T-13/4 SUB-MINIATURE LAMP
Data Display Products
Single-Chip
– For Detailed LED Data, See Discrete Section, MODEL 200
1
TO ORDER, FOLLOW THE EXAMPLE:
Model[1]
BP202[5]
MB200
MF200 [6]
MG200
MS200
WB201
Select one BOLD component from each SHADED column in the tables below.
Bi-Pin
Bayonet
Flange
Groove
Screw
Wedge
LED
1Model
2 -BCG
3Voltage
WB201
12H
➜Part Number WB201-BCG12H
MEDIUM INTENSITY - TINTED ENCAPSULATION
2 LED
-BCR
-BCA
-BCG
Voltage/Current
λpk
Iv[2]
Viewing
V/C
Color
(nm)
(mcd)
Angle
Table[3]
RED
AMB
GRN
635
583
565
35
35
24
I
I
I
120
100
80
Design
Max
Vf/If
Vf/If
V/C Table I
5V/22mA
5.5V/28mA
7V/27mA
6V/21mA
12V/20mA
14V/25mA
15V/24mA
16.5V/28mA
26V/20mA
24V/17mA
28V/16.5mA
30V/18mA
HIGH INTENSITY- WATERCLEAR ENCAPSULATION
LED
-NWR
-NWO
-NWA
-NWG
-NWB
-NWW
-NWL
-NKR
-NKO
-NKA
-NKG
-NKB
-NKW
-NKL
λpk
Iv[2]
Viewing
V/C
Color
(nm)
(mcd)
Angle
Table[3]
RED
ORG
AMB
GRN
BLU
CWHT
WWHT
RED
ORG
AMB
GRN
BLU
CWHT
WWHT
634
605
592
520
465
2800
2000
2800
2400
700
2500
1800
3600
8000
3600
10000
3000
9200
9200
30
30
30
45
45
50
50
15
15
15
15
15
I
I
I
II
II
II
II
I
I
I
II
II
II
II
634
605
592
520
465
3
Voltage[4]
2
5H
6H
12H
15H
24H
28H
Voltage/Current
Design
Max
Vf/If
Vf/If
V/C Table II
5V/15mA
5.5V/23mA
6V/15mA
7V/25mA
12V/15mA
14V/20mA
15V/15mA
16.5V/18mA
24V/15mA
26V/18mA
28V/15mA
30V/17mA
WIDE ANGLE/FLAT-TOPPED-WATERCLEAR ENCAPSULATION
LED
-NFR
-NFA
-NFG
-NFB
-NFW
λpk
Iv[2]
Viewing
V/C
Color
(nm)
(mcd)
Angle
Table[3]
RED
AMB
GRN
BLU
WHT
634
592
520
465
75
75
75
75
75
I
I
II
II
II
780
600
780
168
280
SPECIALTY LEDs
LED
-RLP[7]
-ALP[7]
-GLP[7]
-LRG
Color
RED
AMB
GRN
RED/GRN
λpk
Iv[2]
Viewing
V/C
(nm)
(mcd)
Angle
Table[3]
Description
50
50
50
60
[3]
[3]
[3]
Low Power
Low Power
Low Power
Bi-Color, Red Cathode
635
583
565
660/565
2.3
2.1
2.3
90/40
[1] All Models are center anode (note cathode notch for BP202, BP203 and WB201). Insert C after
Model for center cathode (e.g. MF200C).
[2] Iv = typical luminous intensity @ If = 20mA (Ta=25°C). Low Power LEDs = 2mA.
[3] See Voltage/Current table for design specifications. Design current for low power LEDs = 2mA.
[4] Ta = 25°C. Voltage 2 indicates external resistor required. Voltages 5H through 28H are VDC.
For AC operation, insert D after Voltage (e.g. 24HD). D indicates built-in rectifier: not required for
5H.
I
[5] Optional Socket available. See Model BPS-1 (pg. 72).
[6] Optional Socket available. See Model MFS1-B (pg. 74).
[7] Omit "H" Voltage designation (e.g. MG200-RLP12).
Continued…
445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639
ww w.datadisplay.com
© 2005 Data Display Products
65
Single-Chip
- For Detailed LED Data, See Discrete Section, MODEL 200
BP202
MB200
BPS-1 (Socket for BP202 Lamp)
.035(0.9)typ
.125(3.2)
.220(5.6)
.115
(2.9)
.250(6.4)
MF200
MG200
MS200
WB201
All dimensions are in inches (mm)
Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25)
Specifications are subject to change without notice.
66
Single-Chip
Wide Angle LED Lamps
BP202, NFX Series (75°)
MB200, NFX Series (75°)
MF200, NFX Series (75°)
MG200, NFX Series (75°)
MS200, NFX Series (75°)
WB201, NFX Series (75°)
67
很抱歉,暂时无法提供与“BP202-NWO12H”相匹配的价格&库存,您可以联系我们找货
