PF-19AL3UD2
PF-19AL3UD2
    CHEVAL(雪佛)
    CHASSIS AL 19 425x335x127.6 MM.
PF-19AL3UD2 数据手册
PF-19 Series NEW Aluminum Design The PF-19 Series of rack mounted 19” Enclosures is very versatile and user friendly. Designed for both professional users and home hobbyists alike, our latest version continues the trend of reducing hardware and maximizing user convenience. The high grade aluminum body features perforated, removable top and bottom panels providing ample ventilation and easy access to work inside. The 3.00 mm thick Aluminum outer front panel covers the easily worked inner front panel to give your project a professional look. Our customized extruded aluminum component mounting bars are slotted to allow for convenient PCB and component installation. PF-19 is provided with self adhesive rubber feet if rack mounting is not required. Standards and Materials Heights from 1U to 6U Depths of 245mm, 335mm and 425mm Dimensions conform to IEC-60297-3 Premium grade (AL 5052) aluminum. Designed and manufactured under ISO 9001:2008 and ISO 14001:2004 All materials RoHS compliant. International Inquiries: Email: commce@chevalgrp.com Tel: +66 2315 1504-5 Fax: +66 2315 1506 Thailand Inquiries: Email: domestic_sales@chevalgrp.com Tel: +66 2744 1632 Fax: +66 2399 1783 Cheval Electronic Enclosure Co., Ltd www.chevalgrp.com Key Features Light weight and strong Very durable all aluminum (AL 5052) construction Easy to assemble Extensive top/bottom and side/side ventilation Inner front panel for component mounting allows outer front panel to remain “clean” appearance Two pieces of extruded aluminum component mounting bars for components fixing are included in the basic kit. Additional bars may be ordered as needed. Optional mounting plates for PCB and heavy components such as transformers Optional solid side covers for air flow control or decorative look in non 19” rack mounted applications 19” rack mounted or free standing Flat pack for efficient storage and shipping “Open Frame” design maximizes user convenience for component assembly Part Number PF19AL1UD1 PF19AL1UD2 PF19AL1UD3 PF19AL2UD1 PF19AL2UD2 PF19AL2UD3 PF19AL3UD2 PF19AL3UD3 PF19AL4UD2 PF19AL4UD3 PF19AL5UD2 PF19AL5UD3 PF19AL6UD3 PF19AL6UD4 Front Panel Size (mm.) (A x B) 482.60 x 43.70 x 3.00 482.60 x 43.70 x 3.00 482.60 x 43.70 x 3.00 482.60 x 88.10 x 3.00 482.60 x 88.10 x 3.00 482.60 x 88.10 x 3.00 482.60 x 132.60 x 3.00 482.60 x 132.60 x 3.00 482.60 x 177.00 x 3.00 482.60 x 177.00 x 3.00 482.60 x 221.50 x 3.00 482.60 x 221.50 x 3.00 482.60 x 265.90 x 3.00 482.60 x 265.90 x 3.00 Unit Gross Cabinet Size (mm.) (C x D x E) Weight (kg.) 38.70 x 245.00 x 425.00 1.77 38.70 x 335.00 x 425.00 2.14 38.70 x 425.00 x 425.00 2.52 83.10 x 245.00 x 425.00 2.16 83.10 x 335.00 x 425.00 2.57 83.10 x 425.00 x 425.00 2.95 127.60 x 335.00 x 425.00 2.94 127.60 x 425.00 x 425.00 3.37 172.00 x 335.00 x 425.00 3.36 172.00 x 425.00 x 425.00 3.79 216.50 x 335.00 x 425.00 3.78 216.50 x 425.00 x 425.00 4.21 261.00 x 425.00 x 425.00 4.42 261.00 x 465.00 x 425.00 4.63 Carton Dimension H x W x D (mm.) 70 x 281.70 x 498.40 70 x 371.70 x 498.40 70 x 461.70 x 498.40 70 x 281.70 x 498.40 70 x 371.70 x 498.40 70 x 461.70 x 498.40 70 x 371.70 x 498.40 70 x 461.70 x 498.40 70 x 371.70 x 498.40 70 x 461.70 x 498.40 70 x 371.70 x 498.40 70 x 461.70 x 498.40 70 x 461.70 x 498.40 70 x 502.00 x 498.40 Cheval strives to provide the latest information in all our product literature. Due to our continuous product development program, product appearance, specifications and dimensions may change without notice. To ensure you have the latest information, please contact Cheval or your local representative.
PF-19AL3UD2 价格&库存
很抱歉,暂时无法提供与“PF-19AL3UD2”相匹配的价格&库存,您可以联系我们找货
