RAFIX 22 FS
FAST & SLIM
Everything else is outdated.
RAFIX 22 FS+
FAST & SLIM
2
rafix 22 fs + FAST & SLIM
Design is the key! New technologies and new materials make new design worlds possible. That not only goes for Colani and
his motor truck vision of the future but also for the control unit in your machine.
The RAFIX 22 FS+ control component generation provides your designers a basis for new designs, plus fast and cost-efficient
installation options requiring a minimum amount of space, and is now optimized to the latest generation of super bright SMT
LEDs.
Fast
The fastest connection type for every
application: with a printed circuit board
or right with quick-connect terminals.
• A printed circuit board is the best and
fastest solution already for medium size production volumes. In adition, PCB
contact blocks can ideally be combined
with displays, short-travel key switches
and electronic assemblies on one
common printed circuit board.
• Alternatively, QC (= Quick Connect) con tact blocks caneasily be snapped into
the actuators without tools. Blade ter minals are used directly for wiring in a
conventional manner.The fast and cost effective variant - where no PCB is pro fiable.
Slim
Now it’s a snap to slim the design of
your control systems thanks to the low
mounting depth.
• Designs with PCB contact blocks feature
a distance between the front panel and
printed circuit board of only 9.2 mm; the
same goes for contact blocks with silver
contacts for mains voltage.
That’s as slim as it gets.
• Also when fitted with QC contact blocks,
RAFIX 22 FS+ panels are extremely flat.
With a small footprint of only 27 mm
behind the front panel, they provide
tremendous design scope for inspiring
control panels.
RAFIX 22 FS+ offer additional benefits
for you:
• Diverse actuators and contact block
options – a complete series
• Variable thanks to round or square
operating components
• Variable thanks to gold contacts from 5 V
silver contacts up to 250 V
• Variable design thanks to diverse front
ring colors
• Variable illumination, compatible with
3 mm THT or newly with SMT LEDs
3
RAFIX 22 FS+
FAST & SLIM
Design IS THE KEY
Enjoy the look of your operating panel just like your customer will. The front elements feature a classically elegant design and
guarantee reliable data input.
4
Design
The RAFIX 22 FS+ series sets new standards in the control component field.
Extremely flat construction and functional esthetic design are absolutely
essential in an increasingly designoriented industrial environment.
The wide variety and variability of actuators give your designer complete de-
sign freedom: round or square collar
types, radiant colors and homogenous
illumination of the large actuating areas
are basic features. Combined with the
various front rings, this makes it possible to create your panel with a distinctive design. For example, a defined color
can always be assigned to a specific
command. What’s more, the large number of color options for the front ring
makes it a snap to customize it to the
corporate colors of the various OEMs.
Safe and reliable
The actuators featured in the RAFIX 22 FS+ series are water-jet proof and consistently ensure a degree of protection to at least IP 65, which makes them suitable for
many diverse applications. For increased environmental requirements, the series
also features actuators with a degree of protection to IP 65/ IP 69K.
Durable
The mechanical lifetime of all actuators is optimally suited for the long-lasting
operation of even much-used panels.
5
RAFIX 22 FS+
FAST & SLIM
6
PCB & QC – TWO SYSTEMS,
ONE TARGET: EFFICIENCY
In front of the front panel control components are functionally identical. Behind it
you’ll find the differences which make life easier for your production
engineer and number work simpler for your accountant.
Quick Connect version
PCB version
Quick Connect
Easy to assemble on the
QC contact blocks for maximum variability
When the investment for the layout and
production of a printed circuit board
does not pay off, your best choice is our
QC contact blocks with quick connect
terminals.The contact blocks are plugged
into the actuators from behind and lock
firmly into place.
Blade terminals enable simple wiring,
without any additional devices or special tools. The enclosed space in the
RAFIX 22 FS+ control components is
also used efficiently for the QC contact
blocks whose mounting depth including
the LED clip and cable lugs is only
27 mm.
PCB contact blocks for high production
volumes
• If you produce your input systems in
large volumes, or
• if you use a printed circuit board for the
electronics, displays and other compo nents anyway, or
• if you are planning combination with
short-travel keyswitches,
RAFIX 22 FS+ with PCB contact blocks is
the only real choice.
Simply include the PCB contacts and
LEDs in the layout of the printed circuit
board and solder them during production – just as simply as the other components on a common printed board.
Your benefits: cost savings and reduction of assembly errors. And don’t worry
about using up space: the contact blocks
require only 9.2 mm of space between
the printed circuit board and the front
panel.
PCB version
7
RAFIX 22 FS+
FAST & SLIM
COMMON SYSTEM DATA
Front panel
Panel cut-out
FS+ series are suitable for 22.3 mm panel cut-outs according to IEC 60947-5-1. All
actuators are equipped with a locating
pip. This locating pip ensures the perfect
fit of actuators and contact blocks for
PCB-mounted components and is therefore essential for a design built with
these contact blocks.
Grid spacing
The design principle makes it possible
to use a minimum grid spacing of
30 mm x 30 mm. In such an arrangement, actuators with square collars can
be aligned directly without any gaps.
When designing the grid spacing, it is
recommended to consider any external
legending required (for example, using
labels strips inserted into the front
panel).
Assembly of the front actuators
Single-handed assembly method
For assembly, insert the actuator into the mounting hole from the front side. It is
clamped in the panel cutout. Subsequently you can screw on the actuator from the
rear using the ring nut. You can perform these steps one after the other with one
hand! Even better: you can start by inserting all actuators from the front side first and
subsequently fasten the threaded rings from the rear in one go. We recommend using the RAFIX fixing spanner to ensure proper tightening.
