PR405-BCG5H
PR405-BCG5H
    VCC
    PMI 1-6-15 GREEN
PR405-BCG5H 数据手册
.250" SNAP-IN PANEL LIGHT Data Display Products ® T-13/4 Standard Profile - Mounting Diameter .249"(6.32) to .252"(6.40) - For Panels .031"(.79) to .125" (3.18) Thick - For Detailed LED Data, See Discrete Section, MODEL 200 TO ORDER, FOLLOW THE EXAMPLE: Select one BOLD component from each numbered category in the tables below. LED Voltage 1Model 2 3 PR405 -BR 12H ➜Part Number PR405-BR12H: 1 Model P405 PR405 Wires W (optional) Voltage/Current Description Design Max Vf/If Vf/If V/C Table I 5V/27mA 5.5V/40mA 12V/27mA 14V/35mA 15V/24mA 16.5V/28mA 24V/17mA 26V/20mA 28V/16.5mA 30V/18mA 48V/15mA 50V/16mA 60V/9mA 65V/10mA 120VAC/3.5mA 130VAC/4mA Voltage = 2 (External Resistor Required) Voltages 5H - 120 STANDARD INTENSITY - DIFFUSED ENCAPSULATION 2 LED λpk Iv[1] Viewing V/C Color (nm) (mcd) Angle Table[3] -BR -BA -BG RED AMB GRN 635 583 565 60 60 60 I I I 14 16 10 MEDIUM INTENSITY - TINTED ENCAPSULATION LED -BCR -BCA -BCG Iv[1] Viewing V/C Color (nm) (mcd) Angle Table[3] -NWR -NWO -NWA -NWG -NWB -NWW -NKR -NKO -NKA -NKG -NKB -NKW RED AMB GRN 635 583 565 35 35 24 I I I λpk Iv[1] Viewing V/C Color (nm) (mcd) Angle Table[3] RED ORG AMB GRN BLU WHT RED ORG AMB GRN BLU WHT 634 605 592 520 465 5300 2000 5300 2400 700 1560 6900 8000 6900 10000 3000 5600 30 30 30 45 45 50 15 15 15 15 15 20 I I I II II II I I I II II II [2] 634 605 592 520 465 [2] 2 5H 12H 15H 24H 28H 48H 60H 120[5] Design Max Vf/If Vf/If V/C Table II 5V/15mA 6V/36mA 12V/15mA 14V/20mA 15V/15mA 16.5V/18mA 24V/15mA 26V/18mA 28V/15mA 30V/17mA 48V/9.5mA 50V/10mA 60V/7mA 65V/8mA 120VAC/3.5mA 130VAC/4mA HIGH INTENSITY - WATERCLEAR ENCAPSULATION LED Voltage[4] Voltage/Current λpk 120 100 80 3 SPECIALTY LEDs - DIFFUSED ENCAPSULATION LED -RLP[6] -ALP[6] -GLP[6] -LRG λpk Iv[1] Viewing V/C Color (nm) (mcd) Angle Table[3] Description RED AMB GRN RED/GRN 635 583 565 660/565 2.3 2.1 2.3 90/40 50 50 50 60 [3] [3] [3] Low Power Low Power Low Power Bi-Color, Red Cathode [1] Iv = typical luminous intensity @ If = 20mA (Ta=25°C), Low Power LEDs @ If = 2mA. [2] White is identified by one of four CIE coordinates x:0.290/y:0.260, x:0.290/y:0.305, x:0.330/y:0:365,x:0.330/y:0.320 [3] See Voltage/Current table for design specifications. Design current for low power LEDs = 2mA. 44 I [4] Ta = 25°C. Voltages 5H through 60H and VDC. For AC operation, insert D after Voltage (e.g. 24HD). D indicates built-in rectifier, not required for 15VAC or less or 120VAC. DC operation not available for 120V. Bi-Color not available in AC voltages. [5] Select high intensity LEDs only. [6] Omit the H when selecting voltage (e.g. PR405-RLP12). 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2003 Data Display Products Data Display Products ® .250" SNAP-IN PANEL LIGHT T-13/4 Standard Profile P405 Standard Wire Leads: 6.0" total length(nominal)/.50" stripped (nominal), red anode/black cathode, 24 AWG TPB UL1061 insulation. Contact factory for other lengths, gauges and colors. PR405 All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2003 Data Display Products 45
PR405-BCG5H 价格&库存
很抱歉,暂时无法提供与“PR405-BCG5H”相匹配的价格&库存,您可以联系我们找货
