P44-BCG2-CG
P44-BCG2-CG
    VCC
    PMI T-1 LED .250" LED 2V FLUSH G
P44-BCG2-CG 数据手册
.250" SNAP-IN PANEL LIGHT Data Display Products ® T-1 Flush Mount Lens - Mounting Diameter .249"(6.32) to .252"(6.40) - For Panels .031"(.79) to .125" (3.18) Thick - For Detailed LED Data, See Discrete Section, MODEL 125 TO ORDER, FOLLOW THE EXAMPLE: Select one BOLD component from each numbered category in the tables below. Model 1 PR44 Wire W LED 2-BCG 3 Voltage 12H Lens Color 4 -CG ➜Part Number PR44W-BCG12H-CG 1 Model P44 PR44 Wires W (optional) Voltage/Current Description Voltage = 2 (External Resistor Required) Voltages 5H - 28H MEDIUM INTENSITY - TINTED ENCAPSULATION 2 LED -BCR -BCA -BCG λpk Iv[1] Viewing V/C Color (nm) (mcd) Angle Table[3] RED AMB GRN 635 583 565 45 45 45 I I I 60 30 44 HIGH INTENSITY - WATERCLEAR ENCAPSULATION LED λpk Iv[1] Color (nm) (mcd) -NWR -NWA -NWG -NWB -NWW[4] RED AMB GRN BLU CWHT 660 592 520 465 2180 2180 2000 600 2070 Viewing V/C Angle Table[3] 35 35 45 45 60 I I II II II Design Max Vf/If Vf/If V/C Table I 5V/22mA 5.5V/28mA 12V/20mA 14V/25mA 15V/24mA 16.5V/28mA 24V/17mA 26V/20mA 28V/16.5mA 30V/18mA Voltage/Current Design Max Vf/If Vf/If V/C Table II 5V/15mA 5.5V/23mA 12V/15mA 14V/20mA 15V/15mA 16.5V/18mA 24V/15mA 26V/18mA 28V/15mA 30V/17mA 3 Voltage[2] 2 5H 12H 15H 24H 28H 4 Lens Color [4] -CR Red -CA Amber -CY Yellow -CG Green -CB Blue -CW Water Clear -S [1] Iv = typical luminous intensity @ If = 20mA (Ta=25°C). [2] Ta=25°C. Voltages 5H - 28H are DC. For AC operation, insert D after voltage. D indicates built-in rectifier, not required for 5H (e.g. 24HD). [3] See voltage/current table for design specifications. Standard Wire Leads: 6.0" total length(nominal)/.50" stripped (nominal), red anode/black cathode, 24 AWG TPB UL1061 insulation. Contact factory for other lengths, gauges and colors. 36 Smoke [4] Colored lenses must match LED colors (e.g. PR44-BCR5H-CR). Water Clear and Smoke lenses may be specified with any LED color. For White, select -CW Lens only. All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products Data Display Products ® .250" SNAP-IN PANEL LIGHT T-1 Flush Mount Lens P44 PR44 Standard Wire Leads: 6.0" total length(nominal)/.50" stripped (nominal), red anode/black cathode, 24 AWG TPB UL1061 insulation. Contact factory for other lengths, gauges and colors. All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products 37
P44-BCG2-CG 价格&库存
很抱歉,暂时无法提供与“P44-BCG2-CG”相匹配的价格&库存,您可以联系我们找货
