电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
TBR-MF-6-1P-SC
TBR-MF-6-1P-SC
    C3CONTROLS
    RELAY GEN PURP SPDT 6A 220-240V
TBR-MF-6-1P-SC 数据手册
es B ma es series series series series non-reversing reversing 300 310 280 290 TERMINAL BLOCK RELAYS miniature series B TBR miniature SERIES TBR PRODUCT PROFILE c3controls Terminal Block Relays are designed to meet your control and automation system requirements, which need reliable, safe connections as well as isolation between electronic controls and process I/O. Due to their unmatched size, flexibility, and various other features, terminal block relays can help you save money and premium panel space. Just look and see what Series TBR has to offer! DELIVERING SUPERIOR PRODUCT QUALITY AND MANUFACTURING EXCELLENCE UNIQUE FEATURES Super Bright LED Proven Our Terminal Block Relays are UL Recognized and CE marked, meeting global standards requirements. Ultra Compact Size Only 6.2mm width for a Single-Pole, Double-Throw relay, allowing you to control more devices and uses less space. Easy Reference Flexibility Pluggable relay attached on the socket can be replaced in case of malfunction, providing flexibility for repair or maintenance work. Quick Identification • Highly visible and bright LED on each unit gives indication of the relay’s operating state. • All the necessary installation markings including wire size and torque are available on the side of each terminal block relay. • Marking system allows for fast and easy circuit identification. A marking strip is pre-supplied on each unit. Secure Installation Quick and simple snap-on installation on a 35mm DIN Rail. Clear Visibility LED indication allows you to see the contact status of the relay, making it very helpful in troubleshooting. Visible Certifications Our product certifications and electrical ratings are clearly marked on the side of the device for easy reference during installation. Added Safety Terminals are IP20 rated, guarding against accidental contact with live parts. The pluggable relay is also IP67 rated making it reliable in extreme conditions. Lifetime Warranty* Every product is backed by our lifetime warranty—unmatched in the industry—bringing you quality components that perform in the most demanding applications. Guaranteed Same-Day Shipping* Product availability reduces inventory, and improves cashflow—saving you money. With c3controls any order for standard catalog items received by 6:00pm ET is guaranteed to ship same-day. Advantage Pricing Our approach to product development, manufacturing, and focus on servicing the OEM and Electrical Equipment Builder reduces cost. The result—the best value in the industry. Pluggable Relay • The marker base functions as a lever for installing or replacing the relay in case of troubleshooting or malfunction. Protection • Built-in Leakage Current Suppression and Coil Surge Protection. Accessories • Apart from the replacement relay, marker and separator, Series TBR consists of a jumper accessory to eliminate labor intensive wiring work. *See c3controls Terms & Conditions THE BEST ELECTRICAL CONTROLS BUSINESS ON THE PLANET! 724.775.7926 | www.c3controls.com eries TB series series series miniature miniature non-reversing reversing 300 310 280 290 ema eries series series TB TBR TERMINAL BLOCK RELAYS SPECIFICATIONS DIMENSIONS TERMINAL BLOCK RELAYS 6.1mm (.24”) UNITS INPUT DATA 12 24 110~125V 220~240 ≤8 ≤4 90 10 14 28 132 0.17 264 0.21 CONTACT RATINGS Contact Configuration Contact Material Rated Load SPDT AgNi 6A, 250VAC / 30VDC Maximum Switching Voltage VAC/VDC 400/125 Minimum Switching Voltage Minimum Switching Current V mA 5 100 35mm (1.388”) 89mm (1.388”) VAC/VDC ms ms % % VAC/VDC W 35mm (1.388”) 89mm (1.388”) Rated Voltage Typical Response Time Typical Release Time Pickup Voltage Dropout Voltage Maximum Allowable Voltage Coil Consumption 55mm (2.177”) 55mm (2.177”) 36mm (1.409”) 36mm (1.409”) 16mm (.642”) 16mm (.642”) 6.1mm (.24”) 76mm (3.004”) 76mm (3.004”) GENERAL Mechanical Service Life ELECTRICAL LIFE NO Operations NC Operations DIELECTRIC STRENGTH Between Contact and Coil Between Pole Vibration Resistance SHOCK RESISTANCE Functional Destructive Ambient Temperature Range Storage Temperature Operating Humidity Altitude Pollution Degree Maximum Wire Size Torque Degree of Protection ROHS COMPLIANCE 1 x 107 cycles 3 x 104 cycles 1 x 104 cycles VAC VAC 4,000 for 1 minute 1,000 for 1 minute 10 to 55Hz, double amplitude 1.0 mm m/s2 m/s2 °C/°F °C/°F % m 49 980 -40 to 55 / -40 to 131 -40 to 85 / -40 to 185 5 to 85 (no condensation) 0 - 2,000 2 14 0.5 IP20 AWG Nm WIRING DIAGRAM A1 A2 Protection and Indication Circuit 14 11 12 For RoHS compliance documentation by product, refer to www.c3controls.com For complete ratings and detailed specifications refer to www.c3controls.com. CERTIFICATIONS Conformity to Standards: Socket UL 508 CSA 22.2 No. 14 IEC 60947-1, 60947-5-1 Certifications: UL File #: E236196 (Guide SWIV2, SWIV8) CE Marked (per EU Low Voltage Directive 2014/35/EU and RoHS Directive EU 2015/863) Copyright © 2020 c3controls. All Rights Reserved.
TBR-MF-6-1P-SC 价格&库存
很抱歉,暂时无法提供与“TBR-MF-6-1P-SC”相匹配的价格&库存,您可以联系我们找货
