PML50 Series
0.688” (17.5mm) Harsh Environment
LED FlexVolt™ Panel Mount Indicator
PML50 Series with built-in LED FlexVolt™ technology
Application
• Industrial
• Transportation
• High Humidity, Sunlight
and/or rain-expose conditions
• Maritime, Oil and Gas Industry
• Automation and Control
• High Vibration
• Safety and Emergency
• Pilot Instrumentation
• Outdoor Applications
Key Features
For panel hole diameter: 0.688” (17.5mm)
Low profile flat and semi dome lens options for uniform illumination
Flat lens with a clear diffused lens for increased contrast visibility between on and off
Semi dome lens with a white diffused lens for optimal side distance viewing
Increase productivity w/color coded wiring
Single colors options: Red, Green, White, Blue and Yellow
Bi-color options: Red/Green, Red/Blue, Yellow/Green, Yellow/Blue and Red//Yellow
Offered with two lens options: Low Profile Flat and Semi Dome
Resistant to shock and vibration
Flex voltage (5 VDC to 28 VDC) designed for application flexibility: one solution for several required input voltages
Wide viewing angle
Mounting hardware provided: lock washer and hex nut
“Double D” mounting hole prevents any rotation of the indicator while the nut is being installed
IP67 specification rating protects front panels against entry of dust, rain and moisture
InGaN and AllnGaP Technology
Visible LED in direct sunlight with UV resistance lens
Long lifetime, up to 100k hours
Does not require an external resistor to work
For custom cable length, connectors or colors contact VCC
RoHS and REACH Compliant
vcclite.com | 1.800.522.5546
PML50 | 11/22 Rev 6 | Page 1 of 6
Ordering Data
PML50
PML50 - Semi Dome
Example:
PML50RFVW
Example:
PML50SWFVW
PML50 Series, Red Color,
5 VDC to 28 VDC
PML50 Series, White Color, 5 VDC to
28 VDC, Semi Dome Lens
Part Number
Color
Lens
Terminal
Voltage
Luminance (mcd)
PML50RFVW
Red
Flat
24 AWG 5.5” color-coded wire leads
5 VDC to 28 VDC
950
PML50WFVW
White
Flat
5 VDC to 28 VDC
2980
PML50GFVW
Green
Flat
5 VDC to 28 VDC
3640
PML50BFVW
Blue
Flat
5 VDC to 28 VDC
270
PML50YFVW
Yellow
Flat
5 VDC to 28 VDC
2020
PML50SRFVW
Red
Semi Dome
5 VDC to 28 VDC
780
PML50SWFVW
White
Semi Dome
5 VDC to 28 VDC
1090
PML50SGFVW
Green
Semi Dome
5 VDC to 28 VDC
1770
PML50SBFVW
Blue
Semi Dome
5 VDC to 28 VDC
200
PML50SYFVW
Yellow
Semi Dome
5 VDC to 28 VDC
970
PML50 - Bi-Color
Example:
PML50YGFVW
PML50 Series, Yellow/Green Bi-Color,
5 VDC to 28 VDC
Part Number
Color
Lens
Terminal
Voltage
Luminance (mcd)
PML50RGFVW
Red/Green
Flat
5 VDC to 28 VDC
1130/2380
PML50RBFVW
Red/Blue
Flat
5 VDC to 28 VDC
870/2373
PML50YGFVW
Yellow/Green
Flat
5 VDC to 28 VDC
1087/762
PML50YBFVW
Yellow/Blue
Flat
5 VDC to 28 VDC
762/2373
PML50RYFVW
Red/Yellow
Flat
5 VDC to 28 VDC
870/394
PML50SRGFVW
Red/Green
Semi Dome
5 VDC to 28 VDC
520/1370
Notes: Test Parameters: Voltage at 24VDC and Temperature at 25℃ or 77℉
PML50 | 11/22 Rev 6 | Page 2 of 6
Product Dimensions
Semi Dome Lens
Flat Lens
Recommended Mounting Hole
D Mounting Hole
Notes:
1. All dimensions are in inches [millimeters]
2. Tolerance is ±[0.25] 0.01 unless otherwise noted.
3. The specifications, characteristics and technical data described in the datasheet are subject to change without prior notice.
PML50 | 11/22 Rev 6 | Page 3 of 6
Product Dimensions
Semi Dome Lens
21. 4
.8 4
17. 2
.6 7
12.5 MA X
.49 MA X
29.5±3
1.16±.12
11/16" - 27NS
16
.6 3
+25.4
14 0 -0 .0
+1. 0
5. 5 - 0.0
(+) RE D
(-) BLAC K
RE D
GREEN
BLACK (- )
16.8
.6 6
8. 1
.3 2
12. 7
.5 0
BI-COLOR
(3-LEAD WIRE)
Notes:
PML50 | 11/22 Rev 6 | Page 4 of 6
Product Dimensions
Flat Lens
19.8 ±0.4
.78± .015
29.8
1.17
17.8
.7 0
6. 3
.248 MA X
9. 3
.3 7
11/16" - 27NS
16
.6 3
(+) RE D
(-) BLAC K
red or yellow
+25.4
140 -. 0
+1. 0
5. 5 - .0
12.7
.5 0
green or blue
BLACK (- )
BI-COLOR
(3-LEAD WIRE)
8. 1
.3 2
16.8
.6 6
Mounting Hardware (Included for flat and semi dome lenses)
19.8
.7 8
1
.0 4
24.5
.9 6
Washer: EPDM
Lock Washer: SPCC Nickel Plated
20.5
.8 1
2. 4
.0 9
Hex Nut: Brass Nickel Plated
Notes:
PML50 | 11/22 Rev 6 | Page 5 of 6
Product Specifications
Compliances and Approvals
PML50 | 11/22 Rev 6 | Page 6 of 6
很抱歉,暂时无法提供与“PML50SGFVW”相匹配的价格&库存,您可以联系我们找货
