keylock switch, RONIS, round collar RAFIX 16 keylock switch, RONIS, square collar, alignable without gaps 2 - 26 2 - 27 2 - 28 2 - 29 RAFIX 16 mushroom-headed pushbutton RAFIX 16 mushroom-headed pushbutton, square collar RAFIX 16 mushroom-headed pushbutton, round collar RAFIX 16 mushroom-headed pushbutton, square collar, alignable without gaps 2 - 30 2 - 31 2 - 31 2 - 32 Control components Stock items are marked by bold printed order numbers. 2-3 RAFIX 16 2 RAFIX 16 RAFIX 16 emergency stop pushbutton RAFIX 16 emergency stop pushbutton, square collar, illuminated RAFIX 16 emergency stop pushbutton, square collar, dupe-proof RAFIX 16 emergency stop pushbutton, round collar, illuminated RAFIX 16 emergency stop pushbutton, round collar, dupe-proof RAFIX 16 emergency stop pushbutton, square collar, alignable without gaps, illuminated RAFIX 16 emergency stop pushbutton, square collar, alignable without gaps, dupe-proof RAFIX 16 safety emergency stop pushbutton, round collar, dupe-proof, non-blocking RAFIX 16 safety emergency stop pushbutton, round collar, conical, dupe-proof, non-blocking 2 - 34 2 - 35 2 - 35 2 - 36 2 - 36 2 - 37 2 - 37 2 - 38 2 - 38 RAFIX 16 toggle switch RAFIX 16 toggle switch, square collar RAFIX 16 toggle switch, round collar RAFIX 16 toggle switch, square collar, alignable without gaps 2 - 40 2 - 41 2 - 41 2 - 42 RAFIX 16 potentiometer drive RAFIX 16 potentiometer drive, square collar RAFIX 16 potentiometer drive, round collar RAFIX 16 potentiometer drive, square collar, alignable without gaps 2 - 44 2 - 45 2 - 45 2 - 46 RAFIX 16 buzzer RAFIX 16 buzzer, square collar RAFIX 16 buzzer, round collar RAFIX 16 buzzer, square collar, alignable without gaps 2 - 48 2 - 49 2 - 49 2 - 50 RAFIX 16 signal indicator RAFIX 16 signal indicator, square lens RAFIX 16 signal indicator, square collar, flush lens RAFIX 16 signal indicator, square collar, protruding lens RAFIX 16 signal indicator, round lens RAFIX 16 signal indicator, round collar, flush lens RAFIX 16 signal indicator, round collar, protruding lens RAFIX 16 signal indicator, square collar, alignable without gaps, flush lens RAFIX 16 signal indicator, square collar, alignable without gaps, protruding lens 2 - 52 2 - 53 2 - 53 2 - 54 2 - 54 2 - 55 2 - 55 2 - 56 2 - 56 RAFIX 16 contact blocks with gold contacts RAFIX 16 standard contact block, gold contacts, with lamp socket RAFIX 16 standard contact block, gold contacts, without lamp socket RAFIX 16 universal contact block, gold contacts, with lamp socket RAFIX 16 universal contact block, gold contacts, without lamp socket 2 - 58 2 - 60 2 - 60 2 - 61 2 - 61 RAFIX 16 contact blocks with silver contacts RAFIX 16 standard contact block, silver contacts, with lamp socket RAFIX 16 standard contact block, silver contacts, without lamp socket RAFIX 16 universal contact block, silver contacts, with lamp socket RAFIX 16 universal contact block, silver contacts, without lamp socket 2 - 62 2 - 64 2 - 64 2 - 65 2 - 65 RAFIX 16 lamp socket RAFIX 16 lamp socket W 2 x 4.6 d RAFIX 16 lamp socket W 2 x 4.6 d 2 - 66 2 - 67 2 - 68 RAFIX 16 special accessories PCB plug-in socket Multipole connector Female quick-connect terminal DIN 46340-B 2.8-1-MS Plug distributor 2 - 70 2 - 70 2 - 71 2 - 71 2 - 72 Protection against contact Protection against contact 2 - 72 2 - 73 Series capacitor Disassembly tool Protective cover, suitable for lead seal, for pushbuttons, alignable without gaps Fixing spanner for hexagon nut 2 - 73 2 - 74 2 - 74 2 - 75 RAFIX 16 insulating housing RAFIX 16 label holder, flush, for square collar RAFIX 16 label holder, flush, for round collar RAFIX 16 label holder, protruding, for square flush fitting collar Emergency stop label, yellow, round 60 mm, PVC adhesive 2 - 75 2 - 76 2 - 76 2 - 77 2 - 77 2-4 Stock items are marked by bold printed order numbers. Control components RAFIX 16 General information RAFIX 16 is a complete control component series for a mounting hole diameter of 16.2 mm. It enables you to design attractive control panels with a minimum of space requirements and at the same time sufficiently large actuating areas. Actuators Contact blocks – Mounting hole ø 16.2 mm to DIN EN 50 007 – Standard (for actuators with one-way operation) • with latching mechanism (latching switch) • without latching mechanism (momentary switch) – Universal (for actuators with two-way operation, e. g. selector switches) • without latching mechanism Contact material RAFIX 16 – Silver contacts for mains voltage – Gold contacts for electronic circuits Illumination - Wedge base lamp W 2 x 4.6 d Assembly – – – – Single-handed cost-effectiv assembly method Panel thickness 0.5 … 5 mm Fixing with hexagon nut Starting torque 1.2 Nm max. Shock-resistance according to IEC 600 68-2-27 – Shock amplitude: ≤ 50 g – Shock time: 11 ms – Shock type: half sinusoidal – Locating lug (easily removable). The locating lug can be easily removed using a screwdriver. – Degree of protection IP 65 on panel. This is achieved by a reliable, tried and tested special seal. – Grid spacing 25 x 25 mm – Low-profile design, 7 mm height from front panel – Three collar shapes, in black • Square 25 x 25 mm • Round 25 mm • Square 25 x 25 mm, alignable in flush fitting rows, which avoids accumulation of dirt between the collars. Control Components 2 Environment conditions – Constant environment: acc. to IEC 600 68-2-3 and 2-30 – Variable environment: acc. to IEC 600 68-2-14 and 2-33 Temperature range – Operating temperature: non-illuminated: - 25 … + 70 ° C illuminated: - 25 … + 55° C – Storage temperature: - 40 … + 85° C 2-5 RAFIX 16 ® CE-Conformity RAFIX 16 Combination actuator and contact block Order no. Limit All actuators All contact blocks with silver contacts Emergency stop Contact blocks with silver contacts Emergency stop, Universal contact blocks with gold contacts Signal indicator lamp socket 1.3007–.– – – 1.2012–.– – – 1.30074.– – – 1.20123.– – – 1.30074.– – – 1.20123.– – – 1.62124.– – – 1.71212.– – – EU-Directive NSR 73/23 Ma. Dir. 89/392 6(4) A/250 V AC ● – 6(4) A/250 V AC ● ● 250 mA/42 V AC/DC – ● 1,2 W/60 V AC/DC ● – 2 Assembly – Insert the actuator through the panel cut-out from the front. If there is no locating indent provided in the cut-out, first remove the locating lug using a screwdriver. – Screw the hexagon nut onto the actuator or signal indicator from the rear and tighten it using a fixing spanner. – Slide the contact block onto the actuator from the rear with an audible click. – Install protection against accidental contact, if applicable. – Connect quick-connect terminals. – Alternatively, connect crimped female quick-connect terminals to multipole connector and plug it onto the contact block. – Alternatively, conntact the plug-in socket soldered onto RAFIX 16 Assembly/Disassembly Disassembly – Turn the contact block by approx. 20° to the left or right – the latches open. – Pull the contact block off towards the rear (commercially available flat nose pliers recommended). To dismount a PCB, pull the PCB with the soldered plug-in sockets off the mounted contact blocks. 2-6 Control Components RAFIX 16 Legending Lamp replacement from front All elements can be labelled using a separate label holder. The label holder is mounted together with the actuator/ signal indicator. For order numbers and standard legend, refer to the section ”Legending”. Non-illuminated pushbuttons and mushroom-headed pushbuttons can be printed or laser engraved. All illuminated pushbuttons and the majority of the signal indicators can be labelled by means of legend inserts. The legend inserts are fitted between actuator body and lens and can be easily changed. Rafi can also provide you custom legending. Price and delivery on request. Use the disassembly tool to grasp the actuator body and pull it towards the front with the lens. Alternatively, you can use a screwdriver in place of the disassembly tool. In this case, insert the screwdriver between actuator body and collar and carefully raise the actuator body. Replace the lamp using a lamp extractor or a suitable insulation sleeve. 2 RAFIX 16 Lamp replacement from front Control Components 2-7 RAFIX 16 RAFIX 16 pushbutton Pict.: red 2 RAFIX 16 Pict.: with contact block panel cut-out Technical data General information Form of lens Colour of lens Form of collar Mechanical characteristics Operating travel Robustness min. see order block see order block see order block Dimensions Length of collar Diameter of collar Key grid Width of collar Overall height Mounting depth Mounting hole see order block see order block 25 x 25 mm see order block see order block 44.7 mm 16.2 mm Mechanical design Mounting Contact function Contact arrangement Illuminability ring nut according to contact block according to contact block see order block Other specifications Operating life Degree of protection from front side Ambient temp. operating min. Ambient temp. operating without lamp max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment 3 mm 100 N 2000000 IP65 -25 °C +70 °C -40 °C +85 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 Accessories RAFIX 16 pushbutton Description Photo Order no. Page RAFIX 16 standard contact block, 1 NC + 1 NO, momentary, silver contacts, with lamp socket 1.20.122.001/0000 2 - 64 RAFIX 16 standard contact block, 1 NC + 1 NO, momentary, gold contacts, with lamp socket 1.20.122.011/0000 2 - 60 RAFIX 16 standard contact block, 1 NC + 1 NO, momentary, silver contacts, without lamp socket 1.20.122.021/0000 2 - 64 RAFIX 16 standard contact block, 1 NC + 1 NO, momentary, gold contacts, without lamp socket 1.20.122.031/0000 2 - 60 LED W 2 x 4.6d superbright, white, 24 V 1.90.690.365/0000 5 - 16 Disassembly tool for LUMOTAST 