TM14-0053-00TR
TM14-0053-00TR
    TRI-STAR
    SMPM 连接器 插座,公插针 50 欧姆 表面贴装,直角 焊接
TM14-0053-00TR 数据手册
8 D 5 6 7 SPECIFICATIONS: ELECTRICAL RATINGS... IMPEDANCE 50 Ohm FREQUENCY RANGE DC TO 65 GHz RETURN LOSS > 19 dB, DC TO 26.5 GHz > 13 dB, 26.5 TO 40 GHz > 9 dB, 40 to 60 GHz INSERTION LOSS > 0.05 x sqr root f(GHz), DC TO 26.5 GHz INSULATION RESISTANCE > 5GΩ CONTACT RESISTANCE CENTER CONTACT OUTER CONTACT WORKING VOLTAGE (AT SEA LEVEL) (AT 70000 FEET) 4 2 3 REVISIONS DESCRIPTION INITIAL RELEASE UPDATE ELECT DATA REV. A B DATE 2/7/2018 8/2/2019 APPROVED R BEDIENT R BEDIENT D 4.00 3.40 5.00 1.32 < 6.0mΩ < 2.0 mΩ 5 O 2.87 325 V rms 125 V rms 1 2.14±0.02 3.40 O 4.40 C C 0.75 O 4.40 0.40 O 0.10+0.03 - 0.05 (SHELL / PIN) 0.95±0.19 (SHELL / PIN) BODY 2.20 INSULATOR FILM PIN 1.00 B 0.305±0.010 B 0.40 1.40 RECOMMENDED PCB PAD LAYOUT A 5 4. POSITION INSULATOR FLUSH TO SHELL 0.00~0.05mm THESE CHARACTERISTICS ARE TYPICAL AND FOR REFERENCE 3. 2. 1. O REPRESENTS A CRITICAL DIMENSION PARTS TO BE PACKAGED IN TRAYS MATERIALS: INSULATORS: TEFLON WHITE PIN: BRASS C3602B Cu 0.30μin, Ni 50μin, Au 0.30μin BODY: BRASS C3604B Cu 0.30μin, Ni 50μin, Au 0.30μin INSULATOR TM4-0053-00 TRAY , 800 PCS / 400 HOLES PART NO. PACKING 7911 188th ST SUITE #100 Kent, WA 98032 DO NOT SCALE DRAWING UNLESS OTHERWISE SPECIFIED DIMENSION ARE IN MM TOLERANCES ARE: NOTES: UNLESS OTHERWISE SPECIFIED... THE INFORMATION CONTAINED HEREIN IS PROPRIETARY TO CARLISLE, INC. AND SHALL IN NO WAY BE REPRODUCED OR DISCLOSED IN WHOLE OR IN PART OR USED FOR ANY DESIGN OR MANUFACTURE EXCEPT WHEN SUCH USER POSSESSES DIRECT, WRITTEN AUTHORIZATION FROM CARLISLE, INC. 7 TAPE & REEL 2000pcs / REEL DHZ53-10019-12020 FILM: POLYIMIDE (BROWN) 8 TM14-0053-00TR 6 .X ` .25 .XX ` .13 ANGLES ` 1.0 SURF FINISH = 40 5 4 APPROVALS DRAWN BY R BEDIENT ENGINEER PRODUCTION QUALITY 3 DATE 02/06/18 R BEDIENT 02/06/18 A SMPM STR, PLUG R/A CONTACT, SMT RECEPTICAL (FULL DETENT) SIZE CAGE CODE B 7M294 SCALE: 16:1 2 DRAWING NUMBER TM14-0053-XX REV B PART NUMBER: TM14-0053-XX 1 OF 1 1
TM14-0053-00TR 价格&库存
很抱歉,暂时无法提供与“TM14-0053-00TR”相匹配的价格&库存,您可以联系我们找货
