PCT125-DRG-DRG
PCT125-DRG-DRG
    VCC
    DUAL STCKD T1 GREEN RED
PCT125-DRG-DRG 数据手册
T-1 PCB MOUNT LEDs Data Display Products ® Dual-Stacked - For Detailed LED Data, See Discrete Section, MODEL 125 1 TO ORDER, FOLLOW THE EXAMPLE: Model PCT125 Select one BOLD component from each SHADED column in the tables below. Right Angle Mount Model Top Bottom LED LED 1PCT125 2 -BCR /BCG ➜Part Number PCT125-BCR/BCG STANDARD INTENSITY - DIFFUSED ENCAPSULATION 2 LED Top -BR -BA -BG λpk Iv[1] Viewing LED Color (nm) (mcd) Angle /BR /BA /BG RED AMB GRN 635 583 565 Bottom 14 14 14 60 60 60 MEDIUM INTENSITY - TINTED ENCAPSULATION Top Bottom LED λpk Iv[1] Viewing LED Color (nm) (mcd) Angle -BCR -BCA -BCG /BCR /BCA /BCG RED AMB GRN 635 583 565 Top Bottom LED LED -RLP -ALP -GLP -DRG -BR5V -BA5V -BG5V -BR12V -BA12V -BG12V /RLP /ALP /GLP /DRG /BR5V /BA5V /BG5V /BR12V /BA12V /BG12V 60 30 44 45 45 45 SPECIALTY LEDs λpk Iv[1] Viewing Color (nm) (mcd) Angle Description RED AMB GRN RED/GRN RED AMB GRN RED AMB GRN 635 583 565 635/567 635 583 565 635 583 565 2.1 1.6 2.1 4.3/3.7 8 8 8 8 8 8 50 50 50 118 60 60 60 60 60 60 Low Power Low Power Low Power Bi-Color, Red Cathode on right, longer lead Integrated Resistor for 5VDC Integrated Resistor for 5VDC Integrated Resistor for 5VDC Integrated Resistor for 12VDC Integrated Resistor for 12VDC Integrated Resistor for 12VDC [1] Iv = typical luminous intensity @ If = 20mA (Ta=25°C), Low Power LEDs @ If = 2mA, Integrated Resistor LEDs @ Vf = 5VDC, or @ Vf = 12VDC. Bi-color LEDs @ lf=10mA. 18 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products Data Display Products T-1 PCB MOUNT LEDs ® Dual-Stacked PCT125 All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products 19
PCT125-DRG-DRG 价格&库存
很抱歉,暂时无法提供与“PCT125-DRG-DRG”相匹配的价格&库存,您可以联系我们找货
