TMA-8MS-9FS-00
TMA-8MS-9FS-00
    TRI-STAR
    同轴连接器(RF) - 适配器 1.85mm 插头,公插针 至 2.92mm(OS-2.9)插孔,母插口 50 欧姆
TMA-8MS-9FS-00 数据手册
Connectors & Accessories RF/Microwave Adapters DC — 65 GHz INTRODUCTION With the introduction of the industry’s first swept right-angle microwave adapter in the 1970s, the Carlisle Interconnect Technologies (CarlisleIT) name has become synonymous with precision RF and microwave adapters. We offer a full-gender family of precision RF adapters in different connector options to cover applications ranging from DC – 65 GHz. These adapters come standard in a passivated stainless steel body with a captivated beryllium copper center conductor to ensure mating repeatability. In addition, options such as gold-plated housing or non-captivated center conductor are also available to fit the desired application. All of our adapters are 100% tested to ensure optimum performance over their respective frequency range. FEATURES » Complete Family of Straight In-Series & Between-Series Precision RF Adapters » 50 Ω Impedance » Low VSWR & Insertion Loss » Color Coded Rings for Series Indication IN-SERIES & BETWEEN-SERIES In order to facilitate adapting from one connector configuration to another, we also offer between-series adapters for different connection types. In this case, the frequency range is limited by the connector with the lower frequency of operation. Similar to the in-series adapters, options such as gold-plated housing or non-captivated center conductor are also available to fit the desired application. Between-Series Adapters In-Series Adapters Learn more: CarlisleIT.com/products Connectors & Accessories RF Adapters In-Series & Between-Series INTRODUCTION This is a complete family of 50 Ω straight adapters available in 1.85 mm, 2.40 mm, 2.92 mm, and 3.50 mm interfaces. PRODUCT NUMBERS & SPECIFICATIONS Product In-Series Adapters BetweenSeries Adapters Part No. Description Connector 1 Connector 2 TMA-8FS-8FS-00 MW ADAPTER 1.85 mm FEMALE - 1.85 mm FEMALE 1.85 mm Female 1.85 mm Female TMA-8MS-8FS-00 MW ADAPTER 1.85 mm MALE - 1.85 mm FEMALE 1.85 mm Male 1.85 mm Female TMA-8MS-8MS-00 MW ADAPTER 1.85 mm MALE - 1.85 mm MALE 1.85 mm Male 1.85 mm Male TMA-4FS-4FS-00 MW ADAPTER 2.4 mm FEMALE - 2.4 mm FEMALE 2.4 mm Female 2.4 mm Female TMA-4MS-4FS-00 MW ADAPTER 2.4 mm MALE - 2.4 mm FEMALE 2.4 mm Male 2.4 mm Female TMA-4MS-4MS-00 MW ADAPTER 2.4 mm MALE - 2.4 mm MALE 2.4 mm Male 2.4 mm Male TMA-9FS-9FS-00 MW ADAPTER 2.92 mm FEMALE - 2.92 mm FEMALE 2.92 mm Female 2.92 mm Female TMA-9MS-9FS-00 MW ADAPTER 2.92 mm MALE - 2.92 mm FEMALE 2.92 mm Male 2.92 mm Female