1100-STA211
1100-STA211
    C3CONTROLS
    AUXCNTCTS W/ALRM S.MNTD 1NO1NC
1100-STA211 数据手册
s series series series series 0 330 CS 620 630 MINIATURE CIRCUIT BREAKERS series SERIES 1100 1100 PRODUCT PROFILE c3controls offers a comprehensive line of Miniature Circuit Breakers designed and manufactured to meet the needs of the machine builder. We promise durable products at a price that gives you an edge, and we guarantee same-day shipping. Check out all the features of our Series 1100 Miniature Circuit Breakers below! DELIVERING SUPERIOR PRODUCT QUALITY AND MANUFACTURING EXCELLENCE Proven UNIQUE FEATURES Full Range Circuit Protection Our Series 1100 Miniature Circuit Breakers are UL Listed and Recognized, and CE marked to meet global standards requirements and are compliant to the RoHS directives. • Available in single pole, single pole + neutral, two pole, three pole, and three pole + neutral constructions and includes both thermal and magnetic trip elements for overload and short circuit protection. Compact Design 17.5mm wide per pole construction for reduced panel size, allowing for smaller control panels. Easy to Install 35mm DIN rail mounting for fast and easy installation and removal. High visibility labels and markings; product part number, amperage, and UL & IEC short circuit ratings can be seen from the front and side of the device for easy identification. Trip-Free Design Visible Markings Added Safety Line and load side IP20 guarded finger-safe terminals prevent accidental contact with live parts, while allowing ring, fork, and bare wire connections. Easy Wiring Limited Lifetime Warranty* Every product is backed by our lifetime warranty—unmatched in the industry—bringing you quality components that perform in the most demanding applications. Guaranteed Same-Day Shipping* Product availability reduces inventory, and improves cash-flow— saving you money. With c3controls any order for standard catalog items received by 6:00pm ET is guaranteed to ship same-day. Advantage Pricing Our approach to product development, manufacturing, and focus on servicing the OEM and Electrical Equipment Builder reduces cost. The result—the best value in the industry. Industry-Leading Short Circuit Rating • 10kA @480Y/277V short circuit current rating on all multipole constructions – the highest interruption rating available in the market. • Holding the operating handle in the ON position will not prevent the miniature circuit breaker from tripping. • Captive screws make it impossible to lose screws when wiring and our box lug design terminals will accept a widerange of copper wire sizes. Line/load wiring is reversible for ease of use. Visible Markings & Status Indication • High visibility labels and markings can be seen from the front and side of the device for easy installation. Color-coded status window for clear visual of the breaker status. *See c3controls Terms & Conditions THE BEST ELECTRICAL CONTROLS BUSINESS ON THE PLANET! 724.775.7926 | www.c3controls.com 20 330 CS 620 630 series 1100 MINIATURE CIRCUIT BREAKERS UL489 MINIATURE CIRCUIT BREAKER (MCB) SPECIFICATIONS DIMENSIONS UL 489 Branch Circuit Breaker - 1 Pole 1 POLE 1 + N POLE 2 POLE 3 POLE 60.6mm (2-25/64") 3 + N POLE ELECTRICAL UL/CSA APPLICATIONS 48 ELECTRICAL IEC APPLICATIONS 96 10 — 17.5mm (11/16") 15 15 kA kA 10 10 — — 1 POLE 1 + N POLE 2 POLE A Hz Ops. 3 POLE Conformity to Standards AC Rated Operating Voltage DC Rated Operating Voltage (wired in series) MAXIMUM SHORT CIRCUIT RATING @ 120 VAC @ 240 VAC @ 277 VAC @ 480Y/277 VAC @ 48 VDC @ 96 VDC (wired in series) 277 V 48 t(s) 3 + N POLE ELECTRICAL IEC APPLICATIONS Conformity to Standards ULTIMATE SHORT CIRCUIT BREAKING CAPACITY (lcu) @ 240 VAC @ 415 VAC RATED SERVICE SHORT CIRCUIT BREAKING CAPACITY (lcs) @ 240 VAC @ 415 VAC 10 — ROHS