8
SYSTEM STRUCTURE
with pcb contact blocks
PCB mounting
The PCB contact blocks are soldered on
the printed circuit board. Two options for
actuator illumination are available:
1.) A 3 mm LED which is inserted into the
base of the contact block and soldered
together with the contact block on the
in the actuators, so the entire system is
very low. Further benefits: individual
wiring is not required, and it is no longer
necessary to cut out the printed circuit
board around the control components.
2.) A separately placed SMT LED whose
light is transported by the light conductor and distributed over the entire surface of the lenses.
The printed circuit board is fastened to
the front panel with bolts, while the contact blocks are almost fully submerged
Keylock switch
Selector switch
Signal indicator
Emergency stop
Pushbutton
Pushbutton with protective cap
1...3mm
9.25 +- 0.10
min.30.00
Distance bushing
PCB hole pattern with THT LED
(view of component side)
Contact A1 Barred area
PCB hole pattern with SMT LED
27.50
Barred area
1.60
Contact A1
Contact A2
Locating indent 1
1.60
Contact A2
1.80
Locating indent 2
1.30
Locating indent 1
Pad dimensions
Soldering pad
4.46
7.80
Locating indent 2
0.18
Contact C1
1.60 X
Contact B1
Contact C2
Pad dimensions
1.60
Contact B2
3.28
Contact B2
Contact B1
10.80
n 2.56
13.00
Contact assignment
Contact A1/A2
terminal marking
Contact B1/B2
terminal marking
Contact C1/C2
terminal marking
*:only if required
1NO
2NO
2NC
1NC + 1NO
Plus 1
Contact assignment
1NO
13 - 14
1NC
11 - 12
1NO
13 - 14
1NC
11 - 12
Contact A1/A2
terminal marking
1NC
21 - 22
1NO
23 - 24
1NC
21 - 22
1NC
21 - 22
1NC
21 - 22
LED*
X1 - X2
LED*
X1 - X2
LED*
X1 - X2
LED*
X1 - X2
1NO
33 - 34
Contact B1/B2
terminal marking
Contact C1/C2
terminal marking
*:only if required
1NC
1NO
13 - 14
LED*
X1 - X2
*:only if required
1NO
2NO
2NC
1NC + 1NO
Plus 1
1NO
13 - 14
1NC
11 - 12
1NO
13 - 14
1NC
11 - 12
1NC
21 - 22
1NO
23 - 24
1NC
21 - 22
1NC
21 - 22
1NC
21 - 22
LED*
X1 - X2
LED*
X1 - X2
LED*
X1 - X2
LED*
X1 - X2
1NO
33 - 34
1NC
1NO
13 - 14
LED*
X1 - X2
*:only if required
Contact
diagram
for
selector
and
keylock
switches
Kontaktschema
für
Wahlundand
Schlüsselschalter
Contact
diagram
for
selector
keylock
switches
All actuators
Alle
Betätigerwith
mit 3 Schaltstellungen
switch positions
A1/A2
B1/B2
Alle
All actuators
Betätigerwith
mit 2 Schaltstellungen
switch positions
(A1/A2;
B1/B2)
A1/A2; B1/B2
9
RAFIX 22 FS+
FAST & SLIM
SYSTEM STRUCTURE
Essential features
• Mounting depth only 27 mm including
• Quick-connect/solder terminals
2.8 x 0.8 mm
• The contact block engages permanent ly with the actuator only at the time of
final assembly
• Compatible with all RAFIX 22 FS+
actuators:
pushbuttons,
selector
switches, keylock switches, emergency
stop buttons and signal indicators, with
all benefits this series offers
Large actuating and indicating areas
Round or square collar shapes
Panel cut-out to IEC 60947: 22.3 mm with
locating indent
Degree of protection IP 65 (water-jet
proof)
• Protection against contact for quick connect terminals and cable lugs: short circuit proof even when the connection
wires are under tensile strain
• Gold contacts for totally reliable switch ing of low voltages (5V/1 mA min.)
or
• Silver contacts (250V/4A max.) for
mains voltage
• Contact assignments: 1NC, 1NO, 2NC,
2NO, 1NC + 1NO
• Illumination with replaceable super
bright LED clips in various LED colors,
with quick-connect terminals 2.8 x 0.8 mm
• Actuators /contact blocks, signal indi cators /lamp sockets and LED clips
can be stocked separately and are not
assembled until final assembly. This
ensures maximum flexibility and
economical stock-keeping for this
range
Safe assembly process
Color marks
>>click 4 mm
triangular version
Height
Order no.
6.25 mm
5.30.759.109/0000
6.50 mm
5.30.759.110/0000
6.75 mm
5.30.759.111/0000
7 mm
5.30.759.112/0000
7.25 mm
5.30.759.113/0000
7.50 mm
5.30.759.114/0000
7.75 mm
5.30.759.115/0000
8 mm
5.30.759.116/0000
8.25 mm
5.30.759.117/0000
Required spacer length = Overall height of key - front panel thickness - 0.5 mm (area embossing).
70
Rafi-22FS_en_04-04-2012.indd 70
05.04.2012 11:55:51
RAFIX 22 FS+
FAST & SLIM
Printed: 2012/05/02
Technical data are approximate
and intended solely for general
orientation in the selection of
a product. Subject to modifications and errors. Images and
other graphics may only be similar. For more information, refer
to www.rafi.de chapter Imprint /
Data Protection.
RAFI GmbH & Co. KG
Ravensburger Str. 128-134, 88276 Berg/Ravensburg, Germany
Phone: +49 751 89-0, Fax: +49 751 89-13 00
www.rafi.de, info@rafi.de
很抱歉,暂时无法提供与“1.30.270.201/2308”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+94.81320
- 200+37.83240
- 500+36.56880
- 1000+35.94240
