BP202-BCR28H
BP202-BCR28H
    VCC
    LED LAMP T-1 3/4 BI-PIN 28V SUB
BP202-BCR28H 数据手册
T-13/4 SUB-MINIATURE LAMP Data Display Products ® Single-Chip – For Detailed LED Data, See Discrete Section, MODEL 200 1 TO ORDER, FOLLOW THE EXAMPLE: Model[1] BP202[5] MB200 MF200 [6] MG200 MS200 WB201 Select one BOLD component from each SHADED column in the tables below. Bi-Pin Bayonet Flange Groove Screw Wedge LED 1Model 2 -BCG 3Voltage WB201 12H ➜Part Number WB201-BCG12H MEDIUM INTENSITY - TINTED ENCAPSULATION 2 LED -BCR -BCA -BCG Voltage/Current λpk Iv[2] Viewing V/C Color (nm) (mcd) Angle Table[3] RED AMB GRN 635 583 565 35 35 24 I I I 120 100 80 Design Max Vf/If Vf/If V/C Table I 5V/22mA 5.5V/28mA 7V/27mA 6V/21mA 12V/20mA 14V/25mA 15V/24mA 16.5V/28mA 26V/20mA 24V/17mA 28V/16.5mA 30V/18mA HIGH INTENSITY- WATERCLEAR ENCAPSULATION LED -NWR -NWO -NWA -NWG -NWB -NWW -NWL -NKR -NKO -NKA -NKG -NKB -NKW -NKL λpk Iv[2] Viewing V/C Color (nm) (mcd) Angle Table[3] RED ORG AMB GRN BLU CWHT WWHT RED ORG AMB GRN BLU CWHT WWHT 634 605 592 520 465 2800 2000 2800 2400 700 2500 1800 3600 8000 3600 10000 3000 9200 9200 30 30 30 45 45 50 50 15 15 15 15 15 20 15 I I I II II II II I I I II II II II 634 605 592 520 465 3 Voltage[4] 2 5H 6H 12H 15H 24H 28H Voltage/Current Design Max Vf/If Vf/If V/C Table II 5V/15mA 5.5V/23mA 6V/15mA 7V/25mA 12V/15mA 14V/20mA 15V/15mA 16.5V/18mA 24V/15mA 26V/18mA 28V/15mA 30V/17mA WIDE ANGLE/FLAT-TOPPED-WATERCLEAR ENCAPSULATION LED -NFR -NFA -NFG -NFB -NFW λpk Iv[2] Viewing V/C Color (nm) (mcd) Angle Table[3] RED AMB GRN BLU WHT 634 592 520 465 75 75 75 75 75 I I II II II 780 600 780 168 280 SPECIALTY LEDs LED -RLP[7] -ALP[7] -GLP[7] -LRG Color RED AMB GRN RED/GRN λpk Iv[2] Viewing V/C (nm) (mcd) Angle Table[3] Description 50 50 50 60 [3] [3] [3] Low Power Low Power Low Power Bi-Color, Red Cathode 635 583 565 660/565 2.3 2.1 2.3 90/40 [1] All Models are center anode (note cathode notch for BP202, BP203 and WB201). Insert C after Model for center cathode (e.g. MF200C). [2] Iv = typical luminous intensity @ If = 20mA (Ta=25°C). Low Power LEDs = 2mA. [3] See Voltage/Current table for design specifications. Design current for low power LEDs = 2mA. [4] Ta = 25°C. Voltage 2 indicates external resistor required. Voltages 5H through 28H are VDC. For AC operation, insert D after Voltage (e.g. 24HD). D indicates built-in rectifier: not required for 5H. I [5] Optional Socket available. See Model BPS-1 (pg. 72). [6] Optional Socket available. See Model MFS1-B (pg. 74). [7] Omit "H" Voltage designation (e.g. MG200-RLP12). Continued… 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products 65 T-13/4 SUB-MINIATURE LAMP Data Display Products ® Single-Chip - For Detailed LED Data, See Discrete Section, MODEL 200 BP202 MB200 BPS-1 (Socket for BP202 Lamp) .035(0.9)typ .125(3.2) .220(5.6) .115 (2.9) .250(6.4) MF200 MG200 MS200 WB201 All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 66 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products Data Display Products ® T-13/4 SUB-MINIATURE LAMP Single-Chip Wide Angle LED Lamps BP202, NFX Series (75°) MB200, NFX Series (75°) MF200, NFX Series (75°) MG200, NFX Series (75°) MS200, NFX Series (75°) WB201, NFX Series (75°) All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products 67
BP202-BCR28H
1. 物料型号:文档列出了多种型号的LED灯,例如BP202、MB200、MF200、MG200、MS200和WB201,每种型号都有不同的封装类型,如Bayonet、Groove、Screw和Wedge。
2. 器件简介:文档提供了LED灯的基本信息,包括它们的封装类型和订购方式。
3. 引脚分配:文档中提到了所有型号的LED灯都是中心阳极设计,除了BP202、BP203和WB201型号,它们有阴极凹槽。如果需要中心阴极,可以在型号后添加"C"。
4. 参数特性:文档详细列出了不同颜色LED的发光强度(单位为mcd)、波长(单位为nm)、视场角度和工作电压/电流。
5. 功能详解:文档提供了LED灯的电压/电流设计规格和最大规格,以及对于低功耗LED的特殊说明。
6. 应用信息:虽然文档没有直接提供应用信息,但从LED的参数特性可以推断它们可能用于指示灯、信号灯或其他需要小型光源的应用。
7. 封装信息:文档提供了不同型号LED的尺寸和公差信息。
BP202-BCR28H 价格&库存
很抱歉,暂时无法提供与“BP202-BCR28H”相匹配的价格&库存,您可以联系我们找货