25, RAFIX 16 5.05.800.042/0000 2 - 74 5 - 26 Label holder, flush, for square collar 5.07.620.004/0000 2 - 76 2-8 Stock items are marked by bold printed order numbers. Control components RAFIX 16 Accessories RAFIX 16 pushbutton Description Photo Fixing spanner for hexagon nut Order no. Page 5.58.002.034/0000 2 - 75 RAFIX 16 pushbutton, flush lens, square collar 2 Pict.: white Illuminability panel cut-out Colour of lens Order no. complete Order no. single parts Housing Lens yes transparent colourless 1.30.070.001/1002 1.30.070.501/0000 5.49.077.011/1002 yes transparent red 1.30.070.001/1306 1.30.070.501/0000 5.49.077.011/1306 yes transparent yellow 1.30.070.001/1403 1.30.070.501/0000 5.49.077.011/1403 yes transparent green 1.30.070.001/1505 1.30.070.501/0000 5.49.077.011/1505 yes transparent blue 1.30.070.001/1607 1.30.070.501/0000 5.49.077.011/1607 no opaque black 1.30.070.251/0100 1.30.070.751/0000 5.05.510.640/0100 no opaque white 1.30.070.251/0200 1.30.070.751/0000 5.05.510.640/0200 no opaque red 1.30.070.251/0300 1.30.070.751/0000 5.05.510.640/0300 no opaque yellow 1.30.070.251/0400 1.30.070.751/0000 5.05.510.640/0400 no opaque green 1.30.070.251/0500 1.30.070.751/0000 5.05.510.640/0500 no opaque blue 1.30.070.251/0600 1.30.070.751/0000 5.05.510.640/0600 Technical data see page 2 - 8 Accessories: Legend insert, blank, use only for transparent lenses: 5.70.635.000/2000 For the „latching“ function, please use the standard contact block with „latching“ function. Control components Stock items are marked by bold printed order numbers. 2-9 RAFIX 16 RAFIX 16 RAFIX 16 pushbutton, protruding lens, square collar Pict.: yellow Illuminability panel cut-out Colour of lens Order no. complete Order no. single parts Housing 2 RAFIX 16 Lens yes transparent colourless 1.30.070.051/1002 1.30.070.551/0000 5.49.077.012/1002 yes transparent red 1.30.070.051/1306 1.30.070.551/0000 5.49.077.012/1306 yes transparent yellow 1.30.070.051/1403 1.30.070.551/0000 5.49.077.012/1403 yes transparent green 1.30.070.051/1505 1.30.070.551/0000 5.49.077.012/1505 yes transparent blue 1.30.070.051/1607 1.30.070.551/0000 5.49.077.012/1607 no opaque black 1.30.070.301/0100 no opaque white 1.30.070.301/0200 no opaque red 1.30.070.301/0300 no opaque yellow 1.30.070.301/0400 no opaque green 1.30.070.301/0500 no opaque blue 1.30.070.301/0600 Technical data see page 2 - 8 Accessories: Legend insert, blank, use only for transparent lenses: 5.70.635.000/2000 For the „latching“ function, please use the standard contact block with „latching“ function. 2 - 10 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 pushbutton, protruding collar, square collar Pict.: yellow Illuminability panel cut-out Colour of lens Order no. complete Order no. single parts Housing Lens yes transparent colourless 1.30.070.101/1002 1.30.070.601/0000 5.49.077.011/1002 yes transparent red 1.30.070.101/1306 1.30.070.601/0000 5.49.077.011/1306 yes transparent yellow 1.30.070.101/1403 1.30.070.601/0000 5.49.077.011/1403 yes transparent green 1.30.070.101/1505 1.30.070.601/0000 5.49.077.011/1505 yes transparent blue 1.30.070.101/1607 1.30.070.601/0000 5.49.077.011/1607 no opaque black 1.30.070.351/0100 1.30.070.851/0000 5.05.510.640/0100 no opaque white 1.30.070.351/0200 1.30.070.851/0000 5.05.510.640/0200 no opaque red 1.30.070.351/0300 1.30.070.851/0000 5.05.510.640/0300 no opaque yellow 1.30.070.351/0400 1.30.070.851/0000 5.05.510.640/0400 no opaque green 1.30.070.351/0500 1.30.070.851/0000 5.05.510.640/0500 no opaque blue 1.30.070.351/0600 1.30.070.851/0000 5.05.510.640/0600 Technical data see page 2 - 8 Accessories: Legend insert, blank, use only for transparent lenses: 5.70.635.000/2000 The protruding collar offers protection against inadvertent operation and thereby fulfils the safety requirements of various machinery manufacturers, particularly in the printing industry. For the "latching" function, please use the standard contact block with "latching" function. Control components Stock items are marked by bold printed order numbers. 2 - 11 2 RAFIX 16 RAFIX 16 RAFIX 16 pushbutton, flush lens, round collar Pict.: blue Illuminability panel cut-out Colour of lens Order no. complete Order no. single parts Housing 2 RAFIX 16 Lens yes transparent colourless 1.30.070.021/1002 1.30.070.521/0000 5.49.259.017/1002 yes transparent red 1.30.070.021/1306 1.30.070.521/0000 5.49.259.017/1306 yes transparent yellow 1.30.070.021/1403 1.30.070.521/0000 5.49.259.017/1403 yes transparent green 1.30.070.021/1505 1.30.070.521/0000 5.49.259.017/1505 yes transparent blue 1.30.070.021/1607 1.30.070.521/0000 5.49.259.017/1607 no opaque black 1.30.070.271/0100 1.30.070.771/0000 5.05.510.641/0100 no opaque white 1.30.070.271/0200 1.30.070.771/0000 5.05.510.641/0200 no opaque red 1.30.070.271/0300 1.30.070.771/0000 5.05.510.641/0300 no opaque yellow 1.30.070.271/0400 1.30.070.771/0000 5.05.510.641/0400 no opaque green 1.30.070.271/0500 1.30.070.771/0000 5.05.510.641/0500 no opaque blue 1.30.070.271/0600 1.30.070.771/0000 5.05.510.641/0600 Technical data see page 2 - 8 Accessories: Legend insert, blank, use only for transparent lenses: 5.70.637.000/2000 For the "latching" function, please use the standard contact block with "latching" function. 2 - 12 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 pushbutton IP66 with protective cap Pict.: yellow Illuminability panel cut-out Colour of lens Order no. complete Order no. single parts Housing yes transparent colourless 1.30.070.026/1002 yes transparent red 1.30.070.026/1306 yes transparent yellow 1.30.070.026/1403 yes transparent green 1.30.070.026/1505 yes transparent blue 1.30.070.026/1607 no opaque black 1.30.070.276/0100 no opaque white 1.30.070.276/0200 no opaque red 1.30.070.276/0300 no opaque yellow 1.30.070.276/0400 no opaque green 1.30.070.276/0500 no opaque blue 1.30.070.276/0600 Lens 2 RAFIX 16 Technical data see page 2 - 8 Accessories: Legend insert, blank, use only for transparent lenses: 5.70.637.000/2000 Pushbutton for use in hostile environments. A transparent protective cap ensures a degree of protection of IP 66 to DIN/IEC. Operating life: 500,000 operations. For the "latching" function, please use the standard contact block with "latching" function. Control components Stock items are marked by bold printed order numbers. 2 - 13 RAFIX 16 RAFIX 16 pushbutton, protruding lens, round collar Pict.: red Illuminability panel cut-out Colour of lens Order no. complete Order no. single parts Housing 2 RAFIX 16 Lens yes transparent colourless 1.30.070.071/1002 1.30.070.571/0000 5.49.259.018/1002 yes transparent red 1.30.070.071/1306 1.30.070.571/0000 5.49.259.018/1306 yes transparent yellow 1.30.070.071/1403 1.30.070.571/0000 5.49.259.018/1403 yes transparent green 1.30.070.071/1505 1.30.070.571/0000 5.49.259.018/1505 yes transparent blue 1.30.070.071/1607 1.30.070.571/0000 5.49.259.018/1607 no opaque black 1.30.070.321/0100 no opaque white 1.30.070.321/0200 no opaque red 1.30.070.321/0300 no opaque yellow 1.30.070.321/0400 no opaque green 1.30.070.321/0500 no opaque blue 1.30.070.321/0600 Technical data see page 2 - 8 Accessories: Legend insert, blank, use only for transparent lenses: 5.70.637.000/2000 For the "latching" function, please use the standard contact block with "latching" function. 2 - 14 Stock items are marked by bold printed order numbers. Control components 16165-r200-008-D1 2/8/05 12:13 PM Page 2 - 15 RAFIX 16 RAFIX 16 pushbutton, protruding collar, round collar Pict.: red Illuminability panel cut-out Colour of lens Order no. complete Order no. single parts Housing Lens yes transparent colourless 1.30.070.121/1002 1.30.070.621/0000 5.49.259.017/1002 yes transparent red 1.30.070.121/1306 1.30.070.621/0000 5.49.259.017/1306 yes transparent yellow 1.30.070.121/1403 1.30.070.621/0000 5.49.259.017/1403 yes transparent green 1.30.070.121/1505 1.30.070.621/0000 5.49.259.017/1505 yes transparent blue 1.30.070.121/1607 1.30.070.621/0000 5.49.259.017/1607 no opaque black 1.30.070.371/0100 1.30.070.871/0000 5.05.510.641/0100 no opaque white 1.30.070.371/0200 1.30.070.871/0000 5.05.510.641/0200 no opaque red 1.30.070.371/0300 1.30.070.871/0000 5.05.510.641/0300 no opaque yellow 1.30.070.371/0400 1.30.070.871/0000 5.05.510.641/0400 no opaque green 1.30.070.371/0500 1.30.070.871/0000 5.05.510.641/0500 no opaque blue 1.30.070.371/0600 1.30.070.871/0000 5.05.510.641/0600 Technical data see page 2 - 8 Accessories: Legend insert, blank, use only for transparent lenses: 5.70.637.000/2000 The protruding collar offers protection against inadvertent operation and thereby fulfils the safety requirements of various machinery manufacturers, particularly in the printing industry. For the "latching" function, please use the standard contact block with "latching" function. Control components Stock items are marked by bold printed order numbers. 2 - 15 2 RAFIX 16 RAFIX 16 RAFIX 16 pushbutton, flush lens, square collar, alignable without gaps Pict.: black Illuminability panel cut-out Colour of lens Order no. complete Order no. single parts Housing 2 RAFIX 16 Lens yes transparent colourless 1.30.070.201/1002 1.30.070.701/0000 5.49.077.011/1002 yes transparent red 1.30.070.201/1306 1.30.070.701/0000 5.49.077.011/1306 yes transparent yellow 1.30.070.201/1403 1.30.070.701/0000 5.49.077.011/1403 yes transparent green 1.30.070.201/1505 1.30.070.701/0000 5.49.077.011/1505 yes transparent blue 1.30.070.201/1607 1.30.070.701/0000 5.49.077.011/1607 no opaque black 1.30.070.451/0100 1.30.070.951/0000 5.05.510.640/0100 no opaque white 1.30.070.451/0200 1.30.070.951/0000 5.05.510.640/0200 no opaque red 1.30.070.451/0300 1.30.070.951/0000 5.05.510.640/0300 no opaque yellow 1.30.070.451/0400 1.30.070.951/0000 5.05.510.640/0400 no opaque green 1.30.070.451/0500 1.30.070.951/0000 5.05.510.640/0500 no opaque blue 1.30.070.451/0600 1.30.070.951/0000 5.05.510.640/0600 Technical data see page 2 - 8 Accessories: Legend insert, blank, use only for transparent lenses: 5.70.635.000/2000 For the „latching“ function, please use the standard contact block with „latching“ function. 