PS200W-B-5H
PS200W-B-5H
    VCC
    PCL .250" LED SOCKET 5VDC WIRE B
PS200W-B-5H 数据手册
.250" PANEL MOUNT LED SOCKET Data Display Products ® Built-In Resistor Optional - For Use with Discrete LEDs, Models 200 & PC3 1 Model Select one BOLD component from each numbered category in the tables below. W (optional) 2 - RC200. KN40, LW40, HN40 Mounting Hardware Included TO ORDER, FOLLOW THE EXAMPLE: Wires PS200 - Mounting Diameter .250" (6.35) 1 PS200 Model Bezel Finish Wires W 2 Bezel Finish -B 3Voltage -12H ➜Part Number PS200W-B-12H -B Black -S Silver 3 Voltage -5H -12H -15H -24H -28H -48H [1] Voltage/Current PS200 With Resistor PC3 LED not Included Design Max Vf/If[2] Vf/If[2] V/C Table I 5V/27mA 5.5V/40mA 12V/27mA 14V/35mA 15V/24mA 16.5V/28mA 24V/17mA 26V/20mA 28V/16.5mA 30V/18mA 48V/15mA 50V/16mA PS200 Without Resistor Discrete LED not Included [1] Ta=25°C. Voltages 5H through 48H are VDC. For AC operation, insert D after Voltage (e.g. 24HD). D indicates built-in rectifier; not required for 15VAC or less. For a socket without a built-in resistor, omit Voltage (e.g. PS200-B). [2] Design current will vary depending on LED used. Standard Wire Leads: 6.0" total length(nominal)/.50" stripped (nominal), red anode/black cathode, 24 AWG TPB UL1061 insulation. Contact factory for other lengths, gauges and colors. All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2003 Data Display Products 39
PS200W-B-5H 价格&库存
很抱歉,暂时无法提供与“PS200W-B-5H”相匹配的价格&库存,您可以联系我们找货
