P81W-B48H-CB
P81W-B48H-CB
    VCC
    PMI LED 0.500" 48V WIRE BLUE
P81W-B48H-CB 数据手册
1/2" Data Display Products ® SNAP-IN PANEL LIGHT WITH LENS P80 Series - For Detailed LED Data, See Discrete Section, Model 200 1 Model P81 P84 TO ORDER, FOLLOW THE EXAMPLE: Wires Select one BOLD component from each numbered category in the tables below. W (optional) LED Voltage 1Model 2 3 4 P81 -G 24 Lens -CG ➜Part Number P81-G24-CG HIGH INTENSITY - WATERCLEAR ENCAPSULATION 2 LED Color (nm) -R -O -A -G -B -W RED ORG AMB GRN BLU WHT 634 605 592 520 465 λpk Iv[1] Viewing V/C (mcd) Angle Table[3] 30 30 30 45 45 50 I I I II II II [2] 5300 2000 5300 2400 700 1560 P81 Voltage/Current Design Max Vf/If Vf/If V/C Table I 5V/27mA 5.5V/40mA 6V/26mA 7V/33mA 12V/27mA 14V/35mA 15V/24mA 16.5V/28mA 24V/17mA 26V/20mA 28V/16.5mA 30V/18mA 48V/15mA 50V/16mA 60V/9mA 65V/10mA 120VAC/3.5mA 130VAC/4mA 3 Voltage[4] 4 Lens 5H 6H 12H 15H 24H 28H 48H 60H 120 -CR Red -CA Amber -CG Green -CB Blue -CW Water Clear Voltage/Current P84 [1] Iv = typical luminous intensity @ If = 20mA(Ta=25°C). Iv is measured without lenses. [2] White is identified by one of four CIE coordinates x:0.290/y:0.260, x:0.290/y:0.305, x:0.330/y:0:365,x:0.330/y:0.320 Standard Wire Leads: 6.0" total length(nominal)/.50" stripped (nominal), red anode/black cathode, 18 AWG TPB UL1015 insulation. Contact factory for other lengths, gauges and colors. Design Max Vf/If Vf/If V/C Table II 5V/15mA 6V/26mA 6V/15mA 7V/25mA 12V/15mA 14V/20mA 15V/15mA 16.5V/18mA 24V/15mA 26V/18mA 28V/15mA 30V/17mA 48V/9.5mA 50V/10mA 60V/7mA 65V/8mA 120VAC/3.5mA 130VAC/4mA [3] See Voltage/Current table for design specifications. [4] Ta = 25°C. Voltages 5H through 60H are VDC. For AC operation, insert D after Voltage (e.g 24HD), D indicates built-in rectifier; not required for 15H or less, or 120VAC. DC operation not available for 120V. All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2003 Data Display Products 65
P81W-B48H-CB 价格&库存
很抱歉,暂时无法提供与“P81W-B48H-CB”相匹配的价格&库存,您可以联系我们找货
