HS19AL1UD2
HS19AL1UD2
    CHEVAL(雪佛)
    CHASSIS HEATSINK 425x335x39.6MM.
HS19AL1UD2 数据手册
NEW HS-19 Series: 19” Heatsink Enclosure The HS-19 Series of rack mounted 19” heatsink enclosures is a versatile and user friendly 19” enclosure series. Designed for both professional users and home hobbyists alike, HS-19 features extruded aluminum heatsink side panels. The high grade aluminum body features removable top and bottom panels providing easy access to work inside. An inner front panel allows you to mount all your components on it and the 3.00 mm thick Aluminum outer front panel covers it to give your project a professional look. Extruded aluminum component mounting rails are slotted to allow for convenient PCB and component installation. HS-19 is provided with self adhesive rubber feet if rack mounting is not required. Key Features Extruded heatsink side panels provide excellent cooling Inside face of side panels have slot for easy general purpose bar installation All aluminum construction Inner front panel for component mounting allows outer front panel to remain “clean” appearance “Open Frame” design maximizes user convenience for component assembly Heavy duty handles Optional mounting plates for PCB and heavy components such as transformers 19” rack mounted or free standing Flat pack for efficient storage and shipping International Inquiries: Thailand Inquiries: Email: commce@chevalgrp.com Email: domestic_sales@chevalgrp.com Cheval Electronic Enclosure Co., Ltd. Tel: +66 2315 1504-5 Tel: +66 2744 1632 Fax: +66 2315 1506 Fax: +66 2399 1783 CPI.18.00.038 Standards and Materials 1U Heights from 1U to 6U Depths of 245mm, 335mm and 425mm Conforms to IEC-60297-3. Premium grade aluminum sheet: AL 5052 and extrusion: AA 6063 (Aluminum Alloy). 2U Designed and manufactured under ISO 9001:2015 and ISO 14001:2015 All materials RoHS compliant. 3U 4U 5U 6U 15 sizes to select Applications Mounting PCB on the GP bar and attaching electronic component to heatsink side frame Attaching electronic component to heatsink side frame Installing on 19” Rack Mounting PSU for component on the GP bar Models & Dimensions G Exploded view Pic. 1: Front view Pic. 3: Top view Pic. 2: Side view Size Front Panel (A x B mm.) Cabinet Size (E x D x C mm.) Handle (G x F mm.) 1U-D1 1U-D2 1U-D3 2U-D1 2U-D2 2U-D3 3U-D2 3U-D3 4U-D2 4U-D3 5U-D2 5U-D3 6U-D2 6U-D3 6U-D4 482.6 x 43.7 482.6 x 43.7 482.6 x 43.7 482.6 x 88.1 482.6 x 88.1 482.6 x 88.1 482.6 x 132.6 482.6 x 132.6 482.6 x 177.0 482.6 x 177.0 482.6 x 221.5 482.6 x 221.5 482.6 x 266.0 482.6 x 266.0 482.6 x 266.0 425 x 245 x 39.6 425 x 335 x 39.6 425 x 425 x 39.6 425 x 245 x 84.0 425 x 335 x 84.0 425 x 425 x 84.0 425 x 335 x 128.6 425 x 425 x 128.6 425 x 335 x 173.0 425 x 425 x 173.0 425 x 335 x 217.3 425 x 425 x 217.3 425 x 335 x 262.0 425 x 425 x 262.0 425 x 465 x 262.0 38 x 40 38 x 40 38 x 40 82.4 x 40 82.4 x 40 82.4 x 40 113 x 40 113 x 40 151 x 40 151 x 40 192 x 40 192 x 40 236.5 x 40 236.5 x 40 236.5 x 40 Pic. 1 Pic. 2&3 Pic. 2 Cheval strives to provide the latest information in all our product literature. Due to our continuous product development progress, product appearance, specifications and dimensions may change without notice. To ensure you have the latest information, please contact Cheval or your local representative.
HS19AL1UD2 价格&库存
很抱歉,暂时无法提供与“HS19AL1UD2”相匹配的价格&库存,您可以联系我们找货
