94W-NWR120-CRO
94W-NWR120-CRO
    VCC
    LED-2P_D8.5X18.9MM_TM
    PMI .290" 120VAC FLUSH WIRE RED
94W-NWR120-CRO 数据手册
.290" MOUNT PANEL LIGHTS Data Display Products ® 90 Series - Mounting Hardware Provided - For Detailed LED Data, See Discrete Section, MODEL 200 1 Wires Model C[1] (optional) 905[2] 91 94 96 961 964 TO ORDER, FOLLOW THE EXAMPLE: Select one BOLD component from each numbered category in the tables below. W (optional) Model 1 LED 2 -LRG 3 94 -BR[4] -BA[4] -BG[4] -BCR -BCA -BCG 4 Voltage/Current λpk Iv[3] Viewing V/C Color (nm) (mcd) Angle Table[5] RED AMB GRN 635 583 565 60 60 60 I I I 14 16 10 Design Max Vf/If Vf/If V/C Table I 5V/22mA 5.5V/28mA 12V/20mA 14V/25mA 15V/24mA 16.5V/28mA 24V/17mA 26V/20mA 28V/16.5mA 30V/18mA 48V/15mA 50V/16mA 60V/9mA 65V/10mA 120VAC/3.5mA 130VAC/4mA MEDIUM INTENSITY - TINTED ENCAPSULATION LED 12H λpk Iv[3] Viewing V/C Color (nm) (mcd) Angle Table[5] RED AMB GRN 635 583 565 35 35 24 I I I 120 100 80 λpk Iv[3] Viewing LED V/C Color (nm) (mcd) Angle Table[5] -NWR -NWO -NWA -NWG -NWB -NWW[8] -NWL[8] -NKR -NKO -NKA -NKG -NKB -NKW[8] -NKL[8] RED ORG AMB GRN BLU CWHT WWHT RED ORG AMB GRN BLU CWHT WWHT 634 605 592 520 465 2800 2000 2800 2400 700 2500 1800 3600 8000 3600 10000 3000 9200 9200 30 30 30 45 45 50 50 15 15 15 15 15 20 15 I I I II II II II I I I II II II II Design Max Vf/If Vf/If V/C Table II 5V/15mA 5.5V/23mA 12V/15mA 14V/20mA 15V/15mA 16.5V/18mA 24V/15mA 26V/18mA 28V/15mA 30V/17mA 48V/9.5mA 50V/10mA 60V/7mA 65V/8mA 120VAC/3.5mA 130VAC/4mA 634 605 592 520 465 Bezel Color 6 W 0 3 Voltage[6] 2 5H 12H 15H 24H 28H 48H 60H 120[9] 4 Lens Diffusion -C Clear -N Diffused 5 Lens Color R Red B Blue A Amber W Water Clear -S Smoke[10] G Green 6 λpk Iv[3] Viewing V/C Color (nm) (mcd) Angle Table[5] Description RED AMB GRN RED/GRN 635 583 565 660/565 2.3 2.1 2.3 90/40 50 50 50 60 [5] [5] [5] Low Power Low Power Low Power Bi-Color, Red Cathode [1] The C option specifies a pin length = .20" for panel lights mounted in the PS90 or PS90T socket (pg. 48). Mounting hardware is included with the socket. Do not select the W option. C and standard pins are not solderable. [2] Model 905 has no lens. Omit Lens Diffusion and Color (e.g. 905-BG5H-0). [3] Iv = typical luminous intensity @ If = 20mA(Ta =25°C). Iv is measured without lenses. For Low Power LEDs, If = 2mA. [4] Use with Model 905 only. [5] See Voltage/Current table for design specifications. Design current for low power LEDs = 2mA. 46 5 Lens Color Y Yellow SPECIALTY LEDs - DIFFUSED ENCAPSULATION -RLP[7] -ALP[7] -GLP[7] -LRG[8] -C Voltage/Current HIGH INTENSITY - WATERCLEAR ENCAPSULATION LED Lens Diffusion ➜Part Number 94-LRG12H-CW0 STANDARD INTENSITY - DIFFUSED ENCAPSULATION 2 LED Voltage I Bezel Color 0 Black 9 White [6] Ta = 25°C. Voltage "2" indicates external resistor required. Voltages 5H through 60H are VDC. For AC operation, insert D after Voltage (e.g. 24HD). D indicates built-in rectifier; not required for 5H or 120VAC. DC operation not available for 120V. Bi-Color not available in AC voltages. [7] Omit H when selecting a voltage (e.g. 91-RLP12-CWO). [8] Select -CW or -NW Lens only. [9] Select high intensity LEDs only. [10]Omit Lens Diffusion when selecting smoked lens (e.g. 91-NWG24H-S0). 