3623V885
3623V885
    CANON(佳能)
    3U5MGXSBAM EVAL KIT
3623V885 数据手册
5MP Global Shutter CMOS Sensor 3U5MGXSBA Product Sheet The 3U5MGXSBA global shutter image sensor employs an advanced pixel design introducing drive readout and gathering structures which help significantly reduce noise, and contributing to a wide dynamic range with a power consumption of 500mW. Equipped with a 3.4μm pixel size and all pixel progressive reading at 120fps, the 2/3” sensor size with 5.33 million effective pixels (2592 x 2056) easily allows for applications in machine vision and other industrial environments where smaller size and high performance are required. It is available in RGB, Monochrome, and a specialized RGB-NIR color filter. Low Power Consumption Canon’s proprietary circuit technology enables this sensor to perform at high frame rates while maintaining a low power consumption. With a power draw of only 500mW at 60fps, this sensor can be used for long periods of time in applications requiring batterypowered operation such as remote sensing on drones. The low power consumption also generates less heat, reducing the need to increase the size of the camera body for thermal management, allowing for more compact designs. Reference Standard Effective Pixel Max Frame Rows Rate [fps] All Pixels 2056 120 Full HD 1080 218 HD 720 312 VGA 480 439 Region of Interest The 3U5MGXSBA can support up to 8 region of interest (ROI) areas, which can overlap, and which the size and position of each area can be independently defined to allow greater flexibility based on end user applications. By reducing the total amount of read information from the sensor, in either a single window, or throughout the maximum 8 ROI areas, the frame rate can also be increased to allow faster detection for more demanding applications. New Pixel Design and Drive Technology The Canon 3U5MGXSBA CMOS sensor uses a light gathering structure within the photodiode which increases its capability to convert photons from wider incident light angles. The result is a CMOS image sensor with higher sensitivity, capable of capturing high quality images even in challenging low-light situations. 3U5MGXSBA 5MP Global Shutter CMOS Sensor Specifications Product Sheet Quantum Efficiency Plot (RGB & Mono) 3U5MGXSBAC 3U5MGXSBAM 3U5MGXSBAI Filter Type RGB Monochrome RGB-NIR Sensitivity (e/lx/sec) 30,000 (Green) 47,000 30,000 (Green) Sensor Size 2/3 inch equivalent (8.8mm x 7.0mm) Number of Effective Pixels 2592h x 2056v Pixel Size 3.4μm x 3.4μm 60fps - Dynamic Range Priority Mode Maximum Frame Rate 120fps - Frame Rate Priority Mode Scan Type Progressive Scan Shutter Global electronic shutter function Package Type 180 pin ceramic LGA Saturation (@ Analog gain 0 dB) 12,000e - Dynamic Range Priority Mode Quantum Efficiency Plot (RGB-NIR) 7,000e - Frame Rate Priority Mode Analog Gain 0 to 36dB Digital Gain 0 to 24dB Conversion Gain 0.28 LSB/e @Analog gain 0 dB Dark Random Noise (Room Temp) 2.6e rms @ Analog gain x1 Dark Current (Room Temp) 1.3 e/sec @Analog gain x1 Drive Frequency 36MHz(Recommended) Output Format Data 12 lanes, Clock 2 lanes with a maximum output of 864Mbps at 12 bit ROI 8 Regions Inverted Output Function Horizontal and Vertical Power Consumption (Type) 500mW (Typ.) Full pixel scan at 60fps Power Supply Voltage 3.3V, 1.2V Package Size (External Electrodes Not Included) 18.96mm x 18.10mm x 2.51mm Exposure Control Register setting or External Trigger Pixel Color Filter Arrangement RGB RGB-NIR Accessories Evaluation Kit Filter Type RGB, Mono, or RGB-NIR Interface USB 3.1 Lens Mount C-Mount Accessories Included Power Supply, Compact Tripod, Cables Design Assets (with NDA) • Sensor board electrical design files • VHDL code for the FPGA Sensor Socket Available from Andon Electronics • 698-180-TH-491-R27-L14-1 (thru-hole socket) • 698-180-SM-500-R27-L14-1 (flat foot surface mount socket) • 698-180-SM-RB593-R27-L14-1 (Rollerball® surface mount socket) Applications • • • • • • • • • • Automotive Drone Embedded Vision Industrial Inspection Machine Vision Manufacturing Medical Robot Vision Surveillance For more information visit https://canon-cmos-sensors.com © 2019 Canon U.S.A., Inc. All rights reserved. Canon is registered trademark of Canon Inc. in the United States and may also be a registered trademark or trademark in other countries. Availability and specifications are subject to change without notice. Not responsible for typographical errors. This document highlights certain capabilities of the CMOS sensor. Any business developing a product that incorporates the CMOS sensor is responsible for compliance with all applicable laws, rules and regulations relating to such product and the marketing and sale thereof. Inc. v1.02
3623V885 价格&库存
很抱歉,暂时无法提供与“3623V885”相匹配的价格&库存,您可以联系我们找货
