PMRL125W-BCR5H
PMRL125W-BCR5H
    VCC
    PMI 10-8-14
PMRL125W-BCR5H 数据手册
.230" PANEL MOUNT REFLECTOR Data Display Products ® T-1, Water-Tight Optional - Reflective Chrome-Plated Body - Mounting Hardware Provided - For Detailed LED Data, See Discrete Section, MODEL 125 1 Model PMRL125 - Maximum Panel Thickness .125"(PMRL125); .070"(PMRL125, Water-Tight) TO ORDER, FOLLOW THE EXAMPLE: Wires Select one BOLD component from each numbered category in the tables below. W (optional) Model 1PMRL125 Wire W LED Voltage 2-BCG 3 12H Water Tight 4 ➜Part Number PMRL125W-BCG12H STANDARD INTENSITY - DIFFUSED ENCAPSULATION 2 LED Color (nm) -BR -BA -BG RED AMB GRN 635 583 565 Voltage/Current λpk Iv[1] Viewing V/C (mcd) Angle Table[2] 60 60 60 I I I 14 14 14 Design Max Vf/If Vf/If V/C Table I 5V/22mA 5.5V/28mA 12V/20mA 14V/25mA 15V/24mA 16.5V/28mA 24V/17mA 26V/20mA 28V/16.5mA 30V/18mA 48V/15mA 50V/16mA 60V/9mA 65V/10mA 120VAC/3.5mA 130VAC/4mA MEDIUM INTENSITY - TINTED ENCAPSULATION LED -BCR -BCA -BCG λpk Iv[1] Viewing V/C Color (nm) (mcd) Angle Table[2] RED AMB GRN 635 583 565 45 45 45 I I I 60 30 44 -NWR -NWA -NWG -NWB -NWW λpk Iv[1] Viewing V/C (nm) (mcd) Angle Table[2] RED AMB GRN BLU WHT 634 592 520 465 35 35 45 45 55 I I II II II 2180 2180 2000 600 1100 4 Voltage/Current Color Voltage[3] 2 5H 12H 15H 24H 28H 48H 60H 120[4] Design Max Vf/If Vf/If V/C Table II 5V/15mA 5.5V/23mA 12V/15mA 14V/20mA 15V/15mA 16.5V/18mA 24V/15mA 26V/18mA 28V/15mA 30V/17mA 48V/9.5mA 50V/10mA 60V/7mA 65V/8mA 120VAC/3.5mA 130VAC/4mA HIGH INTENSITY - WATERCLEAR ENCAPSULATION LED 3 Water Tight[5] -WT (optional) SPECIALTY LEDs - DIFFUSED ENCAPSULATION LED -RLP[6] -ALP[6] -GLP[6] -RG λpk Iv[1] Viewing V/C Color (nm) (mcd) Angle Table[2] RED AMB GRN RED/GRN 635 583 565 630/565 2.1 1.6 2.1 5.0/5.0 50 50 50 72 [2] [2] [2] [1] Iv = typical luminous intensity @ If = 20mA(Ta =25°C). For Low Power LEDs, If = 2mA. [2] See Voltage/Current table for design specifications. Design current for low power LEDs = 2mA. [3] Ta = 25°C. Votalge "2" indicates external resistor required. Voltages 5H through 60H are VDC. For AC operation, insert D after Voltage (e.g. 24HD). D indicates built-in rectifier, not required for 5H or 120VAC. DC operation not available for 120VAC. Bi-Color not available in AC voltages. 54 I Description Low Power Low Power Low Power Bi-Color, Red Cathode [4] Select high intensity LEDs only. [5] Drip-proof (not submersible), supplied with two neoprene gaskets. [6] Omit H when selecting a voltage (e.g. PMRL125-RLP12). 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products Data Display Products ® .230" PANEL MOUNT REFLECTOR T-1, Water-Tight Optional PMRL125 Standard Wire Leads: 6.0" total length(nominal)/.50" stripped (nominal), red anode/black cathode, 24 AWG TPB UL1061 insulation. Contact factory for other lengths, gauges and colors. All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products 55
PMRL125W-BCR5H 价格&库存
很抱歉,暂时无法提供与“PMRL125W-BCR5H”相匹配的价格&库存,您可以联系我们找货
