53-NKG120-CWO
53-NKG120-CWO
    VCC
    PMI .312" LED HI-HAT 120V GREEN
53-NKG120-CWO 数据手册
.312" MOUNT PANEL LIGHTS Data Display Products ® 50 Series - Mounting Hardware Provided 1 Model 51 53[1] 54 56 561 564 - For Detailed LED Data, See Discrete Section, MODEL 200 TO ORDER, FOLLOW THE EXAMPLE: Wires Select one BOLD component from each numbered category in the tables below. W (optional) Model 1 LED 2 -ALP 3 54 -BCR -BCA -BCG 2 4 Lens Diffusion -C Voltage/Current λpk Iv[2] Viewing V/C Color (nm) (mcd) Angle Table[3] RED AMB GRN 635 583 565 35 35 24 I I I 120 100 80 Design Max Vf/If Vf/If V/C Table I 5.5V/28mA 5V/22mA 12V/20mA 14V/25mA 15V/24mA 16.5V/28mA 24V/17mA 26V/20mA 28V/16.5mA 30V/18mA 48V/15mA 50V/16mA 60V/9mA 65V/10mA 120VAC/3.5mA 130VAC/4mA HIGH INTENSITY - WATERCLEAR ENCAPSULATION λpk Iv[2] Viewing LED V/C Color (nm) (mcd) Angle Table[3] -NWR -NWO -NWA -NWG -NWB -NWW[7] -NWL[7] -NKR -NKO -NKA -NKG -NKB -NKW[7] -NKL[7] RED ORG AMB GRN BLU CWHT WWHT RED ORG AMB GRN BLU CWHT WWHT 634 605 592 520 465 2800 2000 2800 2400 700 2500 1800 3600 8000 3600 10000 3000 9200 9200 30 30 30 45 45 50 50 15 15 15 15 15 20 15 I I I II II II II I I I II II II II 634 605 592 520 465 3 -RLP[6] -ALP[6] -GLP[6] -LRG[7] -RAG[7] -GAR[7] Bezel Color 6 A 9 4 Voltage/Current Design Max Vf/If Vf/If V/C Table II 5V/15mA 5.5V/23mA 12V/15mA 14V/20mA 15V/15mA 16.5V/18mA 24V/15mA 26V/18mA 28V/15mA 30V/17mA 48V/9.5mA 50V/10mA 60V/7mA 65V/8mA 120VAC/3.5mA 130VAC/4mA λpk Iv[2] Voltage[4] 2 5H 12H 15H 24H 28H 48H 60H 120[5] Lens Diffusion -C Clear -N Diffused 5 SPECIALTY LEDs LED 5 Lens Color ➜Part Number 54-ALP2-CA9 MEDIUM INTENSITY - TINTED ENCAPSULATION 2 LED Voltage Lens Color R Red B Blue A Amber W Water Clear Y Yellow -S Smoke[8] Viewing V/C Description Low Power Low Power Low Power Bi-Color. Red Cathode Tri-Color, Common Cathode Tri-Color, Common Anode Color (nm) (mcd) Angle Table[3] RED AMB GRN RED/GRN RED/AMB/GRN GRN/AMB/RED 635 583 565 660/565 630/565 635/565 2.3 2.1 2.3 90/40 6/6/6 5/5/5 50 50 50 60 60 50 [3] [3] [3] I I I G Green 6 Bezel Color 0 Black 9 White [1] Model 53 is available with Clear (-C) Lens only. [2] Iv = typical luminous intensity @ If = 20mA (Ta =25°C). Iv is measured without lenses. For Low Power LEDs, If = 2mA. [3] See Voltage/Current table for design specifications. Design current for low power LEDs = 2mA. [4] Ta = 25°C. Voltage 2 indicates external resistor required. Voltages 5H through 60H are VDC. For AC operation, insert D after Voltage (e.g. 24HD), D indicates built-in rectifier; not required for 5H or 120VAC. DC operation not available for 120V. Bi-Color and Tri-Color not available in AC voltages. 52 [5] Select high intensity LEDs only. [6] Omit H when selecting a voltage (e.g. 51-RLP12-CWO). [7] Select -CW or -NW lens only. -RAG wire leads: green anode/black cathode/red anode. -GAR wire leads: green cathode/black anode/red cathode. Common lead is the first lead clockwise from reference mark on header. Tri-Color 5 or 12 volt, omit H in part number. [8] Omit Lens Diffusion when selecting smoked lens (e.g. 51-NWA12H-SO). 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products Data Display Products ® .312" MOUNT PANEL LIGHTS 50 Series 51 53 54 (flush lens) 56 561 564 TC5 & NW5 Mounting Hardware Standard Wire Leads: 6.0" total length(nominal)/.50" stripped (nominal), red anode/black cathode, 24 AWG TPB UL1061 insulation. Contact factory for other lengths, gauges and colors. All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products 53
53-NKG120-CWO
1. 物料型号:文档中提到了多种型号,例如51、53、54、56、561、564等,以及特殊型号如-RLP、-ALP、-GLP等。
2. 器件简介:文档描述了不同系列的面板灯,包括中等强度的带色封装和高强度的透明封装。
3. 引脚分配:文档中提到了引脚分配,例如53型号的LED灯具有清晰的镜头,并且提到了引脚的配置,如阳极和阴极的配置。
4. 参数特性:文档列出了不同颜色LED的参数,包括发光强度(mcd)、视场角度、设计电压/电流等。
5. 功能详解:文档提供了不同LED的功能描述,如低功耗LED、双色和三色LED。
6. 应用信息:文档中提到了LED的应用,例如面板指示灯等。
7. 封装信息:文档提供了封装尺寸和引脚配置的详细信息。
53-NKG120-CWO 价格&库存
很抱歉,暂时无法提供与“53-NKG120-CWO”相匹配的价格&库存,您可以联系我们找货
