C6635-4
C6635-4
    TRI-STAR
    #2-56 Kwik 螺帽 0.192"(4.88mm) 黄铜
C6635-4 数据手册
4 PART NO. D -1 -2 -3 -4 -5 -6 -7 -8 -9 -10 -11 -12 3 APPLICABLE NOTE(S) A** 2 B 1, 2, 3, 4, 6 .056 +.000/-.005 [1.422+.000/-.127] 1, 2, 3, 4, 5, 6 .056 +.000/-.005 [1.422+.000/-.127] 1, 2, 3, 4, 6 .102 +/-.004 [2.591+/-.100] 1, 2, 3, 4, 5, 6 .102 +/-.004 [2.591+/-.100] 1, 2, 3, 4, 6 .033+.000/-.003[.838+.000/-.076] 1, 2, 3, 4, 5, 6 .033+.000/-.003[.838+.000/-.076] 1, 2, 3, 4, 6 .073+/-.004[1.854+/-.100] 1, 2, 3, 4, 5, 6 .073+/-.004[1.854+/-.100] 1, 2, 3, 4, 6 .125+/-.004[3.175+/-.100] 1, 2, 3, 4, 5, 6 .125+/-.004[3.175+/-.100] 1, 2, 3, 4, 6 .167+/-.004[4.242+/-.100] 1, 2, 3, 4, 5, 6 .167+/-.004[4.242+/-.100] C .010+/-.002 [.254+/-.050] .010+/-.002 [.254+/-.050] .056 +/-.002[1.422+/-.050] .056 +/-.002[1.422+/-.050] .005+/-.002[.127+/-.050] .005+/-.002[.127+/-.050] .027+/-.002[.686+/-.050] .027+/-.002[.686+/-.050] .079+/-.002[2.007+/-.050] .079+/-.002[2.007+/-.050] .121+/-.002[3.073+/-.050] .121+/-.002[3.073+/-.050] .065±.005 1.651±0.127 A ** (D) 1 BOARD THICKNESS DESCRIPTION .062 [1.57] MACHINED FINISH PLATED MACHINED FINISH PLATED MACHINED FINISH PLATED MACHINED FINISH PLATED MACHINED FINISH PLATED MACHINED FINISH PLATED .011+/-.001[.279+/-.025] .027[.686] .011+/-.001[.279+/-.025] .027[.686] .011+/-.001[.279+/-.025] .027[.686] .011+/-.001[.279+/-.025] .027[.686] .007+/-.001[.178+/-.025] .013[.330] .007+/-.001[.178+/-.025] .013[.330] .011+/-.001[.279+/-.025] .027[.686] .011+/-.001[.279+/-.025] .027[.686] .011+/-.001[.279+/-.025] .027[.686] .011+/-.001[.279+/-.025] .027[.686] .011+/-.001[.279+/-.025] .027[.686] .011+/-.001[.279+/-.025] .027[.686] .125 [3.18] .0394 [1.00] .093 [2.36] .150 [3.81] .197 [5.00) REVISIONS DESCRIPTION ECO 32953 (CHG. MAT'L & FINISH) ECO 33862 (ADD KNURL SPEC.) ECO 35051 (ADD -3,-4) ECO XXXXX (REVISE DIM) ECO XXXXX (DIM'S CHANGE) KNURL Ø.156+/-.003 WAS Ø.165+/.003,Ø.132/.135 WAS Ø.145/.148 ADD KNURL DEPTH .008/.012 AND ADD REF. DIM. .140 REV. A B C D E DATE 10/05/17 07/09/18 7/31/2019 8/6/2019 8/13/19 BY HT HT PV PV HT 08/15/19 HT 08/26/19 HT ECO 35152 (ADD .004 FLAT MAX, .009/.011 KNURL DEPTH WAS .008/.012 & REF DIM .Ø.136 WAS .140, 09/13/19 ADD -5 THRU -10) HT E1 E2 F ECO 35488(ADD-11 &-12 FOR 5.00mm PCB THK) G 02.13.20 HT KNURL TOOL MARK WILL BE ACCEPTABLE C C .156±.002 3.962±0.051 STRAIGHT KNURL 128 DP (18-20 TEETH) .000 .192+.005 0 4.877-0.127 D .004 FLAT MAX. 0.101 C 45° B .135 .132 3.429 3.353 B A 4 B A #2-56 UNC-2B THRU SECTION A-A SCALE 12 : 1 NOTE(S): 1. MATERIAL: BRASS ALLOY, UNS No. C36000 PER ASTM B 16, TEMPER HO2. 