17/32"
MOUNT PANEL LIGHT WITH LENS
Data Display Products
High Intensity, Wide Angle
1
TO ORDER, FOLLOW THE EXAMPLE:
Model
Select one BOLD component from each SHADED column in the tables below.
1732
LED
Voltage
Lens
Bi-Polar
3
1Model
2
4
5
1732
-B
24
-CB
➜Part Number 1732-B24-CB
2 LED
Color
-R
-A
-G
-B
-W
-L
RED
AMB
GRN
BLU
CWHT
WWHT
λpk
Iv[1]
V/C
(nm)
(mcd)
Table[2]
634
592
520
465
2180
2180
2000
600
2500
1800
I
I
II
II
II
II
Voltage/Current
Design
Max
Vf/If
Vf/If
V/C Table I
5.5V/28mA
5V/22mA
6V/21mA
7V/27mA
12V/20mA
14V/25mA
15V/24mA
16.5V/28mA
24V/17mA
26V/20mA
28V/16.5mA
30V/18mA
48V/15mA
50V/16mA
60V/9mA
65V/10mA
120VAC/3.5mA
130VAC/4mA
3
Voltage[3]
5
6
12
15
24
28
48
60
120
4
Lens
-CR
Red
-CA
Amber
-CG
Green
-CB
Blue
-CW
Water
Clear
Voltage/Current
Design
Max
Vf/If
Vf/If
V/C Table II
5V/15mA
5.5V/23mA
6V/15mA
7V/25mA
12V/15mA
14V/20mA
15V/15mA
16.5V/18mA
24V/15mA
26V/18mA
28V/15mA
30V/17mA
48V/9.5mA
50V/10mA
60V/7mA
65V/8mA
130VAC/4mA
120VAC/3.5mA
1732
5
Bi-Polar
-BP
(optional)
[1] Iv = typical luminous intensity @ If = 20mA (Ta=25°C). Luminous intensity is measured
without the lens.
[2] See Voltage/Current table for design specifications.
Standard Wire Leads:
6.0" total length(nominal)/.50" stripped (nominal), red
anode/black cathode, 24 AWG TPB UL1061 insulation.
Contact factory for other lengths, gauges and colors.
60
[3] Ta = 25°C. Voltages 5 through 60 are VDC. For AC operation, insert AC after Voltage (e.g. 24AC), not
required for 120V. Contact factory for VAC design currents. For 120VDC insert DC after Voltage
(e.g. 120DC).
All dimensions are in inches (mm)
Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25)
Specifications are subject to change without notice.
445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639
ww w.datadisplay.com
© 2005 Data Display Products
很抱歉,暂时无法提供与“1732-W120-CW”相匹配的价格&库存,您可以联系我们找货