2 - 16 Stock items are marked by bold printed order numbers. Control components 16165-r200-018-D3 2/8/05 12:05 PM Page 2 - 18 RAFIX 16 RAFIX 16 selector switch Pict.: Handle marking opaque white 2 RAFIX 16 Panel cut-out Technical data General information Form of lens Marking of handle Form of collar Mechanical characteristics Torque max. handle see order block see order block Dimensions Length of collar Diameter of collar Key grid Width of collar Overall height Mounting depth Mounting hole see order block see order block 25 x 25 mm see order block 17.1 mm 44.7 mm 16.2 mm Mechanical design Mounting Contact function Contact arrangement Illuminability Rotating angle ring nut see order block according to contact block see order block see order block Other specifications Operating life Degree of protection from front side Ambient temp. operating min. Ambient temp. operating without lamp max. Ambient temp. operating with lamp max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment 1.3 Nm 30000 IP65 -25 °C +70 °C +55 °C -40 °C +85 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 Accessories RAFIX 16 selector switch Description Photo Order no. Page RAFIX 16 universal contact block, 1 NC + 1 NO, momentary, silver contacts, with lamp socket 1.20.123.001/0000 2 - 65 RAFIX 16 universal contact block, 1 NC + 1 NO, momentary, gold contacts, with lamp socket 1.20.123.011/0000 2 - 61 Label holder, flush, for square collar 5.07.620.004/0000 2 - 76 Fixing spanner for hexagon nut 5.58.002.034/0000 2 - 75 For suitable LEDs, filament lamps and other contact blocks, refer to the chapter „RAFIX 16 contact blocks“; for additional accessories, refer to the chapter „RAFIX 16 special accessories“. 2 - 18 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 selector switch, square collar Pict.: Handle marking translucent Illuminability Panel cut-out Contact function Rotating angle Marking of handle Order no. complete yes momentary 1 x 40° translucent white 1.30.073.551/2000 yes momentary 2 x 40° translucent white 1.30.073.651/2000 yes latching L, 1 x 90° translucent white 1.30.073.501/2000 yes latching V, 1 x 90° translucent white 1.30.073.601/2000 yes latching 2 x 60° translucent white 1.30.073.701/2000 yes latching 90°/momentary 40° translucent white 1.30.073.751/2000 no latching 1 x 90° and momentary 1 x 40° momentary 1 x 40° opaque white 1.30.073.550/0200 no momentary 2 x 40° opaque white 1.30.073.650/0200 no latching L, 1 x 90° opaque white 1.30.073.500/0200 no latching V, 1 x 90° opaque white 1.30.073.600/0200 no latching 2 x 60° opaque white 1.30.073.700/0200 no latching 1 x 90° and momentary 1 x 40° latching 90°/momentary 40° opaque white 1.30.073.750/0200 0 2 0 2 Technical data see page 2 - 18 Only use contact blocks with "momentary" contact function. For versions with clockwise and counterclockwise rotation, use universal contact blocks only! Other handle marking colours available on request. Control components Stock items are marked by bold printed order numbers. 2 - 19 2 RAFIX 16 RAFIX 16 RAFIX 16 selector switch, round collar Pict.: handle opaque Illuminability 2 RAFIX 16 Panel cut-out Contact function Rotating angle Marking of handle Order no. complete yes momentary 1 x 40° translucent white 1.30.073.571/2000 yes momentary 2 x 40° translucent white 1.30.073.671/2000 yes latching L, 1 x 90° translucent white 1.30.073.521/2000 yes latching V, 1 x 90° translucent white 1.30.073.621/2000 yes latching 2 x 60° translucent white 1.30.073.721/2000 yes latching 90°/momentary 40° translucent white 1.30.073.771/2000 no latching 1 x 90° and momentary 1 x 40° momentary 1 x 40° opaque white 1.30.073.570/0200 no momentary 2 x 40° opaque white 1.30.073.670/0200 no latching L, 1 x 90° opaque white 1.30.073.520/0200 no latching V, 1 x 90° opaque white 1.30.073.620/0200 no latching 2 x 60° opaque white 1.30.073.720/0200 no latching 1 x 90° and momentary 1 x 40° latching 90°/momentary 40° opaque white 1.30.073.770/0200 0 2 0 2 Technical data see page 2 - 18 Only use contact blocks with "momentary" contact function. For versions with clockwise and counterclockwise rotation, use universal contact blocks only! Other handle marking colours available on request. 2 - 20 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 selector switch, square collar, alignable without gaps Pict.: handle opaque white Illuminability Panel cut-out Contact function Rotating angle Marking of handle Order no. complete yes momentary 1 x 40° translucent white 1.30.073.591/2000 yes momentary 2 x 40° translucent white 1.30.073.691/2000 yes latching L, 1 x 90° translucent white 1.30.073.541/2000 yes latching V, 1 x 90° translucent white 1.30.073.641/2000 yes latching 2 x 60° translucent white 1.30.073.741/2000 yes latching 90°/momentary 40° translucent white 1.30.073.791/2000 no latching 1 x 90° and momentary 1 x 40° momentary 1 x 40° opaque white 1.30.073.590/0200 no momentary 2 x 40° opaque white 1.30.073.690/0200 no latching L, 1 x 90° opaque white 1.30.073.540/0200 no latching V, 1 x 90° opaque white 1.30.073.640/0200 no latching 2 x 60° opaque white 1.30.073.740/0200 no latching 1 x 90° and momentary 1 x 40° latching 90°/momentary 40° opaque white 1.30.073.790/0200 0 2 0 2 Technical data see page 2 - 18 Only use contact blocks with "momentary" contact function. For versions with clockwise and counterclockwise rotation, use universal contact blocks only! Other handle marking colours available on request. Control components Stock items are marked by bold printed order numbers. 2 - 21 2 RAFIX 16 RAFIX 16 RAFIX 16 keylock switch MICROMEC Panel cut-out 2 RAFIX 16 Technical data General information Form of collar see order block Dimensions Length of collar Diameter of collar Key grid Width of collar Overall height Mounting depth Mounting hole see order block see order block 25 x 25 mm see order block 27.95 mm 44.7 mm 16.2 mm Mechanical design Mounting Contact function Contact arrangement Illuminability Lock Wafers Lock type Number of locking positions Main key Symmetric key Rotating angle Key removal position Group key General key ring nut see order block according to contact block no Micromec 5 001 500 yes no see order block see order block yes yes Mechanical characteristics Torque max. 1.3 Nm Electrical characteristics Protection class II Other specifications ESD-strength lock / contact ESD strength key/ front panel Operating life Degree of protection from front side Ambient temp. operating min. Ambient temp. operating without lamp max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment 15 kV 8 kV 65000 IP65 -25 °C +70 °C -40 °C +85 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 Accessories RAFIX 16 keylock switch MICROMEC Description Photo Order no. Page RAFIX 16 universal contact block, 1 NC + 1 NO, momentary, silver contacts, without lamp socket 1.20.123.021/0000 2 - 65 RAFIX 16 universal contact block, 1 NC + 1 NO, momentary, gold contacts, without lamp socket 1.20.123.031/0000 2 - 61 Label holder, flush, for square collar 5.07.620.004/0000 2 - 76 Fixing spanner for hexagon nut 0 5.58.002.034/0000 2 - 75 2 2 - 22 Stock items are marked by bold printed order numbers. Control components RAFIX 16 Accessories RAFIX 16 keylock switch MICROMEC Description Photo Order no. Spare key, black Page 5.58.007.001/0000 For other contact blocks, refer to the chapter „RAFIX 16 contact blocks“; for additional accessories, refer to the chapter „RAFIX 16 special accessories“. RAFIX 16 keylock switch MICROMEC, square collar 2 Panel cut-out Contact function Rotating angle Key removal position Order no. complete momentary 1 x 40° 0 1.30.076.501/0000 momentary 2 x 40° 0 1.30.076.701/0000 latching L, 1 x 90° 0 1.30.076.001/0000 latching L, 1 x 90° 0+1 1.30.076.051/0000 latching V, 1 x 90° 0 1.30.076.101/0000 latching V, 1 x 90° 0+1 1.30.076.151/0000 latching 2 x 90° 0 1.30.076.301/0000 latching 2 x 90° 0+1+2 1.30.076.401/0000 latching 1 x 90°/ momentary 1 x 40° 2 latching 1 x 90° and momentary 1 x 40° 0 1.30.076.901/0000 2 Technical data see page 2 - 22 Only use contact blocks with "momentary" contact function. For versions with clockwise and counterclockwise rotation, use universal contact block only. Included: 2 keys. Control components Stock items are marked by bold printed order numbers. 2 - 23 RAFIX 16 RAFIX 16 RAFIX 16 keylock switch MICROMEC, round collar Panel cut-out Contact function 2 RAFIX 16 Rotating angle Key removal position Order no. complete momentary 1 x 40° 0 1.30.076.521/0000 momentary 2 x 40° 0 1.30.076.721/0000 latching L, 1 x 90° 0 1.30.076.021/0000 latching L, 1 x 90° 0+1 1.30.076.071/0000 latching V, 1 x 90° 0 1.30.076.121/0000 latching V, 1 x 90° 0+1 1.30.076.171/0000 latching 2 x 90° 0 1.30.076.321/0000 latching 2 x 90° 0+1+2 1.30.076.421/0000 latching 1 x 90°/ momentary 1 x 40° 2 latching 1 x 90° and momentary 1 x 40° 0 1.30.076.921/0000 2 Technical data see page 2 - 22 Only use contact blocks with "momentary" contact function. For versions with clockwise and counterclockwise rotation, use universal contact block only. Included: 2 keys. 2 - 24 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 keylock switch MICROMEC, square collar, alignable without gaps Panel cut-out Contact function Rotating angle Key removal position Order no. complete momentary 1 x 40° 0 1.30.076.541/0000 momentary 2 x 40° 0 1.30.076.741/0000 latching L, 1 x 90° 0 1.30.076.041/0000 latching L, 1 x 90° 0+1 1.30.076.091/0000 latching V, 1 x 90° 0 1.30.076.141/0000 latching V, 1 x 90° 0+1 1.30.076.191/0000 latching 2 x 90° 0 1.30.076.341/0000 latching 2 x 90° 0+1+2 1.30.076.441/0000 latching 1 x 90°/ momentary 1 x 40° 2 latching 1 x 90° and momentary 1 x 40° 0 1.30.076.941/0000 2 Technical data see page 2 - 22 Only use contact blocks with "momentary" contact function. For versions with clockwise and counterclockwise rotation, use universal contact block only. Included: 2 keys. Control components Stock items are marked by bold printed order numbers. 