PMRL200-BCG28H
PMRL200-BCG28H
    VCC
    PMI 10-23-2015 GREEN
PMRL200-BCG28H 数据手册
.312" PANEL MOUNT REFLECTOR Data Display Products ® T-13/4, Water-Tight Optional - Reflective Chrome-Plated Body - Mounting Hardware Provided - For Detailed LED Data, See Discrete Section, MODEL 200 1 Model PMRL200 - Maximum Panel Thickness .160"(PMRL200); .100"(PMRL200, Water-Tight) TO ORDER, FOLLOW THE EXAMPLE: Wires Select one BOLD component from each numbered category in the tables below. W (optional) Model 1PMRL200 Wire W LED 2-BCA Voltage 3 12H Water Tight 4 ➜Part Number PMRL200W-BCA12H STANDARD INTENSITY - DIFFUSED ENCAPSULATION 2 LED Color (nm) -BR -BA -BG RED AMB GRN 635 583 565 Voltage/Current λpk Iv[1] Viewing V/C (mcd) Angle Table[2] 60 60 60 I I I 14 16 10 Design Max Vf/If Vf/If V/C Table I 5V/22mA 5.5V/28mA 12V/20mA 14V/25mA 15V/24mA 16.5V/28mA 24V/17mA 26V/20mA 28V/16.5mA 30V/18mA 48V/15mA 50V/16mA 60V/9mA 65V/10mA 120VAC/3.5mA 130VAC/4mA MEDIUM INTENSITY - TINTED ENCAPSULATION LED -BCR -BCA -BCG λpk Iv[1] Viewing V/C Color (nm) (mcd) Angle Table[2] RED AMB GRN 635 583 565 35 35 24 I I I 120 100 80 Voltage/Current Design Max Vf/If Vf/If V/C Table II 5V/15mA 5.5V/23mA 12V/15mA 14V/20mA 15V/15mA 16.5V/18mA 24V/15mA 26V/18mA 28V/15mA 30V/17mA 48V/9.5mA 50V/10mA 60V/7mA 65V/8mA 120VAC/3.5mA 130VAC/4mA HIGH INTENSITY - WATERCLEAR ENCAPSULATION LED -NWR -NWO -NWA -NWG -NWB -NWW -NWL -NKR -NKO -NKA -NKG -NKB -NKW -NKL λpk Iv[1] Viewing V/C Color (nm) (mcd) Angle Table[2] RED ORG AMB GRN BLU CWHT WWHT RED ORG AMB GRN BLU CWHT WWHT 634 605 592 520 465 2800 2000 2800 2400 700 2500 1800 3600 8000 3600 10000 3000 9200 9200 30 30 30 45 45 50 50 15 15 15 15 15 20 15 I I I II II II II I I I II II II II 634 605 592 520 465 3 Voltage[3] 2 5H 12H 15H 24H 28H 48H 60H 120[4] 4 Water Tight[5] -WT (optional) SPECIALTY LEDs - DIFFUSED ENCAPSULATION LED -RLP[6] -ALP[6] -GLP[6] -LRG -RAG[7] -GAR[7] λpk Iv[1] Viewing V/C Color (nm) (mcd) Angle Table[3] Description RED AMB GRN RED/GRN RED/AMB/GRN GRN/AMB/RED 635 583 565 660/565 630/565 635/565 2.3 2.1 2.3 90/40 6/6/6 5/5/5 50 50 50 60 60 50 [3] [3] [3] Low Power Low Power Low Power Bi-Color, Green Cathode Tri-Color, Common Cathode Tri-Color, Common Anode [1] Iv = typical luminous intensity @ If = 20mA(Ta =25°C). For Low Power LEDs, If = 2mA. [2] See Voltage/Current table for design specifications. Design current for low power LEDs = 2mA. [3] Ta = 25°C. Voltage "2" indicates external resistor requird. Voltages 5H through 60H are VDC. For AC operation, insert D after Voltage (e.g. 24HD). D indicates built-in rectifier, not required for 5H or 120VAC. DC operation not available for 120V. Bi-Color and Tri-Color not available in AC voltages. [4] Select high intensity LEDs only 56 I I I [5] Drip-proof (not submersible), supplied with two neoprene gaskets. [6] Omit H when selecting a voltage (e.g. PMR200-RLP12). [7] -RAG Wire Leads: green anode/black cathode/red anode. -GAR Wire Leads: green cathode/black anode/red cathode. Tri-Color 5 or 12 volt, omit H from part number. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products .312" PANEL MOUNT REFLECTOR Data Display Products ® T-13/4, Water-Tight Optional PMRL200 Standard Wire Leads: 6.0" total length(nominal)/.50" stripped (nominal), red anode/black cathode, 24 AWG TPB UL1061 insulation. Contact factory for other lengths, gauges and colors. All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products 57
PMRL200-BCG28H 价格&库存
很抱歉,暂时无法提供与“PMRL200-BCG28H”相匹配的价格&库存,您可以联系我们找货
