TMB-E8FS-1S1
TMB-E8FS-1S1
    TRI-STAR
    1.85mm 连接器 插孔,母形插口 50 欧姆 板边缘,末端装入式 焊接
TMB-E8FS-1S1 数据手册
3 4 2 1 REVISIONS .691 17.56 .187 4.75 TYP .421 10.69 D [.040] 1.02 TYP [.040] 1.02 TYP .230 5.84 REV. DESCRIPTION DATE APPROVED - INITIAL RELEASE 07/24/2018 MM 1 UPDATED PART NUMBER AND COLOR 10/26/2018 DL 2 ADDED SHEET 2 PCB DEFINITION 2/20/2019 PV 3 ADDED SECTION VIEW 3/12/2019 PV D .003 0.07 [.312] 7.92 [.068] 1.73 TYP .073 1.85 M7.00 X 0.75P-6g C SEE DETAIL A .004 0.10 [.154] 3.90 TYP [.375] 9.52 C .028 0.71 .039 1.00 .0070±.0004 0.178±0.010 .012 0.31 .016 0.41 .014 0.35 B NOTE(S): 1. These characteristics are typical and for reference. 2. DYH: 59-20010-12070 3. See sheet 2 for PCB interface definition. DETAIL A SCALE 20:1 MATERIAL(S): ELECTRICAL(S): MECHANICAL(S): ENVIRONMENTAL(S): Body: Brass Center Conductor: Beryllium Copper Insulator: Insulator1: PCTFE, white Insulator 2: PTFE, white RoHS Compliant Protective Cap: Soft PVC Color: Green Impedence: 50 Ohms Nominal Frequency Range: DC to 65 GHz VSWR: 1.3:1 max at 65 GHz Working Voltage: 400 Vrms max @ Sea Level Dielectric Withstand Voltage: 500 Vrms max. Insulation Resistance: 5000 Megaohms min. Contact Resistance: Initial: Center Contact: 1.5 Milliohms max Outer Contact: 0.8 Milliohms max Mating Characteristics: Interface per MIL-STD-348 Force to Engage & Disengage: Torque: 2 inch-pounds max Longitudinal Force: NA Connector Durability: 500 Cycles min. Permeability: Less than 2.0 mu. Center Contact Retention: Axial Force: 6 pounds min. Radial Force: NA Temperature Range: -65 C to +165 C Moisture Resistance: MIL-STD-202, Method 103, Test Condition B Corrosion: MIL-STD-202, Method 101, Test Condition B Vibration: MIL-STD-202, Method 204, Test Condition A Shock: MIL-STD-202, Method 213, Test Condition 1 APPROVAL INITIALS DATE APPLICABLE CARLISLE IT DOCUMENTS TOLERANCES AND NOTES EXCEPT AS NOTED DRAWN MM 07.24.18 ASSY INSTRUC WORK STANDARD PROD INSTRUC FINISH(ES): A B PROTECTION CAP Body: Gold Plating Center Conductor: Gold Plating ENG-SW REV. E NA - NA N O T I C E NA THIS DRAWING EMBODIES A CONFIDENTIAL PROPRIETARY DESIGN ORIGINATED BY CARLISLE INTERCONNECT TECHNOLOGIES & ALL DESIGN, MANUFACTURING, REPRODUCTION, USE & SALE RIGHTS REGARDING THE SAME ARE EXPRESSLY RESERVED. IT IS SUBMITTED UNDER A CONFIDENTIAL RELATIONSHIP FOR A SPECIFIED PURPOSE & THE RECIPIENT AGREES BY ACCEPTING THIS DRAWING NOT SUPPLY OR DISCLOSE ANY INFORMATION REGARDING IT TO ANY UNAUTHORIZED PERSON TO INCORPORATE IN OTHER PROJECTS ANY SPECIAL FEATURES PECULIAR TO THIS DESIGN. ALL PATENT RIGHTS HERETO ARE EXPRESSLY RESERVED BY CARLISLE INTERCONNECT TECHNOLOGIES, CERRITOS, CALIFORNIA 90703. 4 3 THIRD ANGLE PROJECTION SCALE 8:1 BY CHECKED BY KM Dongguan City, Guangdong P.R. China 523533 07.24.18 TITLE DIMENSIONS ARE IN [INCHES] MM ANGLES 2 DESIGN ENG SCALE .XX DECIMALS .063 .XXX DECIMALS .01 APPR BY SIZE 2 1.85mm STRAIGHT JACK, EDGE MOUNT (MANUAL SOLDER) 8:1 C SUB-DIRECTORY/ _OUTLINE/ DRAWING NO. SHEET TMB-E8FS-1S1 1 1 OF 2 REV. 3 A 4 3 2 1 SUBSTRATE EDGE .117 2.98 D .020 0.50 .010 0.25 (REF) MAY BE LOCATED CLOSER TO EDGE .059 1.50 .008 0.20 TYP .020 0.50 .047 1.20 .028 0.70 .059 1.50 .018 0.46 TYP .117 2.98 .193 4.90 .335 8.50 .032 0.82 SOLDER PASTE STENCIL SCALE 6:1 .022 0.55 .018 0.46 TYP .008 0.20 TYP .063 1.60 .032 0.82 DETAIL B C .022 0.55 DETAIL C SCALE 20 : 1 C SCALE 20 : 1 B C .244 6.20 B D .010 0.25 (REF) MAY BE LOCATED CLOSER TO EDGE .059 1.50 .244 6.20 CONNECTOR KEEPOUT CONNECTOR KEEPOUT .404 10.25 .020 0.50 BODY .022 0.56 .404 10.25 .020 0.50 BODY PIN B .012 0.31 PIN LAYER 1: Cu (0.036mm [1.4mil]) LAYER 1: Cu (0.036mm [1.4mil]) PCB (REF) PCB (REF) A LAYER 2: SUBSTRATE (0.203mm [8.0mil]) DIELECTRIC LAYER 2: SUBSTRATE (0.457mm [18.0mil]) DIELECTRIC A PCB LAYOUT OPTION 2 0.203mm [8.0mil] THICK SUBSTRATE (LAYER 2) PCB LAYOUT OPTION 1 PCB LAYOUT (FOR REFERENCE ONLY) 0.457mm [18.0mil] THICK SUBSTRATE (LAYER 2) SCALE 8:1 4 3 SHEET SIZE CAGE CODE DRAWING NO. C ENG-SW REV. E SUB-DIRECTORY/ 2 TMB-E8FS-1S1 1 2 OF 2 REV. 3
TMB-E8FS-1S1 价格&库存
很抱歉,暂时无法提供与“TMB-E8FS-1S1”相匹配的价格&库存,您可以联系我们找货