2 - 25 2 RAFIX 16 16165-r200-018-D3 2/8/05 12:05 PM Page 2 - 26 RAFIX 16 RAFIX 16 keylock switch, RONIS Panel cut-out 2 RAFIX 16 Technical data General information Form of collar see order block Dimensions Length of collar Diameter of collar Key grid Width of collar Overall height Mounting depth Mounting hole see order block see order block 25 x 25 mm see order block 20.9 mm 44.7 mm 16.2 mm Mechanical design Mounting Contact function Contact arrangement Illuminability Lock Wafers Lock type Number of locking positions Main key Symmetric key Rotating angle Key removal position Group key General key ring nut see order block according to contact block no Ronis 4 455 200 no no see order block see order block no no Mechanical characteristics Robustness min. 100 N Electrical characteristics Protection class II Other specifications ESD-strength lock / contact ESD strength key/ front panel Operating life Degree of protection from front side Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment 15 kV 4 kV 65000 IP65 -25 °C +70 °C -40 °C +85 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 Accessories Keylock switch, RONIS Description Photo Order no. Page RAFIX 16 universal contact block, 1 NC + 1 NO, momentary, silver contacts, without lamp socket 1.20.123.021/0000 2 - 65 RAFIX 16 universal contact block, 1 NC + 1 NO, momentary, gold contacts, without lamp socket 1.20.123.031/0000 2 - 61 Label holder, flush, for square collar 5.07.620.004/0000 2 - 76 Fixing spanner for hexagon nut 5.58.002.034/0000 2 - 75 For other contact blocks, refer to the chapter „RAFIX 16 contact blocks“; for additional accessories, refer to the chapter „RAFIX 16 special accessories“. 2 - 26 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 keylock switch, RONIS, square collar Panel cut-out Contact function Rotating angle Key removal position Order no. complete momentary 1 x 40° 0 1.30.176.501/0000 momentary 2 x 40° 0 1.30.176.701/0000 latching L, 1 x 90° 0 1.30.176.001/0000 latching L, 1 x 90° 0+1 1.30.176.051/0000 latching V, 1 x 90° 0 1.30.176.101/0000 latching V, 1 x 90° 0+1 1.30.176.151/0000 latching 2 x 90° 0 1.30.176.301/0000 latching 2 x 90° 0+1+2 1.30.176.401/0000 Technical data see page 2 - 26 Only use contact blocks with "momentary" contact function. For versions with clockwise and counterclockwise rotation, use universal contact block only. Included: 2 keys. Other lock variants available on request. Control components Stock items are marked by bold printed order numbers. 2 - 27 2 RAFIX 16 RAFIX 16 RAFIX 16 keylock switch, RONIS, round collar Panel cut-out Contact function 2 RAFIX 16 Rotating angle Key removal position Order no. complete momentary 1 x 40° 0 1.30.176.521/0000 momentary 2 x 40° 0 1.30.176.721/0000 latching L, 1 x 90° 0 1.30.176.021/0000 latching L, 1 x 90° 0+1 1.30.176.071/0000 latching V, 1 x 90° 0 1.30.176.121/0000 latching V, 1 x 90° 0+1 1.30.176.171/0000 latching 2 x 90° 0 1.30.176.321/0000 latching 2 x 90° 0+1+2 1.30.176.421/0000 Technical data see page 2 - 26 Only use contact blocks with "momentary" contact function. For versions with clockwise and counterclockwise rotation, use universal contact block only. Included: 2 keys. 2 - 28 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 keylock switch, RONIS, square collar, alignable without gaps Panel cut-out Contact function Rotating angle Key removal position Order no. complete momentary 1 x 40° 0 1.30.176.541/0000 momentary 2 x 40° 0 1.30.176.741/0000 latching L, 1 x 90° 0 1.30.176.041/0000 latching L, 1 x 90° 0+1 1.30.176.091/0000 latching V, 1 x 90° 0 1.30.176.141/0000 latching V, 1 x 90° 0+1 1.30.176.191/0000 latching 2 x 90° 0 1.30.176.341/0000 latching 2 x 90° 0+1+2 1.30.176.441/0000 Technical data see page 2 - 26 Only use contact blocks with "momentary" contact function. For versions with clockwise and counterclockwise rotation, use universal contact block only. Included: 2 keys. Control components Stock items are marked by bold printed order numbers. 2 - 29 2 RAFIX 16 RAFIX 16 RAFIX 16 mushroom-headed pushbutton Pict.: red 2 RAFIX 16 panel cut-out Technical data General information Form of lens Colour of lens Form of collar Mechanical characteristics Operating travel Robustness min. protruding lens see order block see order block Dimensions Length of collar Diameter of collar Key grid Width of collar Overall height Mounting depth Mounting hole see order block see order block 25 x 25 mm see order block 12.1 mm 44.7 mm 16.2 mm Mechanical design Mounting Contact function Contact arrangement Illuminability ring nut according to contact block according to contact block no Other specifications Operating life Degree of protection from front side Ambient temp. operating min. Ambient temp. operating without lamp max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment 3 mm 100 Nm 2000000 IP65 -25 °C +70 °C -40 °C +85 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 Accessories RAFIX 16 mushroom-headed pushbutton Description Photo Order no. Page RAFIX 16 standard contact block, 1 NC + 1 NO, momentary, silver contacts, without lamp socket 1.20.122.021/0000 2 - 64 RAFIX 16 standard contact block, 1 NC + 1 NO, momentary, gold contacts, without lamp socket 1.20.122.031/0000 2 - 60 Label holder, flush, for square collar 5.07.620.004/0000 2 - 76 Fixing spanner for hexagon nut 5.58.002.034/0000 2 - 75 For other contact blocks, refer to the chapter „RAFIX 16 contact blocks“; for additional accessories, refer to the chapter „RAFIX 16 special accessories“. 2 - 30 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 mushroom-headed pushbutton, square collar Pict.: red panel cut-out Illuminability Colour of lens Order no. complete no opaque black 1.30.071.001/0100 no opaque red 1.30.071.001/0300 2 Technical data see page 2 - 30 For the "latching" function, please use the standard contact block with "latching" function. RAFIX 16 RAFIX 16 mushroom-headed pushbutton, round collar Pict.: red panel cut-out Illuminability Colour of lens Order no. complete no opaque black 1.30.071.021/0100 no opaque red 1.30.071.021/0300 Technical data see page 2 - 30 For the "latching" function, please use the standard contact block with "latching" function. Control components Stock items are marked by bold printed order numbers. 2 - 31 RAFIX 16 RAFIX 16 mushroom-headed pushbutton, square collar, alignable without gaps Pict.: red 2 panel cut-out Illuminability Colour of lens Order no. complete no opaque black 1.30.071.041/0100 no opaque red 1.30.071.041/0300 Technical data see page 2 - 30 For the "latching" function, please use the standard contact block with "latching" function. RAFIX 16 2 - 32 Stock items are marked by bold printed order numbers. Control components 16165-r200-030-E1 2/8/05 11:39 AM Page 2 - 34 RAFIX 16 RAFIX 16 emergency stop pushbutton panel cut-out 2 RAFIX 16 Technical data General information Form of button Colour of button Form of collar see order block see order block see order block Dimensions Length of collar Diameter of collar Key grid Width of collar Overall height Mounting depth Mounting hole see order block see order block 25 x 25 mm see order block see order block 44.7 mm 16.2 mm Mechanical design Mounting Contact function Contact arrangement Illuminability Mechanical characteristics Robustness min. Robustness Other specifications Operating life Degree of protection from front side Ambient temp. operating min. Ambient temp. operating without lamp max. Ambient temp. operating with lamp max. Storage temperature min. Storage temperature max. Resistance to constant environment ring nut latching according to contact block see order block Resistance at variable environment Corresponding to CE Ma-Dir. 89/392 Approvals 30000 IP65 -25 °C +70 °C +55 °C -40 °C +85 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 yes IEC 60204, IEC 73 100 N acc. IEC 60947-5-5 Accessories RAFIX 16 emergency stop pushbutton Description Photo Order no. Page RAFIX 16 universal contact block, 1 NC, momentary, silver contacts, without lamp socket 1.20.123.022/0000 2 - 65 RAFIX 16 universal contact block, 1 NC, momentary, gold contacts, without lamp socket 1.20.123.032/0000 2 - 61 Fixing spanner for hexagon nut 5.58.002.034/0000 2 - 75 Emergency stop label, yellow, round 60 mm, PVC adhesive, without legend 5.76.204.400/0400 2 - 77 For suitable LEDs, filament lamps and other contact blocks, refer to the chapter „RAFIX 16 contact blocks“; for additional accessories, refer to the chapter „RAFIX 16 special accessories“. 2 - 34 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 emergency stop pushbutton, square collar, illuminated Pict.: red panel cut-out Illuminability Colour of button Order no. complete yes translucent red 1.30.074.501/0304 2 Technical data see page 2 - 34 Only use universal contact blocks. RAFIX 16 RAFIX 16 emergency stop pushbutton, square collar, dupe-proof Pict.: red panel cut-out Illuminability Colour of button Order no. complete no opaque red 1.30.074.101/0301 Technical data see page 2 - 34 Only use universal contact blocks. The positively driven mechanical arrangement is dupe-proof to EN 418. Control components Stock items are marked by bold printed order numbers. 