1732-W48-CW
1732-W48-CW
    VCC
    PMI LED 17/32" 48V WIRE WHITE
1732-W48-CW 数据手册
17/32" MOUNT PANEL LIGHT WITH LENS Data Display Products ® High Intensity, Wide Angle 1 TO ORDER, FOLLOW THE EXAMPLE: Model Select one BOLD component from each SHADED column in the tables below. 1732 LED Voltage Lens Bi-Polar 3 1Model 2 4 5 1732 -B 24 -CB ➜Part Number 1732-B24-CB 2 LED Color -R -A -G -B -W -L RED AMB GRN BLU CWHT WWHT λpk Iv[1] V/C (nm) (mcd) Table[2] 634 592 520 465 2180 2180 2000 600 2500 1800 I I II II II II Voltage/Current Design Max Vf/If Vf/If V/C Table I 5.5V/28mA 5V/22mA 6V/21mA 7V/27mA 12V/20mA 14V/25mA 15V/24mA 16.5V/28mA 24V/17mA 26V/20mA 28V/16.5mA 30V/18mA 48V/15mA 50V/16mA 60V/9mA 65V/10mA 120VAC/3.5mA 130VAC/4mA 3 Voltage[3] 5 6 12 15 24 28 48 60 120 4 Lens -CR Red -CA Amber -CG Green -CB Blue -CW Water Clear Voltage/Current Design Max Vf/If Vf/If V/C Table II 5V/15mA 5.5V/23mA 6V/15mA 7V/25mA 12V/15mA 14V/20mA 15V/15mA 16.5V/18mA 24V/15mA 26V/18mA 28V/15mA 30V/17mA 48V/9.5mA 50V/10mA 60V/7mA 65V/8mA 130VAC/4mA 120VAC/3.5mA 1732 5 Bi-Polar -BP (optional) [1] Iv = typical luminous intensity @ If = 20mA (Ta=25°C). Luminous intensity is measured without the lens. [2] See Voltage/Current table for design specifications. Standard Wire Leads: 6.0" total length(nominal)/.50" stripped (nominal), red anode/black cathode, 24 AWG TPB UL1061 insulation. Contact factory for other lengths, gauges and colors. 60 [3] Ta = 25°C. Voltages 5 through 60 are VDC. For AC operation, insert AC after Voltage (e.g. 24AC), not required for 120V. Contact factory for VAC design currents. For 120VDC insert DC after Voltage (e.g. 120DC). All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products
1732-W48-CW 价格&库存
很抱歉,暂时无法提供与“1732-W48-CW”相匹配的价格&库存,您可以联系我们找货
