W22S2-HW-20
W22S2-HW-20
    C3CONTROLS
    开关 工作温度-40℃~+55℃
W22S2-HW-20 数据手册
22MM IEC PILOT DEVICES SERIES1 223 DS EC TB GR 0 22 1 6 PRODUCT PROFILE s series al iec s series series series series c3controls line of 22mm IEC Pilot Devices includes a wide range of push buttons, pilot lights, selector switches, special operators, and accessories, all engineered for superior durability long life. We offer multiple cap types for our push buttons, including flush, s e r iand es extended, and mushroom caps, and our light units are available in multi voltage and full voltage. series TB nema nema THE MOST INNOVATIVE LINE OF AMERICAN ENGINEERED 22 IEC PILOT DEVICES Proven series Environmentally Secure 22 series iec 0 22 s series Our 22mm IEC operators are UL Listed and CE marked meeting global standards requirements. With 4/4X and IP66 ratings, our 22mm line of pilot devices are built to last and withstand dust, corrosion, ice, and rain. UNIQUE FEATURES se Shorter Depth & Rugged Design ries TB • Our compact line saves you space behind the panel with our shorter contact blocks and light modules delivering the shortest depth 22mm Pilot Devices engineered in the USA. Easy to Install Our “snap-on” contact blocks are color coded for quick circuit identification and feature 35⁰ angled captive terminal screws and self-lifting pressure plates for fast and easy wiring. Quick & Simple The latching mechanism enables the user to wire the contact blocks & light modules separate from the operator and outside the confined space of the control panel. Low Profile The 22mm line assumes the lead in the industry with the shortest depth behind the panel. global compliance standards for EN418—Safety of Machinery, both non-illuminated and illuminated versions. Rugged Design Manufactured to be the highest quality—inside and out. With its metal appearance and sleek design, you know you are getting the quality you deserve. Visible Certifications Our product certifications and electrical ratings are clearly marked on the outside of the contact blocks for easy reference during installation. Heavy Duty Polyester construction provides superior durability, corrosion resistance, moisture rejection and electrical insulation. Flexible Our contact blocks can be stacked 2 deep and up to 3 across for a total of 6 circuits, providing the flexibility to operate multiple control circuits from a single operator. Convenient Reduce inventory with our interchangeable modular design, providing endless options for appropriate operator interface. Limited Lifetime Warranty* Every product is backed by our limited lifetime warranty— unmatched in the industry—bringing you quality components that perform in the most demanding applications. Guaranteed Same-Day Shipping* Product availability reduces inventory, and improves cash-flow— saving you money. With c3controls any order for standard catalog items received by 6:00pm ET is guaranteed to ship same-day. Advantage Pricing Our approach to product development, manufacturing, and focus on servicing the OEM and Electrical Equipment Builder reduces cost. The result—the best value in the industry. And with our metal appearance you get quality and durability inside and out. EN418 Emergency Stop Operators • c3controls maintained push-twist-release operators meet the and they feature a unique trigger action and are available in Exclusive Multi-Voltage Lights • Our multi-voltage light units—the only U.S. engineered multivoltage light in the industry!