2 - 35 RAFIX 16 RAFIX 16 emergency stop pushbutton, round collar, illuminated Pict.: red 2 panel cut-out Illuminability Colour of button Order no. complete yes translucent red 1.30.074.521/0304 Technical data see page 2 - 34 Only use universal contact blocks. RAFIX 16 RAFIX 16 emergency stop pushbutton, round collar, dupe-proof Pict.: red panel cut-out Illuminability Colour of button Order no. complete no opaque red 1.30.074.121/0301 Technical data see page 2 - 34 Only use universal contact blocks. The positively driven mechanical arrangement is dupe-proof to EN 418. 2 - 36 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 emergency stop pushbutton, square collar, alignable without gaps, illuminated Pict.: red panel cut-out Illuminability Colour of button Order no. complete yes translucent red 1.30.074.541/0304 2 Technical data see page 2 - 34 Only use universal contact blocks. RAFIX 16 RAFIX 16 emergency stop pushbutton, square collar, alignable without gaps, dupe-proof Pict.: red panel cut-out Illuminability Colour of button Order no. complete no opaque red 1.30.074.141/0301 Technical data see page 2 - 34 Only use universal contact blocks. The positively driven mechanical arrangement is dupe-proof to EN 418. Control components Stock items are marked by bold printed order numbers. 2 - 37 16165-r200-030-E1 2/8/05 11:51 AM Page 2 - 38 RAFIX 16 RAFIX 16 safety emergency stop pushbutton, round collar, dupe-proof, non-blocking panel cut-out 2 Illuminability Colour of button Order no. complete no opaque red, collar yellow 1.30.074.821/0000 Technical data see page 2 - 34 Only use universal contact blocks. The positively driven mechanical arrangement is dupe-proof to EN 418. Special shape prevents blocking: Actuation cannot be interrupted by any jamming objects. RAFIX 16 RAFIX 16 safety emergency stop pushbutton, round collar, conical, dupe-proof, non-blocking panel cut-out Illuminability Colour of button Order no. complete no opaque red, collar yellow 1.30.074.281/0300 Technical data see page 2 - 34 Only use universal contact blocks. The positively driven mechanical arrangement is dupe-proof to EN 418. 2 - 38 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 toggle switch Pict.: red 2 RAFIX 16 Panel cut-out Technical data Mechanical characteristics Robustness min. General information Form of lens Colour of toggle Form of collar toggle see order block see order block Dimensions Length of collar Diameter of collar Key grid Width of collar Overall height Mounting depth Mounting hole see order block see order block 25 x 25 mm see order block 18.4 mm 44.7 mm 16.2 mm Mechanical design Mounting Contact function Contact arrangement Illuminability ring nut latching according to contact block no Other specifications Degree of protection from front side Ambient temp. operating min. Ambient temp. operating without lamp max. Ambient temp. operating with lamp max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment Operating life (operations) 100 N IP65 -25 °C +70 °C +55 °C -40 °C +85 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 300000 Accessories RAFIX 16 toggle switch Description Photo Order no. Page RAFIX 16 standard contact block, 1 NC + 1 NO, momentary, silver contacts, without lamp socket 1.20.122.021/0000 2 - 64 RAFIX 16 standard contact block, 1 NC + 1 NO, momentary, gold contacts, without lamp socket 1.20.122.031/0000 2 - 60 Label holder, flush, for square collar 5.07.620.004/0000 2 - 76 Fixing spanner for hexagon nut 5.58.002.034/0000 2 - 75 For other contact blocks, refer to the chapter „RAFIX 16 contact blocks“; for additional accessories, refer to the chapter „RAFIX 16 special accessories“. 2 - 40 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 toggle switch, square collar Pict.: black toggle Einbauöffung Contact function Illuminability Colour of toggle Order no. complete latching no opaque black 1.30.075.001/0100 latching no opaque red 1.30.075.001/0300 2 Technical data see page 2 - 40 Only use contact blocks with "momentary" contact function. RAFIX 16 RAFIX 16 toggle switch, round collar Pict.: black toggle Einbauöffung Contact function Illuminability Colour of toggle Order no. complete latching no opaque black 1.30.075.021/0100 latching no opaque red 1.30.075.021/0300 Technical data see page 2 - 40 Only use contact blocks with "momentary" contact function. Control components Stock items are marked by bold printed order numbers. 2 - 41 RAFIX 16 RAFIX 16 toggle switch, square collar, alignable without gaps Pict.: red toggle 2 Einbauöffung Contact function Illuminability Colour of toggle Order no. complete latching no opaque black 1.30.075.041/0100 latching no opaque red 1.30.075.041/0300 Technical data see page 2 - 40 Only use contact blocks with "momentary" contact function. RAFIX 16 2 - 42 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 potentiometer drive Pict.: with potentiometer (not included) 2 RAFIX 16 Einbauöffung Technical data General information Form of lens Colour of handle Form of collar handle black see order block Dimensions Length of collar Diameter of collar Key grid Width of collar Overall height Mounting depth Mounting hole see order block see order block 25 x 25 mm see order block 23.65 mm 19.2 mm 16.2 mm Mechanical design Mounting ring nut Other specifications Degree of protection from front side Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment IP65 -25 °C +70 °C -40 °C +85 °C IEC 600 68-2-3 and 2-30 IEC 600 68-2-14 and 2-33 Accessories Potentiometer drive Description Photo Order no. Page Label holder, flush, for square collar 5.07.620.004/0000 2 - 76 Fixing spanner for hexagon nut 5.58.002.034/0000 2 - 75 For additional accessories, refer to the chapter „RAFIX 16 special accessories“. 2 - 44 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 potentiometer drive, square collar Pict.: with potentiometer (not included) Einbauöffung Form of lens Form of collar Colour of handle Order no. complete handle square black 1.30.077.001/0000 2 Technical data see page 2 - 44 To operate potentiometers with a shaft diameter of 6 mm. Suitable for potentiometers to DIN 41 450 with a shaft length of 32 mm. Potentiometer not included. RAFIX 16 RAFIX 16 potentiometer drive, round collar Pict.: with potentiometer (not included) Einbauöffung Form of lens Form of collar Colour of handle Order no. complete handle round black 1.30.077.021/0000 Technical data see page 2 - 44 To operate potentiometers with a shaft diameter of 6 mm. Suitable for potentiometers to DIN 41 450 with a shaft length of 32 mm. Potentiometer not included. Control components Stock items are marked by bold printed order numbers. 2 - 45 RAFIX 16 RAFIX 16 potentiometer drive, square collar, alignable without gaps Einbauöffung 2 Form of lens Form of collar Colour of handle Order no. complete handle square alignable black 1.30.077.041/0000 Technical data see page 2 - 44 To operate potentiometers with a shaft diameter of 6 mm. Suitable for potentiometers to DIN 41 450 with a shaft length of 32 mm. Potentiometer not included. RAFIX 16 2 - 46 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 buzzer Panel cut-out 2 RAFIX 16 Technical data General information Form of lens Colour of lens Form of collar Sound flat lens opaque black see order block see order block Dimensions Length of collar Diameter of collar Key grid Width of collar Overall height Mounting depth Mounting hole see order block see order block 25 x 25 mm see order block 6.95 mm 30.5 mm 16.2 mm Mechanical design Mounting ring nut Acoustic characteristics Sonic pressure, 1 m distance min. see order block Electrical characteristics Operating voltage DC Input current 24 V see order block Mechanical characteristics Robustness min. 100 N Other specifications Degree of protection from front side Ambient temp. operating min. Ambient temp. operating max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment IP65 -25 °C +70 °C -40 °C +85 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 Accessories RAFIX 16 buzzer Description Photo Fixing spanner for hexagon nut Order no. Page 5.58.002.034/0000 2 - 75 For additional accessories, refer to the chapter „RAFIX 16 special accessories“. 2 - 48 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 buzzer, square collar Einbauöffung Sound Operating voltage DC Input current Sonic pressure, 1 m distance min. Order no. complete continuos beep 24 V 25 mA 70 dB 1.30.078.001/0100 2 Technical data see page 2 - 48 12 V DC available on request. RAFIX 16 RAFIX 16 buzzer, round collar Einbauöffung Sound Operating voltage DC Input current Sonic pressure, 1 m distance min. Order no. complete continuos beep 24 V 25 mA 70 dB 1.30.078.021/0100 Technical data see page 2 - 48 12 V DC available on request. Control components Stock items are marked by bold printed order numbers. 