MTR1 R138
MTR1 R138
    CANTHERM
    热熔断体 (TCO) AC DC 3 A 径向
MTR1 R138 数据手册
Thermal Cut-Off 250 Vac L50N 1) 5/10/20/25A L50NG900 (max. 184 °C) L10N 1) 3/8A Thermal Cut-Off HDMV, HDMH 15A 2) L10N HDMV L10N L50NG902 (max. 184°C) HDMH L10NG911 L50NG913 (max. 240°C) Plastic or metal housing temperature rating (°C) type Tf Th Tm Tm Tf type Th Tm 78 DM 62 250 71 - L10N 55 175 90 DM 68 250 72 L50N - - - 99 DM 83 250 77 L50N L10N 55 175 110 DM 86 250 84 L50N - - - 120 DM 96 250 85 - L10N 55 175 130 DM 112 250 90 - L10N 60 175 140 DM 125 250 93 L50N - - - 150 DM 135 250 98 L50N - - - 170 DM 1) 145 250 100 L50N L10N 70 175 182 DM 163 250 104 L50N - - - 190 DM 170 250 108 - L10N 78 175 110 L50N - - - 117 L50N - - - 118 - L10N 88 175 121 L50N - - - 128 L50N - - - 130 - L10N 100 175 140 - L10N 110 175 144 L50N - - - 150 - L10N 120 175 152 L50N For Ratings see SDFS/SDFL 15A 165 - - - L10N 135 175 167 L50N - - - 172 L50N - - - 184 L50N - - - 190 L50N - - - 192 L50N - - - 205 L50N 3) - - - 216 L50N 3) - - - 229 L50N 3) - - - 240 L50N 3) - - - tolerance (K) wire 1) Th type 0 / -5 0 / -7 see chart below see chart below 6.3 x 0.8 mm type lead code temperature max. operating voltage max. diameter insulation L10N stranded white L330 200 °C 600 V 0.90 mm AWG24 / 0.24 mm2 3557 L10N G911 stranded white L340 200 °C 600 V 1.26 mm AWG20 / 0.61 mm2 3557 L50N stranded white L350 200 °C 600 V 1.50 mm AWG18 / 0.96 mm2 3557 L50N solid yellow L440 200 °C 300 V 1.51 mm AWG20 / 0.81 mm 1332 not approved 2) UL approved only 3) Tf >200°C on request Applications - Household appliances - Electronic appliances - Fan heaters - Transformers - Automotive industry Benefits 0 / -5 cross section diameter UL style Deviations from standard types on request. 8415 Mountain Sights Avenue • Montreal (Quebec), H4P 2B8, Canada Tel: (514) 739-3274 • 1-800-561-7207 • Fax: (514) 739-2902 • E-mail: sales@cantherm.com Website: www.cantherm.com | Division of Microtherm 2016/SEPT THERMAL CUTOFF HDM L10 L50 MTEF MTHF MTKF MTML MTNF MTR1 MTS1 MTTF MTYF MWS SDF S3M - Small compact design - Broad product line - Dust-proof design - Customer-specific design Thermal Cut-Off 250 Vac Thermal Cut-Off 250 Vac MTKF 1A ceramic housing MTTF 1/2A size B (00): 38 size B (01): 68 MTYF 4/5A size B (00): 38 size B (01): 68 size B (00): 38 size B (01): 68 temperature rating ( C) o Tf type Th Tm type Th Tm 65 K06F 55 200 T06F 50 200 76 - - - T0F 55 200 Y06 1) Th Tm 45 200 Y0F 55 200 type MTNF Tf Functioning open temperature. Th Holding temperature: Maximum continuous exposure temperature during operation. Tm Maximum overshoot temperature: Above this temperature the TCO might conduct again. plastic housing 1A size E (S): 36 size E (L): 68 All current ratings relate to resistive loads. MTML 1A MTHF 2A MTEF 3A housing: white size E (S): 36 size E (L): 68 size E (S): 36 size E (L): 65 temperature rating (°C) Tm type Th Tm type N06F 1) Th Th Tm 65 50 200 - - - H06F 50 200 E06F 50 200 76 N0F 50 200 - - - H0F 50 200 E0F 55 200 86 N1F 60 200 - - - H1F 60 200 E1F 65 200 102 N2F 75 200 L10 75 165 H2F 75 200 E2F 70 200 115 N3F 95 200 L20 85 165 H3F 95 200 E3F 90 200 - L30 90 165 - - - - - - 200 - - - H4F 100 200 E4F 95 200 Tf type Th Tm type 86 - - - T1F 60 200 Y1F 60 200 102 K2F 80 200 T2F 75 200 Y2F 70 200 115 K3F 99 200 T3F 95 200 Y3F 90 200 127 K4F 110 200 T4F 110 200 Y4F 100 200 133 K13F 110 200 T13F 105 200 Y13F 100 200 125 - 136 K5F 115 200 T5F 105 200 Y5F 105 200 127 N4F 139 K6F 120 200 T6F 120 200 Y6F 115 200 130 - - - L33 100 165 - - - - - 145 K7F 125 200 - - - Y7F 125 200 133 N13F 105 200 - - - H13F 1) 100 200 E13F 95 200 105 - tolerance (K) 0 / -10 0 / -10 0 / -10 136 N5F 100 200 - - - H5F 100 200 E5F 95 200 wire (mm) Ø 0.53 Ø 0.53 Ø 0.70 139 N6F 110 200 - - - H6F 110 200 E6F 105 200 145 N7F 125 200 - - - H7F 110 200 E7F 115 200 S3M7 5A S3M4 10A metal housing SDFS/SDFL 15A size A (00): 63.8 size A (01): 82.9 S3M5 20A size B (S): 25.4 size B (L): 35 S3M8 25A size A (00): 63.8 size A (01): 82.9 tolerance (K) 0 / -10 0 / -10 0 / -10 0 / -10 wire (mm) Ø 0.53 Ø 0.52 Ø 0.55 Ø 0.70 MTR1 3A 2) MTS1 5A MWS1 15A MWS2 20A size A (00): 63.8 size A (01): 82.9 temperature rating (oC) Tf type Th Tm type Th Tm type Th Tm(VDE) Tm(UL) type Th Tm type Th Tm 66 - - - - - - DF 42 110 130 - - - - - - 70 E7F 55 125 E4A 55 130 - - - - E5A 55 175 E8A 45 175 72 - - - E4A 57 100 DF 50 115 110 E5A 57 175 E8A 47 175 77 E7F 62 125 E4A 62 125 DF 55 120 110 E5A 62 200 E8A 52 200 84 E7F 69 125 E4A 69 125 DF 60 125 114 E5A 69 200 E8A 59 200 91 - - - - - - DF 67 135 121 - - - - - - 93 E7F 78 140 E4A 78 140 - - - - E5A 78 215 E8A 68 215 98 E7F 83 140 E4A 83 140 DF 76 140 130 E5A 83 215 E8A 73 215 100 E7F 85 130 E4A 85 140 DF 78 135 250 E5A 85 215 - - - 104 - - - E4A 89 150 DF 80 150 150 E5A 89 225 E8A 79 225 110 E7F 95 140 E4A 95 150 DF 86 140 140 E5A 95 225 E8A 85 225 117 E7F 102 150 E4A 102 160 - - - - E5A 102 235 E8A 92 235 119 - - - - - - DF 95 170 170 - - - - - - 121 E7F 106 150 E4A 106 160 - - - - E5A 106 235 E8A 96 235 128 E7F 113 150 E4A 113 205 DF 106 155 155 E5A 113 235 E8A 103 235 141 - - - - - - DF 117 171 171 - - - - - - 144 E7F 129 175 E4A 129 240 DF 120 250 250 E5A 129 250 E8A 119 250 152 E7F 137 175 E4A 137 205 DF 128 176 175 E5A 137 250 E8A 127 250 167 E7F 152 200 E4A 152 240 - - - - E5A 152 285 E8A 142 285 170 - - - - - - DF 146 300 190 - - - - - - 172 E7F 157 200 E4A 157 240 - - - - E5A 157 350 - - - 184 E7F 169 200 E4A 169 210 DF 160 300 214 E5A 169 350 E8A 159 350 190 E7F 175 270 E4A 175 310 - - - - E5A 175 350 - - - 192 - - - E4A 177 210 DF 162 290 222 E5A 177 350 E8A 167 350 205 - - - E4A 189 310 - - - - E5A 189 375 - - - 216 - - - E4A 200 375 DF 1) 191 241 - E5A 200 375 - - - 228 - - - - - - DF 193 300 300 - - - - - - 229 - - - E4A 200 375 - - - - E5A 200 375 E8A 200 375 240 - - - E4A 200 450 DF 200 290 260 E5A 200 375 E8A 200 375 tolerance (K) wire (mm) 1) VDE approved only 0 / -5 0 / -5 0 / -5 0 / -5 0 / -5 Ø 0.57 Ø 1.0 Ø 1.02 / AWG18 Ø 1.0 Ø 1.0 i Tape + Reel, cut and bent on request plastic housing temperature rating (°C) Tf type Th Tm type Th Tm type Th Tm type Th 98 R-95 70 180 - - - - - - - - - 100 - - - S95 3) 70 180 S95H 3) 70 180 S95 3) 70 180 108 R-105 80 180 - 110 - - - S105 2) 130 R-125 100 180 143 - - - 150 (not RoHS compliant) - - - 2) S138 2) - S125 - - - 80 180 S105H 2) 100 180 3) 110 180 - - - S145H 3) S125H - - - - - 80 180 S105 3) 80 180 100 180 - - - - - - - - 120 180 S145 3) 120 180 tolerance (K) 0 / -10 0 / -10 0 / -10 0 / -10 wire (mm) Ø 0.60 Ø 0.70 Ø 1.20 Ø 1.60 1) VDE approved only 2) UL approved only 3) Tm not approved Ordering example S3M4 E4A 00 121 temperature Tf construction / code: 00 / S (one side short); 01 / L (both sides long) type (manufacturer designation) sales name ®
MTR1 R138 价格&库存
很抱歉,暂时无法提供与“MTR1 R138”相匹配的价格&库存,您可以联系我们找货
