.156" SNAP-IN PANEL LIGHT
Data Display Products
T-1
- Mounting Diameter .155"(3.94) to .158"(4.01) - For Panels .031"(.79) to .125" (3.18) Thick - For Detailed LED Data, See Discrete Section, MODEL 125
1 Model
P205
TO ORDER, FOLLOW THE EXAMPLE:
Wires
Select one BOLD component from each numbered category in the tables below.
W
(optional)
LED
Voltage
1Model
2
3
P205
-BCR
2
➜Part Number P205-BCR2
STANDARD INTENSITY - DIFFUSED ENCAPSULATION
2 LED
Color
(nm)
-BR
-BA
-BG
RED
AMB
GRN
635
583
565
λpk
Iv[1]
Viewing
V/C
(mcd)
Angle
Table[3]
60
60
60
I
I
I
14
14
14
Voltage/Current
Design
Max
Vf/If
Vf/If
V/C Table I
5V/22mA
5.5V/28mA
12V20mA
14V/25mA
15V/24mA
16.5V/28mA
24V/17mA
26V/20mA
30V/18mA
28V/16.5mA
MEDIUM INTENSITY - TINTED ENCAPSULATION
LED
-BCR
-BCA
-BCG
λpk
Iv[1]
Viewing
V/C
Color
(nm)
(mcd)
Angle
Table[3]
RED
AMB
GRN
635
583
565
45
45
45
I
I
I
60
30
44
RED
AMB
GRN
BLU
WHT
634
592
520
465
2180
2180
2000
600
1100
35
35
45
45
55
Voltage[4]
2
5H
12H
15H
24H
28H
Voltage/Current
Design
Max
Vf/If
Vf/If
V/C Table II
5V/15mA
5.5V/23mA
12V/15mA
14V/20mA
15V/15mA
16.5V/18mA
24V/15mA
26V/18mA
28V/15mA
30V/17mA
HIGH INTENSITY - WATERCLEAR ENCAPSULATION
λpk
Iv[1]
Viewing
V/C
Color
(nm)
(mcd)
Angle
Table[3]
LED
-NWR
-NWA
-NWG
-NWB
-NWW
3
I
I
II
II
II
SPECIALTY LEDs
LED
-RLP[2]
-ALP[2]
-GLP[2]
-DRG
λpk
Iv[1]
Viewing
V/C
Color
(nm)
(mcd)
Angle
Table[3]
RED
AMB
GRN
RED/GRN
635
583
565
635/567
2.1
1.6
2.1
4.3/3.7
50
50
50
118
I
I
I
I
[1] Iv = typical luminous intensity @ If = 20mA (Ta=25°C), Low Power LEDs @ If = 2mA.
Bi-color LEDs @ lf=10mA.
[2] Omit the H when selecting a voltage. (e.g. P205-RLP12).
[3] See Voltage/Current table for design specifications. Design current for low power LEDs = 2mA.
34
Description
Low Power
Low Power
Low Power
Bi-Color, Red Cathode
[4] Ta = 25°C. Voltage "2" indicates external resistor required. Voltages 5H through 28H are VDC. For
AC operation, insert D after Voltage (e.g. 24HD). D indicates built-in rectifier; not required for 5H.
Bi-Color not available in AC voltages.
445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639
ww w.datadisplay.com
© 2005 Data Display Products
T-1
P205
Standard Wire Leads:
6.0" total length(nominal)/.50" stripped (nominal), red
anode/black cathode, 24 AWG TPB UL1061 insulation.
Contact factory for other lengths, gauges and colors.
All dimensions are in inches (mm)
Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25)
Specifications are subject to change without notice.
35
很抱歉,暂时无法提供与“P205W-BG2”相匹配的价格&库存,您可以联系我们找货