2 - 49 RAFIX 16 RAFIX 16 buzzer, square collar, alignable without gaps Einbauöffung 2 Sound Operating voltage DC Input current Sonic pressure, 1 m distance min. Order no. complete continuos beep 24 V 25 mA 70 dB 1.30.078.041/0100 Technical data see page 2 - 48 12 V DC available on request. RAFIX 16 2 - 50 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 signal indicator indicator with lamp socket 2 RAFIX 16 panel cut-out Technical data General information Form of lens Colour of lens Form of collar Other specifications Degree of protection from front side Ambient temp. operating min. Ambient temp. operating without lamp max. Ambient temp. operating with lamp max. Storage temperature min. Storage temperature max. Resistance to constant environment see order block see order block see order block Dimensions Length of collar Diameter of collar Key grid Width of collar Overall height Mounting depth Mounting hole see order block see order block 25 x 25 mm see order block see order block 30.5/44.7 mm 16.2 mm Mechanical design Mounting Illuminability ring nut yes Mechanical characteristics Robustness min. 100 N Resistance at variable environment IP65 -25 °C +70 °C +55 °C -40 °C +85 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 Accessories RAFIX 16 signal indicator Description Photo Order no. Page RAFIX 16 lamp socket W 2 x 4.6 d 1.71.212.001/0000 2 - 67 RAFIX 16 lamp socket W 2 x 4.6 d 1.71.212.011/0000 2 - 68 LED W 2 x 4.6d superbright, white, 24 V 1.90.690.365/0000 5 - 16 Disassembly tool for LUMOTAST 25, RAFIX 16 5.05.800.042/0000 2 - 74 5 - 26 Label holder, flush, for square collar 5.07.620.004/0000 2 - 76 Fixing spanner for hexagon nut 5.58.002.034/0000 2 - 75 For suitable LEDs and filament lamps, refer to the chapter „RAFIX 16 lamp sockets“; for additional accessories, refer to the chapter „RAFIX 16 special accessories“. 2 - 52 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 signal indicator, square lens Pict.: green Form of lens panel cut-out Form of collar Colour of lens Order no. complete Order no. single parts Housing lens square Lens 1.65.124.001/1002 1.65.124.101/0000 5.49.263.006/1002 lens square transparent colourless transparent red lens square transparent yellow 1.65.124.001/1403 1.65.124.101/0000 5.49.263.006/1403 lens square transparent green 1.65.124.001/1505 1.65.124.101/0000 5.49.263.006/1505 lens square transparent blue 1.65.124.001/1607 1.65.124.101/0000 5.49.263.006/1607 1.65.124.001/1306 1.65.124.101/0000 5.49.263.006/1306 Technical data see page 2 - 52 Legending can only be made externally on a label holder. RAFIX 16 signal indicator, square collar, flush lens Pict.: colourless Form of lens panel cut-out Form of collar Colour of lens Order no. complete Order no. single parts Housing flat lens square flat lens Lens 1.65.124.301/1002 1.65.124.401/0000 5.49.077.011/1002 square transparent colourless transparent red flat lens square transparent yellow 1.65.124.301/1403 1.65.124.401/0000 5.49.077.011/1403 flat lens square transparent green 1.65.124.301/1505 1.65.124.401/0000 5.49.077.011/1505 flat lens square transparent blue 1.65.124.301/1607 1.65.124.401/0000 5.49.077.011/1607 1.65.124.301/1306 1.65.124.401/0000 5.49.077.011/1306 Technical data see page 2 - 52 Accessories: Legend insert, blank, use only for transparent lenses: 5.70.635.000/2000 Control components Stock items are marked by bold printed order numbers. 2 - 53 2 RAFIX 16 RAFIX 16 RAFIX 16 signal indicator, square collar, protruding lens Pict.: red Form of lens panel cut-out Form of collar Colour of lens Order no. complete Order no. single parts Housing 2 RAFIX 16 protruding lens square protruding lens Lens 1.65.124.351/1002 1.65.124.451/0000 5.49.077.012/1002 square transparent colourless transparent red protruding lens square transparent yellow 1.65.124.351/1403 1.65.124.451/0000 5.49.077.012/1403 protruding lens square transparent green 1.65.124.351/1505 1.65.124.451/0000 5.49.077.012/1505 protruding lens square transparent blue 1.65.124.351/1607 1.65.124.451/0000 5.49.077.012/1607 1.65.124.351/1306 1.65.124.451/0000 5.49.077.012/1306 Technical data see page 2 - 52 Accessories: Legend insert, blank, use only for transparent lenses: 5.70.635.000/2000 RAFIX 16 signal indicator, round lens Pict.: yellow Form of lens panel cut-out Form of collar Colour of lens Order no. complete Order no. single parts Housing lens round round lens round Lens 1.65.124.021/1002 1.65.124.101/0000 5.49.263.007/1002 round transparent colourless transparent red lens round round transparent yellow 1.65.124.021/1403 1.65.124.101/0000 5.49.263.007/1403 lens round round transparent green 1.65.124.021/1505 1.65.124.101/0000 5.49.263.007/1505 lens round round transparent blue 1.65.124.021/1607 1.65.124.101/0000 5.49.263.007/1607 1.65.124.021/1306 1.65.124.101/0000 5.49.263.007/1306 Technical data see page 2 - 52 Accessories: Legending can only be made externally on a label holder. 2 - 54 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 signal indicator, round collar, flush lens Pict.: yellow Form of lens panel cut-out Form of collar Colour of lens Order no. complete Order no. single parts Housing flat lens round flat lens Lens 1.65.124.321/1002 1.65.124.421/0000 5.49.259.017/1002 round transparent colourless transparent red flat lens round transparent yellow 1.65.124.321/1403 1.65.124.421/0000 5.49.259.017/1403 flat lens round transparent green 1.65.124.321/1505 1.65.124.421/0000 5.49.259.017/1505 flat lens round transparent blue 1.65.124.321/1607 1.65.124.421/0000 5.49.259.017/1607 1.65.124.321/1306 1.65.124.421/0000 5.49.259.017/1306 Technical data see page 2 - 52 Accessories: Legend insert, blank, use only for transparent lenses: 5.70.637.000/2000 RAFIX 16 signal indicator, round collar, protruding lens Pict.: yellow Form of lens panel cut-out Form of collar Colour of lens Order no. complete Order no. single parts Housing protruding lens round protruding lens Lens 1.65.124.371/1002 1.65.124.471/0000 5.49.259.018/1002 round transparent colourless transparent red protruding lens round transparent yellow 1.65.124.371/1403 1.65.124.471/0000 5.49.259.018/1403 protruding lens round transparent green 1.65.124.371/1505 1.65.124.471/0000 5.49.259.018/1505 protruding lens round transparent blue 1.65.124.371/1607 1.65.124.471/0000 5.49.259.018/1607 1.65.124.371/1306 1.65.124.471/0000 5.49.259.018/1306 Technical data see page 2 - 52 Accessories: Legend insert, blank, use only for transparent lenses: 5.70.637.000/2000 Control components Stock items are marked by bold printed order numbers. 2 - 55 2 RAFIX 16 RAFIX 16 RAFIX 16 signal indicator, square collar, alignable without gaps, flush lens Pict.: green Form of lens panel cut-out Form of collar Colour of lens Order no. complete Order no. single parts Housing 2 RAFIX 16 flat lens square alignable flat lens Lens 1.65.124.551/1002 1.65.124.651/0000 5.49.077.011/1002 square alignable transparent colourless transparent red flat lens square alignable transparent yellow 1.65.124.551/1403 1.65.124.651/0000 5.49.077.011/1403 flat lens square alignable transparent green 1.65.124.551/1505 1.65.124.651/0000 5.49.077.011/1505 flat lens square alignable transparent blue 1.65.124.551/1607 1.65.124.651/0000 5.49.077.011/1607 1.65.124.551/1306 1.65.124.651/0000 5.49.077.011/1306 Technical data see page 2 - 52 Accessories: Legend insert, blank, use only for transparent lenses: 5.70.635.000/2000 RAFIX 16 signal indicator, square collar, alignable without gaps, protruding lens panel cut-out Form of lens Form of collar Colour of lens Order no. complete Order no. single parts Housing protruding lens square alignable protruding lens Lens 1.65.124.501/1002 1.65.124.661/0000 5.49.077.012/1002 square alignable transparent colourless transparent red protruding lens square alignable transparent yellow 1.65.124.501/1403 1.65.124.661/0000 5.49.077.012/1403 protruding lens square alignable transparent green 1.65.124.501/1505 1.65.124.661/0000 5.49.077.012/1505 protruding lens square alignable transparent blue 1.65.124.501/1607 1.65.124.661/0000 5.49.077.012/1607 1.65.124.501/1306 1.65.124.661/0000 5.49.077.012/1306 Technical data see page 2 - 52 Accessories: Legend insert, blank, use only for transparent lenses: 5.70.635.000/2000 2 - 56 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 contact blocks with gold contacts actuator with contact block 2 RAFIX 16 Technical data Dimensions Length Width Height Mounting depth (with actuator / indicator) Mechanical design Mounting Contact system Contact materials Contact arrangement Contact function Lamp socket Terminals Terminal marking Operating travel Robustness Mechanical characteristics Robustness Electrical characteristics Rated voltage min. Rated voltage max. (AC/DC) Rated current min. Rated current max. Operating life switching element (momentary) Contact resistance when new max. 22.2 mm 22.2 mm 34.4 mm 44.7 mm snap on actuator bridgecontact self cleaning Au see order block see order block see order block quick connector 2.8 x 0.8 according to DIN 50013, X1 = +, X2 = 3 mm 100 N acc. IEC 60947-5-5 0.02 V Other specifications Protection class Shock resistance acc. to IEC 60068-2-27 Ambient temp. operating min. Ambient temp. operating without lamp max. Ambient temp. operating with lamp max. Storage temperature min. Storage temperature max. Colour code Resistance to constant environment Resistance at variable environment Mechanical operating life latching (operations) Resistance to vibrations acc. to IEC 60068-2-6 2000000 50 mΩ II amplitude < 50g, 11ms, half sinusoidal -25 °C +70 °C +55 °C -40 °C +85 °C white bottom IEC 600 68-2-3 and 2-30 IEC 600 68-2-14 and 2-33 see order block 10 g at 20 ... 500 Hz 42 V 0.001 A 0.25 A Accessories RAFIX 16 contact blocks with gold contacts Description Photo Order no. Page Filament lamp, W 2 x 4.6d base, 24 - 30 V 1.90.120.005/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 60 V 1.90.120.009/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 48 V 1.90.120.010/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 24 V 1.90.120.011/0000 5 - 4 2 - 58 Stock items are marked by bold printed order numbers. Control components RAFIX 16 Accessories RAFIX 16 contact blocks with gold contacts Description Photo Order no. Page Filament lamp, W 2 x 4.6d base, 12 V 1.90.120.012/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 6 V 1.90.120.013/0000 5 - 4 LED W 2 x 4.6d superbright, red, 24 V 1.90.690.361/0000 5 - 16 LED W 2 x 4.6d superbright, green, 24 V 1.90.690.362/0000 5 - 16 LED W 2 x 4.6d superbright, yellow, 24 V 1.90.690.363/0000 5 - 16 LED W 2 x 4.6d superbright, blue, 24 V 1.90.690.364/0000 5 - 16 LED W 2 x 4.6d superbright, white, 24 V 1.90.690.365/0000 5 - 16 Multipole connector 5.05.510.421/0000 2 - 71 PCB plug-in socket, 10 contacts (universal application) 5.05.510.644/0000 2 - 70 Female quick-connect terminal DIN 46340-B 2.8-1-MS 5.37.540.024/8622 2 - 71 Plug distributor 5.37.540.029/6000 2 - 72 Protection against contact 5.55.103.105/0100 2 - 72 Control components Stock items are marked by bold printed order numbers. 