WD-B40X60W
WD-B40X60W
    C3CONTROLS
    WIRE DUCT SLOT 2PC ADH SCR 6.75
WD-B40X60W 数据手册
WIRING DUCT WD L WD SERIES PRODUCT PROFILE s series c3controls Wiring Duct includes a variety of styles, options, and accessories to simplify and increase the speed of your wiring and cable management, bringing you more control over your wiring productivity, reducing your installation costs, and providing you with the most attractive and organized control panels in the industry. FEATURES AND BENEFITS ADVANTAGES Fast Wiring • Wide variety of sizes to meet your wiring capacity needs: • Widths from 25mm (0.98”) to 150mm (5.90”) • The V-shaped slot lead-in makes wire insertion fast and easy. • Heights from 30mm (1.18”) to 100mm (3.94”) Convenience • Up to 21 width/height combinations in each slot type • Non-flammable (UL94 V-0), rigid PVC won’t warp, peel, chip, crack, or become brittle, and resists oil, salt solutions, and fungus for superior performance in even the most demanding industrial environments. • Flush side-wall and duct provide increased wire capacity and a pleasing, finished look. • Restricted slot design ensures that wires are held in place, even when the cover is not installed. • Snap-off, side wall fingers are scored to easily enlarge slots for any size wire or wire bundle. No tool is required to “snap off” fingers, and scoring ensures clean break-offs, eliminating sharp edges. • Optional adhesive backing allows you to temporarily stick your wiring duct where you want it on the panel before you permanently mount it. Just position, press, then drill and tap. Customization • Embossed mounting holes accept mounting inserts for installing smaller wiring duct inside larger wiring duct. Mounting inserts can be installed even after the wiring duct is secured to the panel, making it easy and saving you installation time. • Mounting hole patterns with elongated slots comply with DIN 43659 for global installation flexibility. • Three slot types are available to meet your capacity and flexibility needs: • Narrow slot – smaller fingers for more precise wiring • Wide slot – larger slots for bigger wires and bundles • Unslotted – to restrict wire access for extra security Durability • Interlocking, non-slip cover prevents sliding, even in high vibration applications. Reduced Inventory • Smaller standard package quantities, bringing you more control over your inventory. Easy Identification • Complete catalog number and dimensions printed on the side of the duct for quick identification and utilization. LIFETIME WARRANTY SAME-DAY SHIPPING ADVANTAGE PRICING PO B ox 4 9 6 • B e ave r, PA 1 5 0 0 9 7 2 4 .7 7 5 .7 9 2 6 • w w w. c 3 co nt ro ls. co m ies series TL WD WIRING DUCT SPECIFICATIONS DIMENSIONS Wiring Duct and Cover GENERAL UNITS Materials Wiring Duct Rigid, Self-Extinguishing PVC Wiring Duct Covers Rigid, Self-Extinguishing PVC Mounting Inserts HEIGHT Nylon 6 - Glass Filled Nylon Rivets Nylon 66 Wire Retainers Nylon 6 Name Plates Nylon 6 Mounting Clips Nylon 6 Continuous Use Temperature 6mm (15/64”) WIDTH WIRING DUCT AND COVER DIMENSIONS UL94 V-0 DIMENSION CODE 2 meters (6’ - 6.75’) Standard Wiring Duct & Cover Length Wiring duct complete with cover Standard Unit MATERIAL PROPERTY UNITS STANDARD VALUE Tensile Strength at Break kg/cm2 ASTM D838 > 390 Tensile Modulus 2 kg/cm ASTM D638 13,500 Flexural Strength kg/cm2 ASTM D790 550 Compressive Strength kg/cm2 ASTM D695 1190 Izod Impact Strength kg-cm/cm ASTM D256 7.0 Hardness - Shore D — ASTM D2240 75 - 80 HDT at 4.6 kg/cm2 °C ASTM D648 85 Vicat Softening Point at 5 kg Load °C ASTM D1525 85 Co-efficient of Linear Thermal Expansion °C ASTM D696 4.6 x 10-5 Flammability — UL94 V-0 Glow Wire Test (2mm) °C IEC 695-2-1 960 Limiting Oxygen Index % ASTM D2863 48.0 Specific Gravity — ASTM D792 1.48 % D570 BREAKING BREAKING LINEASTM LINE ASTM D150 0.018 Dielectric Constant — ASTM D150 2.5 Dielectric Strength kV/mm ASTM D149 13 Surface Resistivity Ohm ASTM D257 1.29 x 1015 Volume Resistivity Ohm-cm ASTM D257 3.21 x 1016 ppm Directive 2002/95/EC WIDTH (IEC 61321) < 500 ppm Directive 2002/95/EC (IEC 61321) < 50 ROHS COMPLIANCE For RoHS compliance documentation by product, refer to www.c3controls.com. For wire fill capacity of electrical conductors and data cables, refer to www.c3controls.com. HEIGHT (MM) WIDTH (INCHES) HEIGHT (INCHES) 25 25 25 25 25 40 40 40 40 60 60 60 60 80 80 80 80 100 100 100 150 30 40 60 80 100 40 60 80 100 40 60 80 100 40 60 80 100 60 80 100 100 0.98 0.98 0.98 0.98 0.98 1.57 1.57 1.57 1.57 2.36 2.36 2.36 2.36 3.15 3.15 3.15 3.15 3.94 3.94 3.94 5.90 1.18 1.57 2.36 3.15 3.94 1.57 2.36 3.15 3.94 1.57 2.36 3.15 3.94 1.57 2.36 3.15 3.94 2.36 3.15 3.94 3.94 Slots FIGURE 1N FIGURE 1N NARROW NARROW (THIN) (THIN) SLOT SLOT Narrow (Thin) Slot FIGURE 1W FIGURE 1W WIDE (STANDARD) WIDE (STANDARD) SLOT SLOT Wide (Standard) Slot 2mm (5/64”) 2mm (5/64”) 2mm (5/64”) 2mm (5/64”) HEIGHT HEIGHT — WIDTH WIDTH (MM) 25X30 25X40 25X60 25X80 25X100 40X40 40X60 40X80 40X100 60X40 60X60 60X80 60X100 80X40 80X60 80X80 80X100 100X60 100X80 100X100 150X100 0.05 Power Factor Cadmium Content 4mm (5/32”) +5° F to +140° F (-15° C to +60° C) Flammability Lead Content 2mm BREAKING LINE Nylon 66 Cable Tie Attachments Water Absorption FIG NARRO S 4mm (5/32”) 4mm (5/32”) 6mm (15/64”) 6mm (15/64”) 8mm (5/16”) 8mm (5/16”) 12mm (15/32”) 12mm (15/32”) CERTIFICATIONS Conformity to Standards: Certifications: UL 1565 CSA C22.2 No. 18.5-02 IEC 61084-2-1 UL File #: E330184 (Guide Z0DZ2, ZODZ8) CE Marked (per EU Low Voltage Directive 2006/95/EC and RoHS Directive 2011/65/EU) Visit c3controls.com to download product certifications. RE VI SI O N 0 3 . 0 3 . 2 0 1 4 Copyright © 2014 c3controls. All Rights Reserved.
WD-B40X60W 价格&库存
很抱歉,暂时无法提供与“WD-B40X60W”相匹配的价格&库存,您可以联系我们找货
