PCV125-200-BCA
PCV125-200-BCA
    VCC
    CBI LED T-1 3/4 5MM RIGHT ANGLE
PCV125-200-BCA 数据手册
T-1 PCB MOUNT LEDs Data Display Products ® Single - For Detailed LED Data, See Discrete Section, MODEL 125 1 TO ORDER, FOLLOW THE EXAMPLE: Model PCH125 PCH125-200 PCV125 PCV125-200 Select one BOLD component from each SHADED column in the tables below. Right Angle Mount Right Angle Mount Vertical Mount Vertical Mount Model LED 1PCH125 2 -BCA ➜Part Number PCH125-BCA 2 LED -BR -BA -BG STANDARD INTENSITY DIFFUSED ENCAPSULATION λpk Iv[1] Viewing Color (nm) (mcd) Angle RED AMB GRN 635 583 565 14 14 14 60 60 60 MEDIUM INTENSITY TINTED ENCAPSULATION LED -BCR -BCA -BCG λpk Iv[1] Viewing Color (nm) (mcd) Angle RED AMB GRN 635 583 565 60 30 44 45 45 45 SPECIALTY LEDs λpk Iv[1] Viewing LED Color (nm) (mcd) Angle Description -RLP -ALP -GLP -DRG -BR5V -BA5V -BG5V -BR12V -BA12V -BG12V RED AMB GRN RED/GRN RED AMB GRN RED AMB GRN 635 583 565 635/567 635 583 565 635 583 565 2.1 1.6 2.1 4.3/3.7 8 8 8 8 8 8 50 50 50 118 60 60 60 60 60 60 Low Power Low Power Low Power Bi-Color, Cathode on right, longer lead Integrated Resistor for 5VDC Integrated Resistor for 5VDC Integrated Resistor for 5VDC Integrated Resistor for 12VDC Integrated Resistor for 12VDC Integrated Resistor for 12VDC [1] Iv = typical luminous intensity @ If = 20mA (Ta=25°C), Low Power LEDs @ If = 2mA, Integrated Resistor LEDs @ Vf = 5VDC or @ Vf = 12VDC. Bi-color LEDs @ lf=10mA. 14 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products Data Display Products ® T-1 PCB MOUNT LEDs Single PCH125 PCH125-200 DDP PCV125 PCV125-200 All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products 15
PCV125-200-BCA
1. 物料型号:提供了多种LED型号,包括标准强度、中等强度和特殊LEDs。 2. 器件简介:文档描述了不同颜色的LED,包括红色、橙色、绿色,并提供了它们的波长、亮度和视角。 3. 引脚分配:文档中没有明确提供引脚分配的详细信息,但提供了LED的尺寸和机械数据。 4. 参数特性:列出了不同LED的典型发光强度(Iv),在20mA电流下的亮度,以及低功耗LED和集成电阻LED的特定参数。 5. 功能详解:文档详细介绍了特殊LED的功能,如低功耗、双色LED和集成电阻LED。 6. 应用信息:虽然文档没有直接提供应用信息,但通过LED的参数可以推断它们可能用于指示灯、信号灯等。 7. 封装信息:提供了不同型号LED的封装尺寸和公差。
PCV125-200-BCA 价格&库存
很抱歉,暂时无法提供与“PCV125-200-BCA”相匹配的价格&库存,您可以联系我们找货