2 RAFIX 16 2 - 59 RAFIX 16 RAFIX 16 standard contact block, gold contacts, with lamp socket actuator with contact block 2 RAFIX 16 Contact function Contact arrangement Lamp socket Rated voltage max. (AC/DC) Rated current max. Order no. complete momentary 1 NC + 1 NO W 2 x 4.6d 42 V 0.25 A 1.20.122.011/0000 momentary 2 NO W 2 x 4.6d 42 V 0.25 A 1.20.122.012/0000 momentary 2 NC W 2 x 4.6d 42 V 0.25 A 1.20.122.013/0000 latching 1 NC + 1 NO W 2 x 4.6d 42 V 0.25 A 1.20.122.051/0000 latching 2 NO W 2 x 4.6d 42 V 0.25 A 1.20.122.052/0000 Technical data see page 2 - 58 Standard contact blocks have one common contact chamber and one actuator plunger. Contact blocks with "latching" contact function are used as switches. When combined with pushbuttons and mushroom actuators, the switching position is visible, releasing is effected by actuating again. RAFIX 16 standard contact block, gold contacts, without lamp socket actuator with contact block Contact function Contact arrangement Lamp socket Rated voltage max. (AC/DC) Rated current max. Order no. complete momentary 1 NC + 1 NO 42 V 0.25 A 1.20.122.031/0000 momentary 2 NO 42 V 0.25 A 1.20.122.032/0000 momentary 2 NC 42 V 0.25 A 1.20.122.033/0000 latching 1 NC + 1 NO 42 V 0.25 A 1.20.122.071/0000 latching 2 NO 42 V 0.25 A 1.20.122.072/0000 Technical data see page 2 - 58 Standard contact blocks have one common contact chamber and one actuator plunger. Contact blocks with "latching" contact function are used as switches. When combined with pushbuttons and mushroom actuators, the switching position is visible, releasing is effected by actuating again. 2 - 60 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 universal contact block, gold contacts, with lamp socket actuator with contact block Contact function Contact arrangement Lamp socket Rated voltage max. (AC/DC) Rated current max. Order no. complete momentary 1 NC + 1 NO W 2 x 4.6d 42 V 0.25 A 1.20.123.011/0000 momentary 1 NC W 2 x 4.6d 42 V 0.25 A 1.20.123.012/0000 momentary 1 NO W 2 x 4.6d 42 V 0.25 A 1.20.123.013/0000 momentary 2 NC W 2 x 4.6d 42 V 0.25 A 1.20.123.014/0000 momentary 2 NO W 2 x 4.6d 42 V 0.25 A 1.20.123.015/0000 Technical data see page 2 - 58 Universal contact blocks have two separate contact chambers and two actuator plungers for alternating actuation directions. Two different polarities can be switched. The NC contacts are positive opening contacts to IEC 60947-5-1. RAFIX 16 universal contact block, gold contacts, without lamp socket actuator with contact block Contact function Contact arrangement Lamp socket Rated voltage max. (AC/DC) Rated current max. Order no. complete momentary 1 NC + 1 NO 42 V 0.25 A 1.20.123.031/0000 momentary 1 NC 42 V 0.25 A 1.20.123.032/0000 momentary 1 NO 42 V 0.25 A 1.20.123.033/0000 momentary 2 NC 42 V 0.25 A 1.20.123.034/0000 momentary 2 NO 42 V 0.25 A 1.20.123.035/0000 Technical data see page 2 - 58 Universal contact blocks have two separate contact chambers and two actuator plungers for alternating actuation directions. Two different polarities can be switched. The NC contacts are positive opening contacts to IEC 60947-5-1. Control components Stock items are marked by bold printed order numbers. 2 - 61 2 RAFIX 16 RAFIX 16 RAFIX 16 contact blocks with silver contacts with contact block 2 RAFIX 16 Technical data Dimensions Length Width Height Mounting depth (with actuator / indicator) Mechanical design Mounting Contact system Thermic rated current Ithe , AC Thermic rated current Ithe , DC Operating life switching element AC Operating life switching element DC 22.2 mm 22.2 mm 34.4 mm 44.7 mm Operating travel Robustness snap on actuator bridgecontact self cleaning Ag see order block see order block see order block quick connector 2.8 x 0.8 according to DIN 50013, X1 = +, X2 = 3 mm 100 N Mechanical characteristics Robustness acc. IEC 60947-5-5 Contact materials Contact arrangement Contact function Lamp socket Terminals Terminal marking Electrical characteristics Rated insulation voltage acc. to VDE 0110, AC Rated insulation voltage acc. to VDE 0110, DC Ohmic rated current IR Rated motor current IM nenn Application category acc. to VDE 0660 Teil 200 Application category acc. to VDE 0660 Teil 200 Rated insulation voltage UI , AC Rated insulation voltage UI , DC Rated voltage UE / Rated current IE , AC Rated voltage UE / Rated current IE ,DAC 2 - 62 Rated power DC Rated power AC Contact resistance when new max. Other specifications Protection class Approvals Corresponding to EU directive N 72/73 Shock resistance acc. to IEC 60068-2-27 Ambient temp. operating min. Ambient temp. operating without lamp max. Ambient temp. operating with lamp max. Storage temperature min. Storage temperature max. Colour code Resistance to constant environment 250 V 300 V 6A 4A AC 15B 300 V Resistance at variable environment DC 13Q 300 V 250 V 300 V 250 V/1,5 A, 120 V/3,0 A V 250 V/0,27 A, 125 V/0,55 A, 60 V/1 A, 24 V/2 A V Mechanical operating life latching (operations) Resistance to vibrations acc. to IEC 60068-2-6 Flame class acc. to UL 94 Hot wire ignition acc. to IEC 60695-2-1 Stock items are marked by bold printed order numbers. 5A 2.5 A 100000 at 6A, 800000 at 2A 250000 at 220 V/0.2 A, 1000000 at 24 V/2 A 10 x IE 1.1 x IE 20 mΩ II ENEC 25 T 70 (55), UL, CSA yes amplitude < 50g, 11ms, half sinusoidal -25 °C +70 °C +55 °C -40 °C +85 °C grey bottom according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 100000 10 g at 20 ... 500 Hz V0 yes Control components RAFIX 16 Accessories RAFIX 16 contact blocks with silver contacts Description Photo Order no. Page Filament lamp, W 2 x 4.6d base, 24 - 30 V 1.90.120.005/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 60 V 1.90.120.009/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 48 V 1.90.120.010/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 24 V 1.90.120.011/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 12 V 1.90.120.012/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 6 V 1.90.120.013/0000 5 - 4 LED W 2 x 4.6d superbright, red, 24 V 1.90.690.361/0000 5 - 16 LED W 2 x 4.6d superbright, green, 24 V 1.90.690.362/0000 5 - 16 LED W 2 x 4.6d superbright, yellow, 24 V 1.90.690.363/0000 5 - 16 LED W 2 x 4.6d superbright, blue, 24 V 1.90.690.364/0000 5 - 16 LED W 2 x 4.6d superbright, white, 24 V 1.90.690.365/0000 5 - 16 Multipole connector 5.05.510.421/0000 2 - 71 PCB plug-in socket, 10 contacts (universal application) 5.05.510.644/0000 2 - 70 Female quick-connect terminal DIN 46340-B 2.8-1-MS 5.37.540.024/8622 2 - 71 Plug distributor 5.37.540.029/6000 2 - 72 Protection against contact 5.55.103.105/0100 2 - 72 Control components Stock items are marked by bold printed order numbers. 2 RAFIX 16 2 - 63 RAFIX 16 RAFIX 16 standard contact block, silver contacts, with lamp socket actuator with contact block 2 RAFIX 16 Contact function Contact arrangement Lamp socket Rated insulation voltage UI , AC Ohmic rated current IR Order no. complete momentary 1 NC + 1 NO W 2 x 4.6d 250 V 6A 1.20.122.001/0000 momentary 2 NO W 2 x 4.6d 250 V 6A 1.20.122.002/0000 momentary 2 NC W 2 x 4.6d 250 V 6A 1.20.122.003/0000 latching 1 NC + 1 NO W 2 x 4.6d 250 V 6A 1.20.122.041/0000 latching 2 NO W 2 x 4.6d 250 V 6A 1.20.122.042/0000 Technical data see page 2 - 62 Standard contact blocks have one common contact chamber and one actuator plunger. Contact blocks with „latching“ contact function are used as switches. When combined with pushbuttons and mushroom actuators, the switching position is visible, releasing is effected by actuating again. RAFIX 16 standard contact block, silver contacts, without lamp socket actuator with contact block Contact function Contact arrangement Lamp socket Rated insulation voltage UI , AC Ohmic rated current IR Order no. complete momentary 1 NC + 1 NO 250 V 6A 1.20.122.021/0000 momentary 2 NO 250 V 6A 1.20.122.022/0000 momentary 2 NC 250 V 6A 1.20.122.023/0000 latching 1 NC + 1 NO 250 V 6A 1.20.122.061/0000 latching 2 NO 250 V 6A 1.20.122.062/0000 Technical data see page 2 - 62 Standard contact blocks have one common contact chamber and one actuator plunger. Contact blocks with „latching“ contact function are used as switches. When combined with pushbuttons and mushroom actuators, the switching position is visible, releasing is effected by actuating again. 2 - 64 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 universal contact block, silver contacts, with lamp socket actuator with contact block Contact function Contact arrangement Lamp socket Rated insulation voltage UI , AC Ohmic rated current IR Order no. complete momentary 1 NC + 1 NO W 2 x 4.6d 250 V 6A 1.20.123.001/0000 momentary 1 NC W 2 x 4.6d 250 V 6A 1.20.123.002/0000 momentary 1 NO W 2 x 4.6d 250 V 6A 1.20.123.003/0000 momentary 2 NC W 2 x 4.6d 250 V 6A 1.20.123.004/0000 momentary 2 NO W 2 x 4.6d 250 V 6A 1.20.123.005/0000 Technical data see page 2 - 62 Universal contact blocks have two separate contact chambers and two actuator plungers. This makes it possible to switch two different polarities. The NC contacts are positive opening contacts to IEC 60947-5-1. RAFIX 16 universal contact block, silver contacts, without lamp socket actuator with contact block Contact function Contact arrangement Lamp socket Rated insulation voltage UI , AC Ohmic rated current IR Order no. complete momentary 1 NC + 1 NO 250 V 6A 1.20.123.021/0000 momentary 1 NC 250 V 6A 1.20.123.022/0000 momentary 1 NO 250 V 6A 1.20.123.023/0000 momentary 2 NC 250 V 6A 1.20.123.024/0000 momentary 2 NO 250 V 6A 1.20.123.025/0000 Technical data see page 2 - 62 Universal contact blocks have two separate contact chambers and two actuator plungers. This makes it possible to switch two different polarities. The NC contacts are positive opening contacts to IEC 60947-5-1. Control components Stock items are marked by bold printed order numbers. 