The PowerLine® 24LS series LED lamps are designed as drop-in
replacements for the industry-standard 24E and 24X incandescent
bulbs. Several models are available designed specifically for
operation in GE ET-5, ET-6 and Westinghouse Minalite sockets.
No modification to input voltage or series resistance is required.
ET-5 socket not included
To select a PowerLine® LED lamp:
1. Identify your input voltage and series resistor from the chart below.
Series resistor values are usually marked on the socket.
2. Select the appropriate PowerLine® LED part number.
3. Replace “X1” in the part number with the color code (see LED color code chart below)
INPUT
VOLTAGE
SERIES
RESISTOR
MAXIMUM PowerLine® LED
VOLTAGE
PART #
BI-POLAR
130AC/DC
48DC
3.2KΩ
900Ω
140
56
24LS4-X1
YES
130DC
24DC
48DC
600DC
3.2KΩ
110Ω
900Ω
20KΩ
140
26
56
650
24LS2-X1
NO
130DC
2KΩ
140
24LS8-X1
YES
67AC
115AC
230AC
250AC
460AC
575AC
1.5KΩ
2.8KΩ
6.3KΩ
7.2KΩ
13KΩ
17KΩ
75
125
250
280
500
630
24LS10-X1
YES
125DC
250DC
Dim/Bright
140
280
24LS12-X1
YES
115AC
230AC
Dim/Bright
125
250
24LS16-X1
YES
LED
COLOR
CODE
EMITTED
COLOR
-R1
-O1
-A1
-G1
-B1
-W1
Red
Orange
Amber
Green
Blue
White
24LS Series
Slide Base #3
Used to illuminate the following lenses
Red
Orange Amber
Yellow
Green
Blue
White
Clear
www.powerlineleds.com
• Replaces 24E and 24X incandescent bulbs
• For GE ET-5, ET-6 and Westinghouse Minalite Socket
• Built-in shunt resistor to clamp noise current
• Bi-polar (optional)
• High-intensity
• Up to 100,000-hour life
• Shock and vibration resistant
T-2 SLIDE BASED LAMPS 24LS SERIES
PowerLine LEDs
T-2 SLIDE BASED
LAMPS 24LS SERIES
All dimensions are in inches (mm) Tolerances: .xx”(.x) ±.025:”(.63)/ .xxx”(.xx)±.010”(.25) Specifications are subject to change without notice.
www.powerlineleds.com l Tel. 800-421-6815 l Fax 310-640-7639 © 2008 DDP
9
很抱歉,暂时无法提供与“24LS10-O1”相匹配的价格&库存,您可以联系我们找货