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products Data Display Products ® .290" MOUNT PANEL LIGHTS 90 Series 905 (no lens) 91 94 (flush lens) 96 961 964 TC9 & NW9 Mounting Hardware Standard Wire Leads: 6.0" total length(nominal)/.50" stripped (nominal), red anode/black cathode, 24 AWG TPB UL1061 insulation. Contact factory for other lengths, gauges and colors. All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products 47 .290" MOUNT PANEL LIGHT SOCKETS Data Display Products ® 90 Series Mounting Hardware - Sockets for 90 Series Panel Lights - Mounting Hole Diameter: Ø.375” - Ø.385”. Panel Thickness: Max: 0.80” TO ORDER, FOLLOW THE EXAMPLE: Select one BOLD component from each SHADED column in the tables below. Model 1 L92 Lens Diffusion 2 Lens Color 3 -C R ➜Part Number L92-CR 1 90 SERIES SOCKETS & HARDWARE Model PS90[1] PS90T[1] RC90 SH90 CSH90 TC9 NW9 Description Mating Components 90 Series Socket, Solder Terminals 90 Series Socket, Turret Terminals Retaining Collar Wiring Plug Wiring Plug with collar 90 Series Mounting Clip 90 Series Mounting Washer (neoprene) C905, C91, C94, C96, C961, C964 C905, C91, C94, C96, C961, C964 PS90, PS90T 905, 91, 94, 96, 961, 964, C905, C91, C94, C96, C961, C964 905, 91, 94, 96, 961, 964, C905, C91, C94, C96, C961, C964 905, 91, 94, 96, 961, 964, C905, C91, C94, C96, C961, C964 905, 91, 94, 96, 961, 964, C905, C91, C94, C96, C961, C964 90 SERIES LENS (For use with PS90 or PS90T Socket with Model C905 Panel Light) 1 Model 2 L92 Lens Diffusion -C Clear -N Diffused 3 Lens Color R Red A Amber Y Yellow G Green B Blue W Water Clear -S Smoke[2] [1] Hardware Assembled. [2] Omit Lens Diffusion Code (e.g. L92-S). 48 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products Data Display Products ® .290" MOUNT PANEL LIGHT SOCKETS 90 Series Mounting Hardware PS90 PS90T SH90 CSH90 RC90-B L92 TC9 & NW9 Mounting Hardware All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products 49
94W-NWR120-CRO
1. 物料型号:文档中列出了多种型号的LED灯,例如905、91、94、96、961、964等,以及它们的变体,如带有不同颜色和扩散特性的型号。
2. 器件简介:文档提供了不同LED灯的基本信息,包括它们的颜色、亮度、视场角度等。
3. 引脚分配:文档中提到了引脚长度的选项,例如C选项指定引脚长度为0.20英寸,适用于PS90或PS90T插座。
4. 参数特性:详细列出了LED灯的电气特性,如工作电压、工作电流、正向电压(Vf)、发光强度(Iv)等。
5. 功能详解:文档解释了不同LED灯的功能,包括它们的封装类型、颜色、亮度等级等。
6. 应用信息:虽然文档没有直接提到应用信息,但从型号和参数特性可以推断这些LED灯可能用于指示灯、面板灯等应用。
7. 封装信息:文档提供了LED灯的物理尺寸和引脚信息,以及如何根据需要选择不同的封装选项。
94W-NWR120-CRO 价格&库存
很抱歉,暂时无法提供与“94W-NWR120-CRO”相匹配的价格&库存,您可以联系我们找货