—operate at any voltage from 20V to 277V AC or DC without losing intensity, making them easily interchangeable across multiple applications. One Cam Design • Our single cam design eliminates the need for multiple cam and selector switch configurations, reducing inventory and saves you labor time and costs. Save Time with Dual Push Buttons • With the ability to combine the functionality of two operators in one space, our Dual Push Buttons save you in labor costs and time spent in installation. Our dual push buttons are available in both illuminated and non-illuminated versions making them perfect for any application. *See c3controls Terms & Conditions Copyright © 2021 c3controls. All Rights Reserved. 724.775.7926 | www.c3controls.com REVISION 10. 2021 ies series strial iec series series series series series series series non-reversing reversing series series series series series IEC 0 22 22MM 3PILOT DS DEVICES EC TB GR PS 300 310 320 16 1 SPECIFICATIONS series series 0 22 ELECTRICAL RATINGS TB s eries FVB6 1866 6.3V FVB12 756 14V FVB24 757 28V FVB55 1835 55V FVB120 ** 130V LED6 ** 6V† LED12 ** 12V† LED24 ** 24V† LED130 ** 120/130V† W22UNR-12L ** 12V AC/DC† W22UNR-24L ** 24V AC/DC† W22UNR-120L ** W22UNR-240L ** Design Life (Hrs.) Current Draw (mA) Lamp Type Shock & Vibration 0.65 5,000 250 Incand. Very Good s e r i N/A es 0.31 15,000 80 Incand. Good N/A 0.62 7,500 80 Incand. Good N/A 1.1 5,000 50 Incand. Good N/A 0.36 10,000 Leakage Protection TB 20 Incand. Good N/A 100,000 50 LED* Excellent 14 mA 100,000 < 20 LED* Excellent 4 mA 100,000 < 20 LED* Excellent 4 mA 100,000 < 10 LED* Excellent 2 mA 100,000 < 18 LED* Excellent < 3 mA 100,000 < 18 LED* Excellent < 3 mA 110-130V AC/DC† 100,000 < 18 LED* Excellent < 3 mA 220-240V AC/DC† 100,000 < 18 LED* Excellent < 3 mA Varies w/Color 2000 mcd Typical 31.5mm (1.240”) 27.7mm 27.7mm (1-3/32”) (1-3/32”) 23mm 23mm (29/32”) (29/32”) series series 300 310 44mm 44mm (1-47/64”) (1-47/64”) 10.2mm 10.2mm (13/32”) (13/32”) 27.7mm (1-3/32”) 23mm (29/32”) 44mm (1-47/64”) Non-Illuminated Operator (shown with Flush Cap) 08/30/2012 2 09/19/2011 1 2 Rev08/30/2012 Date 09/19/2011 1 TOLERANCE Date Rev Units: 3.0mm (.118”) Panel Thickness Shown 10.2mm (13/32”) XXX. +/- 1.00 mm [in] XX.X +/- 0.30 TOLERANCE X.XX +/- 0.10Units: Drawn By: XXX. ANGLES +/- 1.00+/- 0.5 DEG mmD.[in] XX.X +/- 0.30 Hehman X.XX UNLESS +/- 0.10OTHERWISE Drawn Modeled By: By: ANGLES +/- 0.5 DEG SPECIFIED D. Hehman D. Hehman UNLESS ThisOTHERWISE drawing is the property D Modeled By: Approved By: of c3controls. This drawing SPECIFIED may not be copied, used or D. Hehman disclosed, for any purpose This drawing is the property except asdrawing authorized in Created Approved By: On: of c3controls. This writing by c3controls. may not be copied, used or 9/19/2011 disclosed, for any purpose except as authorized in Created On: R writing by c3controls. 22.4mm (.882”) 31.5mm (1.240”) Ø 31.0mm (Ø 1.220”) 9/19/2011 2 1 Rev UNLESS OTHERWISE SPECIFIED 15.0mm (.591”) Drawing updated Drawing released Description 08/30/2012 09/19/2011 Date TOLERANCE XXX. +/- 1.00 XX.X +/- 0.30 X.XX +/- 0.10 ANGLES +/- 0.5 DEG Revision History Units: Drawn By: D. Hehman Modeled By: MULTI-VOLTAGE POWER CONSUMPTION & CURRENT DRAW AC Current Draw (mA) DC Current Draw (mA) 20 24 21 48 17 7 120 3.5 — 125 — 3 240 2.5 — 250 — 2 277 2.5 — 3.0mm (.118”) Panel Thickness Shown Power Consumption (W) AC:
W22S2-HW-20 价格&库存
很抱歉,暂时无法提供与“W22S2-HW-20”相匹配的价格&库存,您可以联系我们找货