2 - 65 2 RAFIX 16 RAFIX 16 RAFIX 16 lamp socket indicator with lamp socket 2 RAFIX 16 Technical data Shock resistance acc. to IEC 60068-2-27 Dimensions Length Width Height Mounting depth see order block see order block see order block see order block Mechanical design Mounting Lamp socket Terminals Terminal marking Robustness see order block wedge-base W 2 x 4.6d quick connector 2.8 x 0.8 X1 = anode, X2 = cathode 100 N Electrical characteristics Rated voltage max. Rated power max. Other specifications Approvals Ambient temp. operating min. Ambient temp. operating with lamp max. Storage temperature min. Storage temperature max. Resistance to constant environment Resistance at variable environment 60 V 1.2 W ENEC 25 T 70 (55), UL, CSA Flame class acc. to UL 94 Hot wire ignition acc. to IEC 60695-2-1 Resistance to vibrations acc. to IEC 60068-2-6 amplitude < 50g, D 11ms, half sinusoidal -25 °C +55 °C -40 °C +85 °C according to IEC 600 68-2-3 and 2-30 according to IEC 600 68-2-14 and 2-33 V0 yes 10 g at 20 ... 500 Hz Accessories RAFIX 16 lamp socket Description Photo Order no. Page Filament lamp, W 2 x 4.6d base, 24 - 30 V 1.90.120.005/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 60 V 1.90.120.009/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 48 V 1.90.120.010/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 24 V 1.90.120.011/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 12 V 1.90.120.012/0000 5 - 4 Filament lamp, W 2 x 4.6d base, 6 V 1.90.120.013/0000 5 - 4 LED W 2 x 4.6d superbright, red, 24 V 1.90.690.361/0000 5 - 16 2 - 66 Stock items are marked by bold printed order numbers. Control components RAFIX 16 Accessories RAFIX 16 lamp socket Description Photo Order no. Page LED W 2 x 4.6d superbright, green, 24 V 1.90.690.362/0000 5 - 16 LED W 2 x 4.6d superbright, yellow, 24 V 1.90.690.363/0000 5 - 16 LED W 2 x 4.6d superbright, blue, 24 V 1.90.690.364/0000 5 - 16 LED W 2 x 4.6d superbright, white, 24 V 1.90.690.365/0000 5 - 16 PCB plug-in socket, 2 contacts (lamp socket) 5.05.510.649/0000 2 - 70 Protection against contact 5.55.103.105/0100 2 - 72 2 RAFIX 16 RAFIX 16 lamp socket W 2 x 4.6 d with contact block Rated voltage max. Rated power max. Lamp socket Mounting Mounting depth Order no. complete 60 V 1.2 W wedge-base W 2 x 4.6d click on signal indicator 44.7 mm 1.71.212.001/0000 Technical data see page 2 - 66 A notch on the lamp socket identifies the cathode side. Control components Stock items are marked by bold printed order numbers. 2 - 67 RAFIX 16 RAFIX 16 lamp socket W 2 x 4.6 d 2 Rated voltage max. Rated power max. Lamp socket Mounting Mounting depth Order no. complete 60 V 1.2 W wedge-base W 2 x 4.6d snap into signal indicator 30.5 mm 1.71.212.011/0000 Technical data see page 2 - 66 A notch on the lamp socket identifies the cathode side. RAFIX 16 2 - 68 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 special accessories 2 PCB plug-in socket RAFIX 16 Short text Feature 1 Feature 2 Order no. PCB plug-in socket, 10 contacts (universal application) 22 mm 24 mm 5.05.510.644/0000 PCB plug-in socket, 6 contacts (2 NO, lamp socket) 22 mm 24 mm 5.05.510.645/0000 PCB plug-in socket, 6 contacts (1 NC, 1 NO, lamp socket) 22 mm 24 mm 5.05.510.646/0000 PCB plug-in socket, 6 contacts (2 NC, lamp socket) 22 mm 24 mm 5.05.510.647/0000 PCB plug-in socket, 4 contacts (2 NC) 22 mm 24 mm 5.05.510.648/0000 PCB plug-in socket, 2 contacts (lamp socket) 22 mm 24 mm 5.05.510.649/0000 For soldering onto PCBs. The PCB carrying the plug-in sockets is plugged onto the contact blocks/lamp sockets. Additional fixing of the PCB to the contact block is not required. Solder terminals for PCB 3.5 mm long, for 1.3 mm hole. 2 - 70 Stock items are marked by bold printed order numbers. Control components RAFIX 16 Multipole connector Short text Feature 1 Feature 2 Order no. Multipole connector 21.8 mm 23.2 mm 5.05.510.421/0000 Makes it possible to simultaneously connect all terminals of a contact block. Can be fitted with 2.8 mm female quick-connect terminals. Female quick-connect terminal DIN 46340-B 2.8-1-MS Short text RAFIX 16 Feature 1 Female quick-connect terminal DIN 46340-B 2.8-1-MS Feature 2 Order no. 5.37.540.024/8622 With latching detent for mating with a multipole connector. Control components Stock items are marked by bold printed order numbers. 2 2 - 71 RAFIX 16 Plug distributor Short text Feature 1 Feature 2 Plug distributor 2 RAFIX 16 Order no. 5.37.540.029/6000 For mounting on the quick-connect terminals of contact blocks. The double number of contacts facilitates loop-through. Protection against contact Short text Feature 1 Protection against contact Feature 2 Order no. 5.55.103.105/0100 Assembly sequence: Snap the protection against contact onto the contact block, connect wires to quick-connect terminals of contact block, pull protection against contact over the terminals; this ensures finger-proof condition to VBG 4. 2 - 72 Stock items are marked by bold printed order numbers. Control components RAFIX 16 Protection against contact Short text Feature 1 Feature 2 Protection against contact (VBG 4 with lamp socket 1.71.212.011) Order no. 5.55.103.134/0700 You can use the protection against contact to cover the terminals of the lamp socket 1.71.212.011/0000 so that they are finger-proof to VBG 4. RAFIX 16 Series capacitor Short text Feature 1 Feature 2 Order no. Series capacitor, 125 V/48 V~, 50 Hz, 25 mA 5.03.771.333/0000 Series capacitor, 230 V/48 V~, 50 Hz, 25 mA 5.03.771.334/0000 Fully encapsulated, with a 2.8 x 0.8 mm quick-connect tab in a touch-proof arrangement. Control components 2 Stock items are marked by bold printed order numbers. 2 - 73 RAFIX 16 Disassembly tool Short text Feature 1 Feature 2 Disassembly tool for LUMOTAST 25, RAFIX 16 2 RAFIX 16 Order no. 5.05.800.042/0000 For replacing pushbutton and signal indicator lenses. Protective cover, suitable for lead seal, for pushbuttons, alignable without gaps Short text Feature 1 Protective cover, suitable for lead seal Feature 2 Order no. 5.05.800.055/0000 To prevent inadvertent operation. The legend is easily visible even when the cap is closed. 2 - 74 Stock items are marked by bold printed order numbers. Control components RAFIX 16 Fixing spanner for hexagon nut Short text Feature 1 Feature 2 Fixing spanner for hexagon nut Order no. 5.58.002.034/0000 2 RAFIX 16 insulating housing RAFIX 16 Pict.: 3-module Short text Feature 1 Feature 2 Order no. RAFIX 16 insulating housing, 1-module, light grey/dark grey 55 mm 100 mm 1.20.810.001/0000 RAFIX 16 insulating housing, 1-module, yellow/yellow 55 mm 100 mm 1.20.810.002/0000 RAFIX 16 insulating housing, 2-module, light grey/dark grey 115 mm 100 mm 1.20.820.001/0000 RAFIX 16 insulating housing, 3-module, light grey/dark grey 115 mm 100 mm 1.20.830.001/0000 RAFIX 16 insulating housing, 4-module, light grey/dark grey 145 mm 100 mm 1.20.840.001/0000 Label sheet for housings 5.40.451.283/0000 • Attractive plastic housing to accommodate up to 4 control components • 2 cable entries prepared: 1-,2-,3-part: M20x1,5, 4-part: M25x1,5 • Degree of protection IP 65 to DIN • All grey housings with overlay, legending possible with legend inserts • Wall mounting with 2 screws through housing bottom prepared • Dimensions x (feature 1) x 100 mm x 74 mm • Accessories: 50 pre-perforated legend inserts on a DIN A4 sheet for printing with a PC printer Control components Stock items are marked by bold printed order numbers. 2 - 75 RAFIX 16 RAFIX 16 label holder, flush, for square collar Short text Feature 1 Feature 2 Label holder, flush, for square collar 2 Order no. 5.07.620.004/0000 Accessories: Legend label 23 x 16 for label holder, without legend: 5.73.111.000/0000 Legending available on request. RAFIX 16 RAFIX 16 label holder, flush, for round collar Short text Feature 1 Label holder, flush, for round collar Feature 2 Order no. 5.07.620.006/0000 Accessories: Legend label 23 x 16 for label holder, without legend: 5.73.111.000/0000 Legending available on request. 2 - 76 Stock items are marked by bold printed order numbers. Control components RAFIX 16 RAFIX 16 label holder, protruding, for square flush fitting collar Short text Feature 1 Feature 2 Label holder, protruding, for square flush fitting collar Order no. 5.07.620.007/0000 2 Accessories: Legend label 23 x 16, without legend: 5.73.112.000/0000 Legending available on request. RAFIX 16 Emergency stop label, yellow, round 60 mm, PVC adhesive Short text Feature 1 Emergency stop label, yellow, round 60 mm, PVC adhesive, without legend 60 mm 5.76.204.400/0400 Emergency stop label, yellow, round 60 mm, PVC adhesive, with legend "NOT-AUS" Emergency stop label, yellow, round 60 mm, PVC adhesive, with legend "EMERGENCY STOP" 60 mm 5.76.204.401/0400 60 mm 5.76.204.403/0400 Control components Stock items are marked by bold printed order numbers. Feature 2 Order no. 2 - 77
5.58.007.001/0000 价格&库存
很抱歉,暂时无法提供与“5.58.007.001/0000”相匹配的价格&库存,您可以联系我们找货
