MF61-CB
MF61-CB
    VCC
    LED LAMP 8-8-2012
MF61-CB 数据手册
T-13/4 SUB-MINIATURE LAMP Data Display Products ® Socket and Fresnel Lens - Flange Base Socket for Model MF200 TO ORDER, FOLLOW THE EXAMPLE: Select one BOLD component from each SHADED column in the tables below. 1Socket MFS1-B 1 Model 2 MF61 Lens Diffusion Lens Color 3 -C R ➜Part Number MFS1-B (Socket) MF61-CR (Model MF61, Clear Red Lens) 1 Part # MFS1-B[1] SOCKET Description For Use With Model MF200 and MF61 lens 1 Lens (For Use With MFS1-B Socket) Lens Diffusion MODEL MF61 -C Clear -N Diffused MFS1-B R Red A Amber Y Yellow G Green B Blue W Water Clear -S[2] Smoke MF61 [1] For Mounting Diameter .470" +/- .005"; Panel Thickness 1/16" to 5/16". [2] Do not select a Diffusion Code (e.g. MF61-S). 68 Lens Color All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products
MF61-CB 价格&库存
很抱歉,暂时无法提供与“MF61-CB”相匹配的价格&库存,您可以联系我们找货
