1/2"
Data Display Products
SNAP-IN PANEL LIGHT WITH LENS
P80 Series
- For Detailed LED Data, See Discrete Section, Model 200
1 Model
P81
P84
TO ORDER, FOLLOW THE EXAMPLE:
Wires
Select one BOLD component from each numbered category in the tables below.
W
(optional)
LED
Voltage
1Model
2
3
4
P81
-G
24
Lens
-CG
➜Part Number P81-G24-CG
HIGH INTENSITY - WATERCLEAR ENCAPSULATION
2 LED
Color
(nm)
-R
-O
-A
-G
-B
-W
RED
ORG
AMB
GRN
BLU
WHT
634
605
592
520
465
λpk
Iv[1]
Viewing
V/C
(mcd)
Angle
Table[3]
30
30
30
45
45
50
I
I
I
II
II
II
[2]
5300
2000
5300
2400
700
1560
P81
Voltage/Current
Design
Max
Vf/If
Vf/If
V/C Table I
5V/27mA
5.5V/40mA
6V/26mA
7V/33mA
12V/27mA
14V/35mA
15V/24mA
16.5V/28mA
24V/17mA
26V/20mA
28V/16.5mA
30V/18mA
48V/15mA
50V/16mA
60V/9mA
65V/10mA
120VAC/3.5mA 130VAC/4mA
3
Voltage[4]
4
Lens
5H
6H
12H
15H
24H
28H
48H
60H
120
-CR
Red
-CA
Amber
-CG
Green
-CB
Blue
-CW
Water
Clear
Voltage/Current
P84
[1] Iv = typical luminous intensity @ If = 20mA(Ta=25°C). Iv is measured without lenses.
[2] White is identified by one of four CIE coordinates x:0.290/y:0.260, x:0.290/y:0.305,
x:0.330/y:0:365,x:0.330/y:0.320
Standard Wire Leads:
6.0" total length(nominal)/.50" stripped (nominal), red
anode/black cathode, 18 AWG TPB UL1015 insulation.
Contact factory for other lengths, gauges and colors.
Design
Max
Vf/If
Vf/If
V/C Table II
5V/15mA
6V/26mA
6V/15mA
7V/25mA
12V/15mA
14V/20mA
15V/15mA
16.5V/18mA
24V/15mA
26V/18mA
28V/15mA
30V/17mA
48V/9.5mA
50V/10mA
60V/7mA
65V/8mA
120VAC/3.5mA
130VAC/4mA
[3] See Voltage/Current table for design specifications.
[4] Ta = 25°C. Voltages 5H through 60H are VDC. For AC operation, insert D after Voltage (e.g 24HD),
D indicates built-in rectifier; not required for 15H or less, or 120VAC. DC operation not available
for 120V.
All dimensions are in inches (mm)
Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25)
Specifications are subject to change without notice.
445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639
ww w.datadisplay.com
© 2003 Data Display Products
65
很抱歉,暂时无法提供与“P81-G28H-CG”相匹配的价格&库存,您可以联系我们找货
