D150D51CR17471KR/LS333
    CALRAMIC
    插件
    470 pF ±10% 15000V(15kV) 陶瓷电容器 径向,圆片式
D150D51CR17471KR/LS333 数据手册
High Voltage Radial Leaded Disc Capacitors Negative TC Low Loss Commercial Level - 3 kVDC to 20 kVDC &DO5DPLF7HFKQRORJLHV//&PDQXIDFWXUHVDVHULHVRI KLJKO\UHOLDEOHVLQJOHOD\HUFRQIRUPDOO\FRDWHGQHJDWLYH WHPSHUDWXUHFRPSHQVDWLQJOHDGHGFHUDPLFGLVFFDSDFLWRUV WKDWGHOLYHUERWKYHU\VWDEOHDQGSUHGLFWDEOHSHUIRUPDQFH FKDUDFWHULVWLFVW\SLFDOO\DVVRFLDWHGZLWKORZORVVGLHOHFWULFV 7KHVHFDSDFLWRUVZKLFKGUDZRQWKLUW\SOXV\HDUVRISURYHQ GHVLJQDQGSURFHVVH[SHULHQFHDUHPDQXIDFWXUHGXQGHU VWULFWTXDOLW\FRQWUROJXLGHOLQHVDQGXWLOL]HDGRXEOHDFWLRQ SUHVVWRPLQLPL]HJUDGLHQWVZLWKLQWKHGLHOHFWULFSRZGHU SURGXFLQJDÀQLVKHGFDSDFLWRUZLWKDXQLIRUPÀUHGFHUDPLF GHQVLW\DQGXQSDUDOOHOHGSHUIRUPDQFHLQKLJKYROWDJH DSSOLFDWLRQV/HDGHGFRQVWUXFWLRQOLPLWVULVNIRUGDPDJH GXHWRH[SRVXUHWRPHFKDQLFDODQGWKHUPDOVWUHVV (VVHQWLDOZKHUHORZORVVHVDQGWLJKWFDSDFLWDQFHWROHUDQFHV DUHFULWLFDOWKHVHFDSDFLWRUVDUHLGHDOO\VXLWHGDVVQXEEHUV IRUVZLWFKLQJSRZHUVXSSOLHVFRXSOLQJDQGGHFRXSOLQJFD SDFLWRUVLQYHUWHUFLUFXLWU\OLJKWLQJEDOODVWVDQGRWKHUKLJK YROWDJHSXOVHDSSOLFDWLRQV 1. Lead Size: D30, D40 @ 0.025" Dia (#22 AWG) [0.64mm] D50 & Larger @ 0.032" Ø (#20 AWG) [0.81mm] 2. Standard / RoHS - 100% Tin Plate 3. Order of marking may vary depending on size of capacitor 3HUIRUPDQFH&KDUDFWHULVWLFV General Information 1. Custom voltages, package sizes and capacitance values available. Contact factory. 2. Higher voltage parts may require further encapsulation to prevent surface arc-over and breakdown. When required, parts should first be cleaned, and oven dried at +85°C. Silicone rubbers or a suitable epoxy may be used and de-airing of encapsulates is recommended. 3. Testing of higher voltage parts before installation and / or supplemental encapsulation, may be done in a suitable, non-contaminating dielectric fluid like FC-40. 4. Large ceramic capacitors, even leaded devices are susceptible to damage when exposed to thermal and / or mechanical shock. Refer to Technical Bulletin AN103 for handling and installation recommendations. 1 &57 5ev 1211-DKA High Voltage Radial Leaded Disc Capacitors Negative TC Low Loss Commercial Level - 3 kVDC to 20 kVDC (OHFWULFDO0HFKDQLFDO&KDUDFWHULVWLFV 2 &57 5ev 1211-DKA High Voltage Radial Leaded Disc Capacitors Negative TC Low Loss Commercial Level - 3 kVDC to 20 kVDC 3HUIRUPDQFH&KDUWV 7\SLFDO 7HPSHUDWXUH&RHIÀFLHQW>330ƒ&@ 7HPSHUDWXUH&RHIÀFLHQW>9V7HPS@ 9ROWDJH&RHIÀFLHQW 3 &57 5ev 1211-DKA
D150D51CR17471KR/LS333 价格&库存
很抱歉,暂时无法提供与“D150D51CR17471KR/LS333”相匹配的价格&库存,您可以联系我们找货
