PCL1254-BR12V
PCL1254-BR12V
    VCC
    CBI LED T-1 3MM 4 LED ARRAY 60DE
PCL1254-BR12V 数据手册
T-1 PCB MOUNT LEDs Data Display Products ® Arrays - For Detailed LED Data, See Discrete Section, MODEL 125 TO ORDER, FOLLOW THE EXAMPLE: Select one BOLD component from each SHADED column in the tables below. Model LED 1PCL1254 2 -BCA ➜Part Number PCL1254-BCA 1 Model PCL1254 PCH125N-200[1] PCV125N-200[1] 2 LED -BR -BA -BG LED -BCR -BCA -BCG Right Angle Four LED Array Right Angle Variable Array Vertical Mount Variable Array STANDARD INTENSITY DIFFUSED ENCAPSULATION λpk Iv[2] Viewing Color (nm) (mcd) Angle RED AMB GRN 635 583 565 14 14 14 MEDIUM INTENSITY TINTED ENCAPSULATION λpk Iv[2] Color (nm) (mcd) RED AMB GRN 635 583 565 60 30 44 60 60 60 Viewing Angle 45 45 45 SPECIALTY LEDs Iv[2] Viewing LED Color (nm) (mcd) Angle Description -RLP -ALP -GLP -DRG -BR5V -BA5V -BG5V -BR12V -BA12V -BG12V RED AMB GRN RED/GRN RED AMB GRN RED AMB GRN 635 583 565 635/567 635 583 565 635 583 565 2.1 1.6 2.1 4.3/3.7 8 8 8 8 8 8 50 50 50 118 60 60 60 60 60 60 Low Power Low Power Low Power Bi-Color, Red Cathode Integrated Resistor for 5VDC Integrated Resistor for 5VDC Integrated Resistor for 5VDC Integrated Resistor for 12VDC Integrated Resistor for 12VDC Integrated Resistor for 12VDC λpk [1] Replace "N" with the number of LEDs in the array, 2 - 8 (e.g. PCH1253-200). [2] Iv = typical luminous intensity @ If = 20mA (Ta=25°C), Low Power LEDs @ If = 2mA, Integrated Resistor LEDs @ Vf = 5VDC or @ Vf = 12VDC. Bi-color LEDs @ lf=10mA. 16 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products Data Display Products T-1 PCB MOUNT LEDs ® Arrays PCL1254 PCH1253-200 DDP DDP DDP PCV1253-200 All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products 17
PCL1254-BR12V 价格&库存
很抱歉,暂时无法提供与“PCL1254-BR12V”相匹配的价格&库存,您可以联系我们找货
