P205W-NWG28H
P205W-NWG28H
    VCC
    PMI .156" LED 28VDC WIRE GREEN
P205W-NWG28H 数据手册
.156" SNAP-IN PANEL LIGHT Data Display Products ® T-1 - Mounting Diameter .155"(3.94) to .158"(4.01) - For Panels .031"(.79) to .125" (3.18) Thick - For Detailed LED Data, See Discrete Section, MODEL 125 1 Model P205 TO ORDER, FOLLOW THE EXAMPLE: Wires Select one BOLD component from each numbered category in the tables below. W (optional) LED Voltage 1Model 2 3 P205 -BCR 2 ➜Part Number P205-BCR2 STANDARD INTENSITY - DIFFUSED ENCAPSULATION 2 LED Color (nm) -BR -BA -BG RED AMB GRN 635 583 565 λpk Iv[1] Viewing V/C (mcd) Angle Table[3] 60 60 60 I I I 14 14 14 Voltage/Current Design Max Vf/If Vf/If V/C Table I 5V/22mA 5.5V/28mA 12V20mA 14V/25mA 15V/24mA 16.5V/28mA 24V/17mA 26V/20mA 30V/18mA 28V/16.5mA MEDIUM INTENSITY - TINTED ENCAPSULATION LED -BCR -BCA -BCG λpk Iv[1] Viewing V/C Color (nm) (mcd) Angle Table[3] RED AMB GRN 635 583 565 45 45 45 I I I 60 30 44 RED AMB GRN BLU WHT 634 592 520 465 2180 2180 2000 600 1100 35 35 45 45 55 Voltage[4] 2 5H 12H 15H 24H 28H Voltage/Current Design Max Vf/If Vf/If V/C Table II 5V/15mA 5.5V/23mA 12V/15mA 14V/20mA 15V/15mA 16.5V/18mA 24V/15mA 26V/18mA 28V/15mA 30V/17mA HIGH INTENSITY - WATERCLEAR ENCAPSULATION λpk Iv[1] Viewing V/C Color (nm) (mcd) Angle Table[3] LED -NWR -NWA -NWG -NWB -NWW 3 I I II II II SPECIALTY LEDs LED -RLP[2] -ALP[2] -GLP[2] -DRG λpk Iv[1] Viewing V/C Color (nm) (mcd) Angle Table[3] RED AMB GRN RED/GRN 635 583 565 635/567 2.1 1.6 2.1 4.3/3.7 50 50 50 118 I I I I [1] Iv = typical luminous intensity @ If = 20mA (Ta=25°C), Low Power LEDs @ If = 2mA. Bi-color LEDs @ lf=10mA. [2] Omit the H when selecting a voltage. (e.g. P205-RLP12). [3] See Voltage/Current table for design specifications. Design current for low power LEDs = 2mA. 34 Description Low Power Low Power Low Power Bi-Color, Red Cathode [4] Ta = 25°C. Voltage "2" indicates external resistor required. Voltages 5H through 28H are VDC. For AC operation, insert D after Voltage (e.g. 24HD). D indicates built-in rectifier; not required for 5H. Bi-Color not available in AC voltages. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products .156" SNAP-IN PANEL LIGHT Data Display Products ® T-1 P205 Standard Wire Leads: 6.0" total length(nominal)/.50" stripped (nominal), red anode/black cathode, 24 AWG TPB UL1061 insulation. Contact factory for other lengths, gauges and colors. All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products 35
P205W-NWG28H 价格&库存
很抱歉,暂时无法提供与“P205W-NWG28H”相匹配的价格&库存,您可以联系我们找货
