22MM IEC PILOT DEVICES
SERIES1
223 DS EC TB GR
0 22 1
6
PRODUCT
PROFILE
s
series
al
iec
s
series
series
series
series
c3controls line of 22mm IEC Pilot Devices includes a wide range of push buttons, pilot
lights, selector switches, special operators, and accessories, all engineered for superior
durability
long life. We offer multiple cap types for our push buttons, including flush,
s e r iand
es
extended, and mushroom caps, and our light units are available in multi voltage and full
voltage.
series
TB
nema
nema
THE MOST INNOVATIVE LINE OF
AMERICAN ENGINEERED 22 IEC PILOT DEVICES
Proven
series
Environmentally
Secure
22
series
iec
0 22
s
series
Our 22mm IEC operators are UL Listed and CE
marked meeting global standards requirements.
With 4/4X and IP66 ratings, our 22mm line of pilot devices are
built to last and withstand dust, corrosion, ice, and rain.
UNIQUE FEATURES
se
Shorter Depth & Rugged Design
ries
TB
• Our compact line saves you space behind the panel with
our shorter contact blocks and light modules delivering the
shortest depth 22mm Pilot Devices engineered in the USA.
Easy to Install
Our “snap-on” contact blocks are color coded for quick circuit
identification and feature 35⁰ angled captive terminal screws
and self-lifting pressure plates for fast and easy wiring.
Quick & Simple
The latching mechanism enables the user to wire the contact
blocks & light modules separate from the operator and
outside the confined space of the control panel.
Low Profile
The 22mm line assumes the lead in the industry with the
shortest depth behind the panel.
global compliance standards for EN418—Safety of Machinery,
both non-illuminated and illuminated versions.
Rugged Design
Manufactured to be the highest quality—inside and out. With
its metal appearance and sleek design, you know you are
getting the quality you deserve.
Visible
Certifications
Our product certifications and electrical ratings are clearly
marked on the outside of the contact blocks for easy
reference during installation.
Heavy Duty
Polyester construction provides superior durability, corrosion
resistance, moisture rejection and electrical insulation.
Flexible
Our contact blocks can be stacked 2 deep and up to 3 across
for a total of 6 circuits, providing the flexibility to operate
multiple control circuits from a single operator.
Convenient
Reduce inventory with our interchangeable modular design,
providing endless options for appropriate operator interface.
Limited Lifetime
Warranty*
Every product is backed by our limited lifetime warranty—
unmatched in the industry—bringing you quality components
that perform in the most demanding applications.
Guaranteed
Same-Day Shipping*
Product availability reduces inventory, and improves cash-flow—
saving you money. With c3controls any order for standard catalog
items received by 6:00pm ET is guaranteed to ship same-day.
Advantage Pricing
Our approach to product development, manufacturing, and
focus on servicing the OEM and Electrical Equipment Builder
reduces cost. The result—the best value in the industry.
And with our metal appearance you get quality and durability
inside and out.
EN418 Emergency Stop Operators
• c3controls maintained push-twist-release operators meet the
and they feature a unique trigger action and are available in
Exclusive Multi-Voltage Lights
• Our multi-voltage light units—the only U.S. engineered multivoltage light in the industry!—operate at any voltage from
20V to 277V AC or DC without losing intensity, making them
easily interchangeable across multiple applications.
One Cam Design
• Our single cam design eliminates the need for multiple cam
and selector switch configurations, reducing inventory and
saves you labor time and costs.
Save Time with Dual Push Buttons
• With the ability to combine the functionality of two operators
in one space, our Dual Push Buttons save you in labor costs
and time spent in installation. Our dual push buttons are
available in both illuminated and non-illuminated versions
making them perfect for any application.
*See c3controls Terms & Conditions
Copyright © 2021 c3controls. All Rights Reserved.
