5SB-NWW28H
5SB-NWW28H
    VCC
    LED LAMP T2 ANSI NO. 5 28V SLIDE
5SB-NWW28H 数据手册
T-2 SLIDE BASED LAMP Data Display Products ® Single-Chip - For Detailed LED Data, See Discrete Section, MODEL 200. 1 TO ORDER, FOLLOW THE EXAMPLE: Model 2SB 5SB 55SB Select one BOLD component from each SHADED column in the tables below. ANSI No. 2 ANSI No. 5 T5.5 LED Voltage 1Model 2 3 2SB -BCG 12H ➜Part Number 2SB-BCG12H MEDIUM INTENSITY - TINTED ENCAPSULATION 2 LED -BCR -BCA -BCG λpk Iv[1] Color (nm) (mcd) RED AMB GRN 635 583 565 120 100 80 Viewing V/C Angle Table[2] 35 35 24 I I I Design Max Vf/If Vf/If V/C Table I 5V/22mA 5.5V/28mA 6V/21mA 7V/27mA 12V/20mA 14V/25mA 15V/24mA 16.5V/28mA 24V/17mA 26V/20mA 28V/16.5mA 30V/18mA 48V/15mA 50V/16mA 60V/9mA 65V/10mA 120VAC/3.5mA 130VAC/4mA HIGH INTENSITY - WATERCLEAR ENCAPSULATION LED -NWR -NWO -NWA -NWG -NWB -NWW -NWL -NKR -NKO -NKA -NKG -NKB -NKW -NKL λpk Iv[1] Viewing V/C Color (nm) (mcd) Angle Table[2] RED ORG AMB GRN BLU CWHT WWHT RED ORG AMB GRN BLU CWHT WWHT 634 605 592 520 465 2800 2000 2800 2400 700 2500 1800 3600 8000 3600 10000 3000 9200 9200 30 30 30 45 45 50 50 15 15 15 15 15 20 15 I I I II II II II I I I II II II II 634 605 592 520 465 -NFR -NFA -NFG -NFB -NFW λpk Iv[1] Viewing V/C Color (nm) (mcd) Angle Table[2] RED AMB GRN BLU CWHT 634 592 520 465 75 75 75 75 75 I I II II II 780 600 780 168 280 Voltage[3] 2 5H 6H 12H 15H 24H 28H 48H 60H 120[4] Voltage/Current WIDE ANGLE/FLAT-TOPPED-WATERCLEAR ENCAPSULATION LED 3 Voltage/Current Design Max Vf/If Vf/If V/C Table II 5V/15mA 5.5V/23mA 6V/15mA 7V/25mA 12V/15mA 14V/20mA 15V/15mA 16.5V/18mA 24V/15mA 26V/18mA 28V/15mA 30V/17mA 48V/9.5mA 50V/10mA 60V/9mA 65V/10mA 120VAC/3.5mA 130VAC/4mA SPECIALTY LEDs LED -RLP[5] -ALP[5] -GLP[5] -LRG Color RED AMB GRN RED/GRN λpk Iv[1] Viewing V/C (nm) (mcd) Angle Table[2] 50 50 50 60 [2] [2] [2] 635 583 565 660/565 2.3 2.1 2.3 90/40 [1] Iv = typical luminous intensity @ If = 20mA (Ta=25°C); Low Power LEDs @ If = 2mA. [2] See Voltage/Current table for design specifications. Design current for low power LEDs = 2mA. [3] Ta = 25°C. Voltage "2" indicates external resistor required. Voltages 5H through 60H are VDC. For AC operation, insert D after the Voltage (e.g. 24HD). D indicates built-in rectifier: not required for 5H or 120VAC. 120VDC operation not available. I Description Low Power Low Power Low Power Bi-Color [4] Select high intensity LEDs only. [5] Omit "H" Voltage designation (e.g. 2SB-RLP12). Continued… 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products 75 T-2 SLIDE BASED LAMP Data Display Products ® Single-Chip - For Detailed LED Data, See Discrete Section, MODEL 200. 2SB 5SB 55SB All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 76 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products Data Display Products ® T-2 SLIDE BASED LAMP Single-Chip Wide Angle LED Lamps 2SB, NFX Series (75°) 5SB, NFX Series (75°) 55SB, NFX Series (75°) All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products 77
5SB-NWW28H
物料型号:2SB、5SB、55SB
器件简介:文档描述了不同型号的LED灯,包括它们的封装类型和预期用途。
引脚分配:文档没有明确提供引脚分配信息。
参数特性:文档列出了不同颜色LED的波长(nm)、亮度(mcd)、视场角度和工作电压/电流表。
功能详解:文档提供了不同封装类型LED的详细特性,包括它们的亮度、颜色、视场角度和设计电压/电流。
应用信息:文档没有提供具体的应用案例,但提到了LED灯的一般用途。
封装信息:文档提供了不同型号LED的尺寸信息,包括最大长度、宽度和高度,以及公差。
5SB-NWW28H 价格&库存
很抱歉,暂时无法提供与“5SB-NWW28H”相匹配的价格&库存,您可以联系我们找货
5SB-NWW28H