TMA-9MS-9MS-00 MW ADAPTER 2.92 mm MALE - 2.92 mm MALE 2.92 mm Male 2.92 mm Male TMA-5FS-5FS-00 MW ADAPTER 3.5 mm FEMALE - 3.5 mm FEMALE 3.5 mm Female 3.5 mm Female TMA-5MS-5FS-00 MW ADAPTER 3.5 mm MALE - 3.5 mm FEMALE 3.5 mm Male 3.5 mm Female TMA-5MS-5MS-00 MW ADAPTER 3.5 mm MALE - 3.5 mm MALE 3.5 mm Male 3.5 mm Male TMA-8FS-4FS-00 MW ADAPTER 1.85 mm FEMALE - 2.4 mm FEMALE 1.85 mm Female 1.85 mm Female TMA-8MS-4FS-00 MW ADAPTER 1.85 mm MALE - 2.4 mm FEMALE 1.85 mm Male 1.85 mm Female TMA-8FS-4MS-00 MW ADAPTER 1.85 mm FEMALE - 2.4 mm MALE 1.85 mm Female 1.85 mm Male TMA-8MS-4MS-00 MW ADAPTER 1.85 mm MALE - 2.4 mm MALE 1.85 mm Male 1.85 mm Male TMA-8FS-9FS-00 MW ADAPTER 1.85 mm FEMALE - 2.92 mm FEMALE 1.85 mm Female 2.92 mm Female TMA-8MS-9FS-00 MW ADAPTER 1.85 mm MALE - 2.92 mm FEMALE 1.85 mm Male 2.92 mm Female TMA-8FS-9MS-00 MW ADAPTER 1.85 mm FEMALE - 2.92 mm MALE 1.85 mm Female 2.92 mm Male TMA-8MS-9MS-00 MW ADAPTER 1.85 mm MALE - 2.92 mm MALE 1.85 mm Male 2.92 mm Male TMA-8FS-5FS-00 MW ADAPTER 1.85 mm FEMALE - 3.5 mm FEMALE 1.85 mm Female 3.5 mm Female TMA-8MS-5FS-00 MW ADAPTER 1.85 mm MALE - 3.5 mm FEMALE 1.85 mm Male 3.5 mm Female TMA-8FS-5MS-00 MW ADAPTER 1.85 mm FEMALE - 3.5 mm MALE 1.85 mm Female 3.5 mm Male TMA-8MS-5MS-00 MW ADAPTER 1.85 mm MALE - 3.5 mm MALE 1.85 mm Male 3.5 mm Male TMA-4FS-9FS-00 MW ADAPTER 2.4 mm FEMALE - 2.92 mm FEMALE 2.4 mm Female 2.92 mm Female TMA-4MS-9FS-00 MW ADAPTER 2.4 mm MALE - 2.92 mm FEMALE 2.4 mm Male 2.92 mm Female TMA-4FS-9MS-00 MW ADAPTER 2.4 mm FEMALE - 2.92 mm MALE 2.4 mm Female 2.92 mm Male TMA-4MS-9MS-00 MW ADAPTER 2.4 mm MALE - 2.92 mm MALE 2.4 mm Male 2.92 mm Male TMA-4FS-5FS-00 MW ADAPTER 2.4 mm FEMALE - 3.5 mm FEMALE 2.4 mm Female 3.5 mm Female TMA-4MS-5FS-00 MW ADAPTER 2.4 mm MALE - 3.5 mm FEMALE 2.4 mm Male 3.5 mm Female TMA-4FS-5MS-00 MW ADAPTER 2.4 mm FEMALE - 3.5 mm MALE 2.4 mm Female 3.5 mm Male TMA-4MS-5MS-00 MW ADAPTER 2.4 mm MALE - 3.5 mm MALE 2.4 mm Male 3.5 mm Male TMA-9FS-5FS-00 MW ADAPTER 2.92 mm FEMALE - 3.5 mm FEMALE 2.92 mm Female 3.5 mm Female TMA-9FS-5MS-00 MW ADAPTER 2.92 mm FEMALE - 3.5 mm MALE 2.92 mm Female 3.5 mm Male TMA-9MS-5FS-00 MW ADAPTER 2.92 mm MALE - 3.5 mm FEMALE 2.92 mm Male 3.5 mm Female TMA-9MS-5MS-00 MW ADAPTER 2.92 mm MALE - 3.5 mm MALE 2.92 mm Male 3.5 mm Male Freq. Range VSWR (Max) DC - 65 GHz 1.20:1 @ 65 GHz DC - 50 GHz 1.20:1 @ 50 GHz DC - 40 GHz 1.20:1 @ 40 GHz DC - 26.5 GHz 1.18:1 @ 26.5 GHz DC - 50 GHz 1.20:1 @ 50 GHz DC - 40 GHz 1.20:1 @ 40 GHz DC - 26.5 GHz 1.18:1 @ 26.5 GHz DC - 40 GHz 1.20:1 @ 40 GHz DC - 26.5 GHz 1.18:1 @ 26.5 GHz DC - 26.5 GHz 1.18:1 @ 26.5 GHz Learn more: CarlisleIT.com/products Connectors & Accessories RF Adapters In-Series & Between-Series RF ADAPTERS CarlisleIT features precision RF adapters with color-coded rings on each end that identify connector type. The color-coding scheme is as follows: Orange DC - 2 6.5GHz 3.5mm Connector Yellow DC - 40GHz 2.92mm (K) Connector Green DC - 50GHz 2.4mm Connector Blue DC - 67GHz 1.85mm (V) Connector SIGNAL INTEGRITY PERFORMANCE These adapters offer excellent signal integrity with low VSWR, and low insertion loss. Figure 1 shows the VSWR data and Figure 2 shows the insertion loss for a 2.92 mm female to 2.92 mm female adapter. It can be seen that the adapter introduces minimal insertion loss in the channel and an exhibits excellent VSWR performance of approximately 1.12 at 40 GHz. Fig.1: VSWR performance of 2.92 mm female to 2.92 mm female adapter Fig. 2: Low insertion loss of 2.92 mm female to 2.92 mm female adapter CarlisleIT Precision RF adapters are readily available within two weeks after receiving the order. Learn more: CarlisleIT.com/products Global Manufacturing. Local Support. Wherever you are, so are we. With manufacturing centers around the globe, our highly qualified team of engineers is up to any challenge. Our extensive worldwide manufacturing capabilities, coupled with end-to-end local project management and engineering support, allow us to design, build, test, and certify your product in-house, saving you the time and hassle of managing multiple vendors. Division HQ Asia/Pacific HQ DIVISION HEADQUARTERS ST. AUGUSTINE, FL 100 Tensolite Drive St. Augustine, FL 32092 United States +1 (800) 458.9960 See CarlisleIT’s line of Test & Measurement products at: CarlisleIT.com/markets/test-measurement FACILITIES CERTIFICATIONS » AS9100 » ISO 9001 » ISO 13485 » ISO 14001 » ITAR registration » MIL-SPEC/SAE » RoHS compliance +1 (800) 458.9960 TMSales@CarlisleIT.com © Carlisle Interconnect Technologies, 2021. All trademarks, service marks and trade names are property of their respective holding companies. All Rights Reserved. SS-10037-TNM-050521
TMA-8MS-9FS-00
物料型号:文档中列出了多种射频适配器的型号,例如TMA-8FS-8FS-00、TMA-8MS-8FS-00等,它们分别对应不同的接口类型和性别。
器件简介:Carlisle Interconnect Technologies (CarlisleIT) 提供精密射频和微波适配器,这些适配器覆盖从直流到65 GHz的应用范围。它们具有标准不锈钢体和固定铍铜中心导体,确保重复配对性。
引脚分配:文档中没有明确提到引脚分配,但提到了适配器的连接器类型,如1.85mm Female、2.4mm Female等。
参数特性:适配器具有50欧姆的阻抗,低VSWR和插入损耗,以及用于系列指示的颜色编码环。
功能详解:适配器提供优秀的信号完整性,具有低VSWR和低插入损耗。文档中提供了2.92mm Female到2.92mm Female适配器的VSWR和插入损耗数据。
应用信息:适配器适用于需要精确射频和微波连接的各种应用,包括测试和测量产品。
封装信息:适配器采用钝化不锈钢体,中心导体为固定铍铜,可选镀金外壳或非固定中心导体。
TMA-8MS-9FS-00 价格&库存
很抱歉,暂时无法提供与“TMA-8MS-9FS-00”相匹配的价格&库存,您可以联系我们找货
