.250" MOUNT PANEL LIGHTS
Data Display Products
40 Series
- Mounting Hardware Provided
- For Detailed LED Data, See Discrete Section, MODEL 200
1
Wires
Model
C[1]
(optional)
405 [2]
41
44
46
461
464
TO ORDER, FOLLOW THE EXAMPLE:
Select one BOLD component from each numbered category in the tables below.
W
(optional)
Model
1
LED
2 -BCG 3
41
-BR[4]
-BA[4]
-BG[4]
-BCR
-BCA
-BCG
4
Voltage/Current
λpk
Iv[3]
Viewing
V/C
Color
(nm)
(mcd)
Angle
Table[5]
RED
AMB
GRN
635
583
565
60
60
60
I
I
I
14
16
10
Design
Max
Vf/If
Vf/If
V/C Table I
5V/22mA
5.5V/28mA
12V/20mA
14V/25mA
15V/24mA
16.5V/28mA
24V/17mA
26V/20mA
28V/16.5mA
30V/18mA
48V/15mA
50V/16mA
60V/9mA
65V/10mA
120VAC/3.5mA
130VAC/4mA
MEDIUM INTENSITY - TINTED ENCAPSULATION
LED
5H
Lens
Diffusion
λpk
Iv[3]
Viewing
V/C
Color
(nm)
(mcd)
Angle
Table[5]
RED
AMB
GRN
635
583
565
35
35
24
I
I
I
120
100
80
λpk
Iv[3]
Viewing
LED
V/C
Color
(nm)
(mcd)
Angle
Table[5]
-NWR
-NWO
-NWA
-NWG
-NWB
-NWW[8]
-NWL[8]
-NKR
-NKO
-NKA
-NKG
-NKB
-NKW[8]
-NKL[8]
RED
ORG
AMB
GRN
BLU
CWHT
WWHT
RED
ORG
AMB
GRN
BLU
CWHT
WWHT
634
605
592
520
465
2800
2000
2800
2400
700
2500
1800
3600
8000
3600
10000
3000
9200
9200
30
30
30
45
45
50
50
15
15
15
15
15
I
I
I
II
II
II
II
I
I
I
II
II
II
II
634
605
592
520
465
6
G
Voltage[6]
2
5H
12H
15H
24H
28H
48H
60H
120[9]
4
Lens
Diffusion
-C
Clear
-N
Diffused
5
Lens Color
R Red
B Blue
A Amber
W Water
Clear
-S Smoke[10]
G Green
6
λpk
Iv[3]
Viewing
V/C
Color
(nm)
(mcd)
Angle
Table[5]
Description
RED
AMB
GRN
RED/GRN
RED/AMB/GRN
GRN/AMB/RED
635
583
565
660/565
630/565
635/565
2.3
2.1
2.3
90/40
6/6/6
5/5/5
50
50
50
60
60
50
[5]
[5]
[5]
Low Power
Low Power
Low Power
Bi-Color, Red Cathode
Tri-Color, Common Cathode
Tri-Color, Common Anode
[1] The C option specifies a pin length = .20" for panel lights mounted in the PS40 or PS44 socket
(pg. 44). Mounting hardware is included with the socket. Do not select the W option.
[2] Model 405 has no lens. Omit the Lens Diffusion and Color (e.g. 405-BG5H-0).
[3] Iv = typical luminous intensity @ If = 20mA (Ta =25°C). Iv is measured without lenses.
For Low Power LEDs, If = 2mA.
[4] Use with Model 405 only.
[5] See Voltage/Current table for design specifications. Design current for low power LEDs = 2mA.
42
5
Bezel
Color
Y Yellow
SPECIALTY LEDs
-RLP[7]
-ALP[7]
-GLP[7]
-LRG[8]
-RAG[8]
-GAR[8]
3
Voltage/Current
Design
Max
Vf/If
Vf/If
V/C Table II
5V/15mA
5.5V/23mA
12V/15mA
14V/20mA
15V/15mA
16.5V/18mA
24V/15mA
26V/18mA
28V/15mA
30V/17mA
48V/9.5mA
50V/10mA
60V/7mA
65V/8mA
120VAC/3.5mA
130VAC/4mA
HIGH INTENSITY - WATERCLEAR ENCAPSULATION
LED
-C
Lens
Color
➜Part Number 41-BCG5H-CG0
STANDARD INTENSITY - DIFFUSED ENCAPSULATION
2 LED
Voltage
I
I
I
Bezel
Color
Black
9
White
[6] Ta = 25°C. Voltage "2" indicates external resistor required. Voltages 5H through 60H are VDC.
For AC operation, insert D after Voltage (e.g. 24HD), D indicates built-in rectifier; not required for 5H
or 120VAC. DC operation not available for 120V. Bi-Color and Tri-Color not available in AC voltages.
[7] Omit H when selecting a voltage (e.g. 41-RLP12-CWO).
[8] Select -CW or -NW lens only. -RAG Wire Leads: green anode/black cathode/red anode. -GAR Wire
Leads: green cathode/black anode/red cathode. Common lead is the first lead clockwise from
reference mark on header. Tri-Color 5 or 12 volt, omit H in part number.
[9] Select high intensity LEDs only.
[10]Omit lens diffusion when selecting smoked lens. (e.g. 46-NWR-S0).
445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639
ww w.datadisplay.com
© 2005 Data Display Products
40 Series
405 (no lens)
41
44 (flush lens)
46
461
464
TC4 & NW4, Mounting Hardware
Standard Wire Leads:
6.0" total length(nominal)/.50" stripped (nominal), red
anode/black cathode, 24 AWG TPB UL1061 insulation.
Contact factory for other lengths, gauges and colors.
see note [1]
All dimensions are in inches (mm)
Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25)
Specifications are subject to change without notice.
43
.250" MOUNT PANEL LIGHT SOCKETS
40 Series Mounting Hardware
- Sockets for 40 Series Panel Lights
Select one BOLD component from each SHADED column in the tables below.
Model/
Part #
1 PS40 2
# of
Pins
-2
➜Part Number PS40-2
2 Number
of Pins
40 SERIES SOCKETS & WIRING PLUGS
1
Model
PS40
PS44
SH40
CSH40
Description
Sockets for
Sockets for
Wiring Plug
Wiring Plug
use with Models C405, C41, C46, C461
use with Models C44, C464
for use with 40 or C40 series
for use with C40 series
-2
-3
-4
Configuration
2, 4
1, 2, 4
1, 2, 3, 4
40 SERIES HARDWARE
P art Number
CS24
CS24T
TC4
NW4
PS40
44
Description
Gold Plated Crimp Terminals
Tin Plated Crimp Terminals
40 Series Mounting Clip
40 Series Mounting Washer
TC5 & NW5 mounting hardware provided
PS44
CSH40
SH40
CS24 & CS24T
22AWG to 28AWG
45
很抱歉,暂时无法提供与“405-GLP2-NGO”相匹配的价格&库存,您可以联系我们找货
