74S-NWG15H-CG
74S-NWG15H-CG
    VCC
    PMI .312" LED 15V GREEN
74S-NWG15H-CG 数据手册
.312" MOUNT PANEL LIGHT Data Display Products ® 74S Series - Black Anodized Aluminum Body 1 Model 74S - For Detailed LED Data, See Discrete Section, Model 200 TO ORDER, FOLLOW THE EXAMPLE: Wires Select one BOLD component from each numbered category in the tables below. W (optional) Model 1 74S LED Voltage 2 -NWR 3 120 4 Lens Diffusion -C 5 Lens Color R ➜Part Number 74S-NWR120-CR HIGH INTENSITY - WATERCLEAR ENCAPSULATION 2 LED -NWR -NWO -NWA -NWG -NWB -NWW -NWL λpk Iv[1] Viewing V/C Color (nm) (mcd) Angle Table[2] RED ORG AMB GRN BLU CWHT WWHT 634 605 592 520 465 30 30 30 45 45 50 50 I I I II II II II 2800 2000 2800 2400 700 2500 1800 Voltage/Current Design Max Vf/If Vf/If V/C Table I 5V/22mA 5.5V/28mA 12V/20mA 14V/25mA 15V/24mA 16.5V/28mA 24V/17mA 26V/20mA 28V/16.5mA 30V/18mA 48V/15mA 50V/16mA 60V/9mA 65V/10mA 120VAC/3.5mA 130VAC/4mA 3 2 5H 12H 15H 24H 28H 48H 60H 120 4 Voltage/Current Design Max Vf/If Vf/If V/C Table II 5V/15mA 5.5V/23mA 12V/15mA 14V/20mA 15V/15mA 16.5V/18mA 24V/15mA 26V/18mA 28V/15mA 30V/17mA 48V/9.5mA 50V/10mA 60V/7mA 65V/8mA 120VAC/3.5mA 130VAC/4mA Voltage[3] Lens Diffusion -C Clear 5 Lens Color R Red G Green A Amber W Water Clear Y Yellow 74S [1] Iv = typical luminous intensity @ If = 20mA(Ta=25°C). Iv is measured without lenses. [2] See Voltage/Current table for design specifications. Standard Wire Leads: 6.0" total length(nominal)/.50" stripped (nominal), red anode/black cathode, 24 AWG TPB UL1061 insulation. Contact factory for other lengths, gauges and colors. 58 [3] Ta = 25°C. Voltages 5H through 60H are VDC. For AC operation, insert D after Voltage (e.g 24HD), D indicates built-in rectifier; not required for 5H or 120VAC. DC operation not available for 120V. All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products
74S-NWG15H-CG 价格&库存
很抱歉,暂时无法提供与“74S-NWG15H-CG”相匹配的价格&库存,您可以联系我们找货