2. CRITICAL DIMENSIONS: * *. 3. ALL MACHINED DIAMETERS TO BE CONCENTRIC WITH Ø .002 TIR. 4. DIMENSIONS APPLY AFTER PLATING.. 5. BRIGHT NICKEL PLATE PER SAE AMS-QQ-N-290, CLASS 1, .000200/.000300 THICK, OVER COPPER STRIKE PER SAE AMS 2418. 6. DIMENSIONS IN BRACKET ARE IN MILLIMETER. ENG-SW REV. E .011 .009 0.277 0.226 kNURL DEPTH .136 3.459 KNURL DIA. AT ROOT REF. DIMENSION .144 .140 3.655 3.553 R.003 MAX 0.076 MAX TYP. .003/.007 X 45 [.076/.178] CHAMFER BOTH SIDES A D APPLICABLE CARLISLE IT DOCUMENTS WORK STANDARD PROD INSTRUC ASSY INSTRUC NA - NA NA N O T I C E THIS DRAWING EMBODIES A CONFIDENTIAL PROPRIETARY DESIGN ORIGINATED BY CARLISLE INTERCONNECT TECHNOLOGIES & ALL DESIGN, MANUFACTURING, REPRODUCTION, USE & SALE RIGHTS REGARDING THE SAME ARE EXPRESSLY RESERVED. IT IS SUBMITTED UNDER A CONFIDENTIAL RELATIONSHIP FOR A SPECIFIED PURPOSE & THE RECIPIENT AGREES BY ACCEPTING THIS DRAWING NOT SUPPLY OR DISCLOSE ANY INFORMATION REGARDING IT TO ANY UNAUTHORIZED PERSON TO INCORPORATE IN OTHER PROJECTS ANY SPECIAL FEATURES PECULIAR TO THIS DESIGN. ALL PATENT RIGHTS HERETO ARE EXPRESSLY RESERVED BY CARLISLE INTERCONNECT TECHNOLOGIES, CERRITOS, CALIFORNIA 90703. 3 TOLERANCES AND NOTES EXCEPT AS NOTED DIMENSIONS ARE IN INCHES. .XX ±.015 LINEAR .XXX ±.005 ANGULAR ± 1/2° FRACTION ± 1/32 1. MACHINE FINISH: 63 RMS 2. BREAK ALL SHARP EDGES .003 MAX. .005 MAX. 3. MACHINED FILLETS 4. MACHINED SURFACES SQUARE TO RESPECTIVE AXIS WITHIN .005 INCHES PER INCH. 5. MACHINED DIAMETERS CONCENTRIC WITHIN .002 T.I.R. 6. DIMENSIONS TO BE MET BEFORE PLATING. 7. CHAMFER ALL THREADS 45°. 8. THREADS PER H-28 9. REMOVE FRAYED EDGES ON TEFLON. 10. REMOVE ALL BURRS. 2 SEE NOTE(S) MATERIAL APPROVAL INITIALS DATE DRAWN BY HT 08.14.17 CHECKED BY - - TEST ENGR - - QUALITY - - DESIGN ENG HT 09.06.17 MFG. ENGR - - ECO APPRV - - SEE NOTE(S) SEE NOTE(S) SPECIFICATION PROCUREMENT CARLISLE TITLE SCALE 16:1 Interconnect Technologies Cerritos, CA 90703 NUT, PRESS FIT SUB-DIRECTORY/ _CXXXX\C66XX\ SIZE CAGE CODE DRAWING NO. C 30990 SHEET C6635 1 1 OF 2 REV. G A 4 3 .065 1.651 2 .065 1.651 .056 1.422 1 .102 2.591 D D -4 CONFIGURATION -2 CONFIGURATION C .065 1.651 .033 0.838 B .065 1.651 -6 CONFIGURATION .065 1.651 C .073 1.854 B -8 CONFIGURATION .065 1.651 .125 3.175 .167 4.242 A A -12 CONFIGURATION SCALE -10 CONFIGURATION ENG-SW REV. E 16:1 SUB-DIRECTORY/ _CXXXX\C66XX\ SIZE CAGE CODE DRAWING NO. C 30990 4 3 2 SHEET C6635 1 2 OF 2 REV. G
C6635-4 价格&库存
很抱歉,暂时无法提供与“C6635-4”相匹配的价格&库存,您可以联系我们找货