724.775.7926
www.c3controls.com
REVISION 10. 2021
ies
series
strial
iec
series
series
series
series
series
series
series
non-reversing
reversing
series
series
series
series
series
IEC
0 22 22MM
3PILOT
DS DEVICES
EC TB GR PS 300 310 320
16 1
SPECIFICATIONS
series
series
0 22
ELECTRICAL RATINGS
TB
s
eries
FVB6
1866
6.3V
FVB12
756
14V
FVB24
757
28V
FVB55
1835
55V
FVB120
130V
LED6
6V†
LED12
12V†
LED24
24V†
LED130
120/130V†
W22UNR-12L
12V AC/DC†
W22UNR-24L
24V AC/DC†
W22UNR-120L
W22UNR-240L
Design
Life (Hrs.)
Current
Draw (mA)
Lamp
Type
Shock &
Vibration
0.65
5,000
250
Incand.
Very Good
s e r i N/A
es
0.31
15,000
80
Incand.
Good
N/A
0.62
7,500
80
Incand.
Good
N/A
1.1
5,000
50
Incand.
Good
N/A
0.36
10,000
Leakage
Protection
TB
Incand.
Good
N/A
100,000
50
LED*
Excellent
14 mA
100,000
< 20
LED*
Excellent
4 mA
100,000
< 20
LED*
Excellent
4 mA
100,000
< 10
LED*
Excellent
2 mA
100,000
< 18
LED*
Excellent
< 3 mA
100,000
< 18
LED*
Excellent
< 3 mA
110-130V
AC/DC†
100,000
< 18
LED*
Excellent
< 3 mA
220-240V
AC/DC†
100,000
< 18
LED*
Excellent
< 3 mA
Varies
w/Color
2000
mcd
Typical
31.5mm
(1.240”)
27.7mm
27.7mm
(1-3/32”)
(1-3/32”)
23mm
23mm
(29/32”)
(29/32”)
series
series
300 310
44mm
44mm
(1-47/64”)
(1-47/64”)
10.2mm
10.2mm
(13/32”)
(13/32”)
27.7mm
(1-3/32”)
23mm
(29/32”)
44mm
(1-47/64”)
Non-Illuminated Operator (shown with Flush Cap)
08/30/2012
2
09/19/2011
1
2 Rev08/30/2012
Date
09/19/2011
1
TOLERANCE
Date
Rev
Units:
3.0mm (.118”)
Panel Thickness
Shown
10.2mm
(13/32”)
XXX. +/- 1.00
mm [in]
XX.X +/- 0.30
TOLERANCE
X.XX +/- 0.10Units:
Drawn By:
XXX. ANGLES
+/- 1.00+/- 0.5 DEG
mmD.[in]
XX.X +/- 0.30
Hehman
X.XX UNLESS
+/- 0.10OTHERWISE
Drawn Modeled
By:
By:
ANGLES +/- 0.5
DEG
SPECIFIED
D. Hehman
D. Hehman
UNLESS
ThisOTHERWISE
drawing is the property
D
Modeled
By:
Approved
By:
of c3controls. This drawing
SPECIFIED
may not be copied, used or
D. Hehman
disclosed,
for any purpose
This drawing
is the property
except
asdrawing
authorized
in Created
Approved
By: On:
of c3controls.
This
writing by
c3controls.
may not be copied,
used
or
9/19/2011
disclosed, for any purpose
except as authorized in Created On:
R
writing by c3controls.
22.4mm
(.882”)
31.5mm
(1.240”)
Ø 31.0mm
(Ø 1.220”)
9/19/2011
2
1
Rev
UNLESS OTHERWISE
SPECIFIED
15.0mm
(.591”)
Drawing updated
Drawing released
Description
08/30/2012
09/19/2011
Date
TOLERANCE
XXX. +/- 1.00
XX.X +/- 0.30
X.XX +/- 0.10
ANGLES +/- 0.5 DEG
Revision History
Units:
Drawn By:
D. Hehman
Modeled By:
MULTI-VOLTAGE POWER CONSUMPTION & CURRENT DRAW
AC Current Draw (mA)
DC Current Draw (mA)
21
48
17
7
120
3.5
125
3
240
2.5
250
2
277
2.5
3.0mm (.118”)
Panel Thickness Shown
Power Consumption (W)
AC:
很抱歉,暂时无法提供与“W22IPB-EW-MVDLW-10”相匹配的价格&库存,您可以联系我们找货
