2511C002
2511C002
    CANON(佳能)
    CPGA188
    CMOS 图像传感器 13272H x 9176V 2.2µm x 2.2µm 188-CPGA(55x47.8)
2511C002 数据手册
120 MP Ultra High Resolution CMOS Sensor 120MXS Product Sheet The 120MXS is an ultra-high resolution CMOS sensor with 13272 x 9176 effective pixels. It has a size equivalent to APS-H (29.2mm x 20.2mm), and a square pixel arrangement of 2.2μm x 2.2μm with 122 million effective pixels. Ultra-high-resolution is made possible by parallel signal processing, which reads signals at high speed from multiple pixels. All pixel progressive reading of 9.4 fps is made possible by 28 digital signal output channels. It is available in RGB, RGB-NIR, or in monochrome with twice the sensitivity. Ultra High Resolution and Speed By incorporating close to the same number of pixels as receptors in the human eye, the 120MXS captures remarkable detail 60 times greater than full high definition standards. By sharing a floating diffusion capacitance between four pixels instead of one, less space is required for the readout circuitry. This allows for larger photodiode sizes with an improved signal-to-noise ratio, without the trade off of long readout speeds. Optimized Pixel Design The sensors small pixels bring the potential for light to leak from pixel to pixel, which is known as crosstalk. When this happens, it can create color shading and inaccurate color representation that degrades image quality. To mitigate crosstalk, a wire layer has been incorporated into the sensor structure between each pixel. This creates a boundary that surrounds the pixel and keeps light from leaking between them. RGB-NIR Pixel Filter By replacing one of the green filters on a standard color CMOS sensor with a Near Infra-Red (NIR) filter, image processing from this sensor allows for the separation of visible and NIR wavelengths. Discrete analysis of these bands from a single image simplifies dual sensor systems by reducing size, weight, and power (SWaP) requirements, provides added capabilities to systems that can benefit from the additional band, and enhances current solutions already detecting in both the NIR and visible wavelengths such as precision agriculture with the benefit of 120MP resolution. 120MXS 120 MP Ultra High Resolution CMOS Sensor Specifications Quantum Efficiency Plot (Mono & RGB) Filter Type Sensitivity (e/lx/sec) 120MXSC 120MXSI 120MXSM RGB RGB-NIR Monochrome 10,000 10,000 20,000 Sensor Size 29.2mm x 20.2mm Number of Effective Pixels 13272h x 9176v Pixel Size 2.2μm x 2.2μm Scan Type Progressive Scan Shutter Rolling Shutter Maximum Frame Rate (All Pixels) 9.4 fps Resistor Control Type Three Wire Serial Communication Package Type 188pin ceramic PGA Saturation 10,000 e @gain x0.5 0.083 LSB/e- @ Gain x1 Conversion Gain Quantum Efficiency Plot (RGB-NIR) 0.67 LSB/e- @ Gain x8 Dark Random Noise (Room Temp) 2.3e rms @ gain x8 Dark Current 8.1e/sec @ gain x8, 60°C Drive Frequency 45MHz Output Channels Data 28 lanes, Clock 14 lanes Output Format 720Mbps in LVDS output 9.4fps @ 10 bit Column Amplifier Gains x0.5, x1, x2, x4, x8 Power Consumption 2.5W Power Supply Voltage 1.7 V, 3.5 V Package Size (External Electrodes Not Included) 55.0mm x 47.8mm x 4.49mm Pixel Color Filter Arrangement Applications • • • • • • • • • • • • • Product Sheet 3D Metrology Aerial Mapping Aeronautic Imaging Digital Archiving Document Scanning Flat Panel Display Inspection Intelligent Traffic Systems (ITS) Wide Area Surveillance Machine Vision Medical Imaging Packaging & Inspection Scientific Research Security RGB RGB-NIR For more information visit https://canon-cmos-sensors.com All specifications based on Canon’s testing standards and subject to change without notice. ©2019 Canon USA, Inc. v4.1
2511C002 价格&库存
很抱歉,暂时无法提供与“2511C002”相匹配的价格&库存,您可以联系我们找货