COMPLIANCE t(s) 0.5 1 2 3 4 5 7 10 20 30 50 70 100 10 — 10 10 10 10 10 10 kA kA 15 15 kA kA 10 10 200 100 50 200 100 50 — 20 10 5 2 1 0.5 0.2 0.1 0.05 0.02 0.01 0.005 0.002 0.001 20 10 5 2 1 0.5 0.2 0.1 0.05 0.02 0.01 0.005 0.002 0.001 0.5 1 0.5 2 t(s) 20 10 5 2 1 0.5 0.2 0.1 0.05 0.02 0.01 0.005 0.002 0.001 200 100 50 20 10 5 2 1 0.5 0.2 0.1 0.05 0.02 0.01 0.005 0.002 0.001 t(s) — — — — AWG 1 x #14 ~ #3 mm2 1 x 2.08 ~ 26.7 For RoHS compliance documentation by product, refer to www.c3controls.com. I/In I/In C Curve B Curve 10,000 5,000 1h 2,000 1,000 500 I/In B Curve 200 100 50 t(s) 31 4 5 72 103 4 20 5 7 301050 70 20 100 30 50 70 100 Multiple of Multiple Operating of Operating Current (Ie)Current (Ie) Trip Curve D (UL 489 & UL 1077) 10,000 5,000 1h 2,000 1,000 500 IEC 60947-2, IEC 60898 CONSTRUCTION - CONDUCTOR SIZE UL/CSA Solid, Stranded, Fine Stranded cURus, UL 1077, CSA C22.2 No. 235 480Y/277 96 10,000 5,000 1h 2,000 1,000 500 t(s) Multiple of Operating Current (Ie) V kA kA kA kA kA kA 20 10 5 2 1 0.5 0.2 0.1 0.05 0.02 0.01 0.005 0.002 0.001 t(s) Trip Curve C (UL 489 & UL 1077) 10,000 5,000 1h 2,000 1,000 500 200 100 50 0.5 ~ 63 50/60 6,000 Suitable for reverse feed ELECTRICAL UL/CSA APPLICATIONS Trip Curve B (UL 1077) 10,000 5,000 1h 2,000 1,000 500 ELECTRICAL GENERAL Rated Operating Current Operating Frequency Electrical Life Line/Load Wiring 44.0mm (1-47/64") 5.9mm (15/64") 70.0mm (2-3/4") 52.5mm (2.0") TRIP CURVES UL 1077 SUPPLEMENTARY PROTECTORS UNITS 60.6mm (2-25/64") 12.0mm (15/32") MINIMUM CLEARANCE DISTANCE FOR LEVER MOVEMENT 44.0mm (1-47/64") 35.0mm (1-3/8") 5.9mm (15/64") 17.5mm 70.0mm (11/16") (2-3/4") 52.5mm (2.0") AWG 1 x #14 ~ #3 mm2 1 x 2.08 ~ 26.7 For RoHS compliance documentation by product, refer to www.c3controls.com. ROHS COMPLIANCE 44.0mm (1-47/64") 5.9mm (15/64") 70.0mm (2-3/4") UL 1077 Supplementary Protector - 1 Pole — — (1-3/8") kA kA 52.5mm (2.0") 60.6mm (2-25/64") IEC 60947-2,35.0mm IEC 60898 CONSTRUCTION - CONDUCTOR SIZE UL/CSA Solid, Stranded, Fine Stranded — 10 10 10 10 10 10 10 — UL1077 MINIATURE CIRCUIT BREAKER (MCB) 44.0mm 35.0mm (1-47/64") (1-3/8") 5.9mm (15/64") 17.5mm 70.0mm (11/16") (2-3/4") 45.2mm (1-25/32") V cULus, UL 489, CSA C22.2 No. 5 52.5mm 35.0mm (1-3/8") 480Y/277 (2.0") 17.5mm (11/16") 86.0mm (3-58/64") 277 kA kA kA kA kA kA Conformity to Standards ULTIMATE SHORT CIRCUIT BREAKING CAPACITY (lcu) @ 240 VAC @ 415 VAC RATED SERVICE SHORT CIRCUIT BREAKING CAPACITY (lcs) @ 240 VAC @ 415 VAC UL1077 MINIATURE CIRCUIT BREAKER (MCB) V 86.0mm (3-58/64") Conformity to Standards AC Rated Operating Voltage DC Rated Operating Voltage (wired in series) MAXIMUM SHORT CIRCUIT RATING @ 120 VAC @ 240 VAC @ 277 VAC @ 480Y/277 VAC @ 48 VDC @ 96 VDC (wired in series) 107.2mm (4-7/32") 0.5 ~ 63 50/60 6,000 Suitable for reverse feed 107.2mm (4-7/32") A Hz Ops. 45.2mm (1-25/32") ELECTRICAL GENERAL Rated Operating Current Operating Frequency Electrical Life Line/Load Wiring 60.6mm (2-25/64") 12.0mm (15/32") MINIMUM CLEARANCE DISTANCE FOR LEVER MOVEMENT t(s) 0.5 1 2 3 4 5 7 10 12.0 (15/ MIN FOR 45.2mm UL 489 BRANCH CIRCUIT BREAKERS UNITS UL489 MINIATURE CIRCUIT BREAKER (MCB) 20 30 50 70 100 Multiple of Operating Current (Ie) 0.5 1 2 3 4 5 7 10 20 30 50 70 100 Multiple of Operating Current (Ie) I/In CERTIFICATIONS B Curve Conformity to Standards: Certifications: UL 489 UL 1077 CSA C22.2 No. 5, No. 235 IEC 60947-2, IEC 60898 UL File#: E496118 UL File#: E496119 I/In C Curve CE Marked (per EU Low Voltage Directive 2006/95/EC and RoHS Directive 2011/65/EU) For complete ratings and detailed specifications refer to www.c3controls.com. Visit www.c3controls.com to download product certifications. Copyright © 2019 c3controls. All Rights Reserved. REVISION 02.2019
1100-STA211 价格&库存
很抱歉,暂时无法提供与“1100-STA211”相匹配的价格&库存,您可以联系我们找货
