T-1 PCB MOUNT LEDs
Data Display Products
Single
- For Detailed LED Data, See Discrete Section, MODEL 125
1
TO ORDER, FOLLOW THE EXAMPLE:
Model
PCH125
PCH125-200
PCV125
PCV125-200
Select one BOLD component from each SHADED column in the tables below.
Right Angle Mount
Right Angle Mount
Vertical Mount
Vertical Mount
Model
LED
1PCH125
2 -BCA
➜Part Number PCH125-BCA
2 LED
-BR
-BA
-BG
STANDARD INTENSITY DIFFUSED ENCAPSULATION
λpk
Iv[1]
Viewing
Color
(nm)
(mcd)
Angle
RED
AMB
GRN
635
583
565
14
14
14
60
60
60
MEDIUM INTENSITY TINTED ENCAPSULATION
LED
-BCR
-BCA
-BCG
λpk
Iv[1]
Viewing
Color
(nm)
(mcd)
Angle
RED
AMB
GRN
635
583
565
60
30
44
45
45
45
SPECIALTY LEDs
λpk
Iv[1]
Viewing
LED
Color
(nm)
(mcd)
Angle
Description
-RLP
-ALP
-GLP
-DRG
-BR5V
-BA5V
-BG5V
-BR12V
-BA12V
-BG12V
RED
AMB
GRN
RED/GRN
RED
AMB
GRN
RED
AMB
GRN
635
583
565
635/567
635
583
565
635
583
565
2.1
1.6
2.1
4.3/3.7
8
8
8
8
8
8
50
50
50
118
60
60
60
60
60
60
Low Power
Low Power
Low Power
Bi-Color, Cathode on right, longer lead
Integrated Resistor for 5VDC
Integrated Resistor for 12VDC
[1] Iv = typical luminous intensity @ If = 20mA (Ta=25°C), Low Power LEDs @ If = 2mA, Integrated
Resistor LEDs @ Vf = 5VDC or @ Vf = 12VDC. Bi-color LEDs @ lf=10mA.
14
445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639
ww w.datadisplay.com
© 2005 Data Display Products
T-1 PCB MOUNT LEDs
Single
PCH125
PCH125-200
DDP
PCV125
PCV125-200
All dimensions are in inches (mm)
Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25)
Specifications are subject to change without notice.
15
很抱歉,暂时无法提供与“PCV125-BA12V”相匹配的价格&库存,您可以联系我们找货
