405-GLP2-CGO
405-GLP2-CGO
    VCC
    LED-2P_D8.5X21.4MM_TM
    PMI .250" LED 2V TAB CLEAR GREEN
405-GLP2-CGO 数据手册
.250" MOUNT PANEL LIGHTS Data Display Products ® 40 Series - Mounting Hardware Provided - For Detailed LED Data, See Discrete Section, MODEL 200 1 Wires Model C[1] (optional) 405 [2] 41 44 46 461 464 TO ORDER, FOLLOW THE EXAMPLE: Select one BOLD component from each numbered category in the tables below. W (optional) Model 1 LED 2 -BCG 3 41 -BR[4] -BA[4] -BG[4] -BCR -BCA -BCG 4 Voltage/Current λpk Iv[3] Viewing V/C Color (nm) (mcd) Angle Table[5] RED AMB GRN 635 583 565 60 60 60 I I I 14 16 10 Design Max Vf/If Vf/If V/C Table I 5V/22mA 5.5V/28mA 12V/20mA 14V/25mA 15V/24mA 16.5V/28mA 24V/17mA 26V/20mA 28V/16.5mA 30V/18mA 48V/15mA 50V/16mA 60V/9mA 65V/10mA 120VAC/3.5mA 130VAC/4mA MEDIUM INTENSITY - TINTED ENCAPSULATION LED 5H Lens Diffusion λpk Iv[3] Viewing V/C Color (nm) (mcd) Angle Table[5] RED AMB GRN 635 583 565 35 35 24 I I I 120 100 80 λpk Iv[3] Viewing LED V/C Color (nm) (mcd) Angle Table[5] -NWR -NWO -NWA -NWG -NWB -NWW[8] -NWL[8] -NKR -NKO -NKA -NKG -NKB -NKW[8] -NKL[8] RED ORG AMB GRN BLU CWHT WWHT RED ORG AMB GRN BLU CWHT WWHT 634 605 592 520 465 2800 2000 2800 2400 700 2500 1800 3600 8000 3600 10000 3000 9200 9200 30 30 30 45 45 50 50 15 15 15 15 15 20 15 I I I II II II II I I I II II II II 634 605 592 520 465 6 G 0 Voltage[6] 2 5H 12H 15H 24H 28H 48H 60H 120[9] 4 Lens Diffusion -C Clear -N Diffused 5 Lens Color R Red B Blue A Amber W Water Clear -S Smoke[10] G Green 6 λpk Iv[3] Viewing V/C Color (nm) (mcd) Angle Table[5] Description RED AMB GRN RED/GRN RED/AMB/GRN GRN/AMB/RED 635 583 565 660/565 630/565 635/565 2.3 2.1 2.3 90/40 6/6/6 5/5/5 50 50 50 60 60 50 [5] [5] [5] Low Power Low Power Low Power Bi-Color, Red Cathode Tri-Color, Common Cathode Tri-Color, Common Anode [1] The C option specifies a pin length = .20" for panel lights mounted in the PS40 or PS44 socket (pg. 44). Mounting hardware is included with the socket. Do not select the W option. [2] Model 405 has no lens. Omit the Lens Diffusion and Color (e.g. 405-BG5H-0). [3] Iv = typical luminous intensity @ If = 20mA (Ta =25°C). Iv is measured without lenses. For Low Power LEDs, If = 2mA. [4] Use with Model 405 only. [5] See Voltage/Current table for design specifications. Design current for low power LEDs = 2mA. 42 5 Bezel Color Y Yellow SPECIALTY LEDs -RLP[7] -ALP[7] -GLP[7] -LRG[8] -RAG[8] -GAR[8] 3 Voltage/Current Design Max Vf/If Vf/If V/C Table II 5V/15mA 5.5V/23mA 12V/15mA 14V/20mA 15V/15mA 16.5V/18mA 24V/15mA 26V/18mA 28V/15mA 30V/17mA 48V/9.5mA 50V/10mA 60V/7mA 65V/8mA 120VAC/3.5mA 130VAC/4mA HIGH INTENSITY - WATERCLEAR ENCAPSULATION LED -C Lens Color ➜Part Number 41-BCG5H-CG0 STANDARD INTENSITY - DIFFUSED ENCAPSULATION 2 LED Voltage I I I Bezel Color 0 Black 9 White [6] Ta = 25°C. Voltage "2" indicates external resistor required. Voltages 5H through 60H are VDC. For AC operation, insert D after Voltage (e.g. 24HD), D indicates built-in rectifier; not required for 5H or 120VAC. DC operation not available for 120V. Bi-Color and Tri-Color not available in AC voltages. [7] Omit H when selecting a voltage (e.g. 41-RLP12-CWO). [8] Select -CW or -NW lens only. -RAG Wire Leads: green anode/black cathode/red anode. -GAR Wire Leads: green cathode/black anode/red cathode. Common lead is the first lead clockwise from reference mark on header. Tri-Color 5 or 12 volt, omit H in part number. [9] Select high intensity LEDs only. [10]Omit lens diffusion when selecting smoked lens. (e.g. 46-NWR-S0). 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products Data Display Products ® .250" MOUNT PANEL LIGHTS 40 Series 405 (no lens) 41 44 (flush lens) 46 461 464 TC4 & NW4, Mounting Hardware Standard Wire Leads: 6.0" total length(nominal)/.50" stripped (nominal), red anode/black cathode, 24 AWG TPB UL1061 insulation. Contact factory for other lengths, gauges and colors. see note [1] All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products 43 .250" MOUNT PANEL LIGHT SOCKETS Data Display Products ® 40 Series Mounting Hardware - Sockets for 40 Series Panel Lights TO ORDER, FOLLOW THE EXAMPLE: Select one BOLD component from each SHADED column in the tables below. Model/ Part # 1 PS40 2 # of Pins -2 ➜Part Number PS40-2 2 Number of Pins 40 SERIES SOCKETS & WIRING PLUGS 1 Model PS40 PS44 SH40 CSH40 Description Sockets for Sockets for Wiring Plug Wiring Plug use with Models C405, C41, C46, C461 use with Models C44, C464 for use with 40 or C40 series for use with C40 series -2 -3 -4 Configuration 2, 4 1, 2, 4 1, 2, 3, 4 40 SERIES HARDWARE P art Number CS24 CS24T TC4 NW4 PS40 44 Description Gold Plated Crimp Terminals Tin Plated Crimp Terminals 40 Series Mounting Clip 40 Series Mounting Washer TC5 & NW5 mounting hardware provided PS44 TC5 & NW5 mounting hardware provided 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products Data Display Products ® .250" MOUNT PANEL LIGHT SOCKETS 40 Series Mounting Hardware CSH40 SH40 CS24 & CS24T 22AWG to 28AWG TC4 & NW4, Mounting Hardware All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products 45
405-GLP2-CGO 价格&库存
很抱歉,暂时无法提供与“405-GLP2-CGO”相匹配的价格&库存,您可以联系我们找货
